Fuel Shut-Off System
Revision as of 22:54, 16 March 2014; view current revision
Category: Fuel System
The Fuel Shut-Off System was introduced in some 1980 B310 USA models. It leverages the anti-diesel valve to stop the fuel flow during periods of deceleration. This is similar to what EFI systems do. It is only active at higher speeds, namely above 40mph.
1980: All California models
1980: FED A15.MT
1981 CAL, FED, FED.MPG and CAN.MPG models.
  Canada models did not use fuel-shut off except for
  MPG (FU Engine) models.
For safety and good performance, the FSOS does not work unless the engine is decelerating.
  • Only works when decelerating (vacuum is high AND speed above 40mph)
  • Does not work in neutral, so engine will not stop due to lack of fuel
  • Does not work when clutch is engaged (so you can blip the throttle)
Components are:
This would be an interesting system to retrofit to older models for increased fuel economy.
Fuel Shut-Off System replaces Throttle Opener.
  • Hitach DCH306-67
  • Dual-mode spark advance (intake vacuum works at idle, improving fuel economy)
  • Double-lead anti-diesel valve
  • 16767-H7280 UNIT-ENGINE REVOLUTION A14 FED(KFU) B310 [Engine Rev Switch, 1000-1150 RPM)
  • 16024-H7281 THROTTLE SWITCH ASSY A14 FED(KFU) B310 [Throttle Valve Switch]
  • 32130-H9011/32130-H9010 EXTENSION ASSY-REAR [unique, but others may work]
  • 32006-K2401 SWITCH COMP-NEUTRAL COUPE 5-SPEED(CAL),FED KFU [Neutral Detecting Switch] replaced 32130-H9705 32006-K2400
  • 10mph switch in speedometer
