Top Switch detects 4th gear AND neutral (whereas the Neutral Switch doesn't detect top gear). It is located on right side of gearbox. It is used by the TCVAS system.
Location
56-series Gearbox
Top switch on 4-speed 56-Series Transmission
on the front case, midway down
60-series Gearbox
Top Switch is of 60-Series Transmission
63-series Gearbox
Top Switch is on Tail Housing of 63-Series Transmission
between reverse and neutral switches
32006-H6000 $22 USD (F4W46L + F4W56A) * COMP-SWITCH,NEUTRAL + COMP-SWITCH 4TH * supercedes 32006-H3900 * F4W56L+F4W56A * 1972-1973 B110 USA
32006-H6502/32006-H6500 $22 USD (F4W56A+F4W60L) * 1974-1976 B210 USA
32006-K2464 supercedes 32006-K2400/32006-K2401 $27 USD (FS5W60A+F4W60) BLADE TERMINALS * 5-speed B210 USA 0476-0776 * 4-speed CAN 0876-0777 * 720 4-spd+5-spd TOP+NEUTRAL * S110 1981-1982 TOP * S130 Turbo 32006-K2400 COMP-SWITCH,4TH MANUAL * F4W71B * 620 CAL 0877- * 620 CAMP CAL 0178-
32006-K2004 superceds 32006-K2000 (FSW471B + FS5W71B + FS5W63A + F4W60L + F4W56A) BLADE TERMINALS SWITCH COMP-4TH/SWITCH COMP-TOP * 4-speed B210 USA 0876-0777 * 4-speed B210 USA+CAN 0877- * 5-speed B210 USA+CAN 0876- * 4-speed B310 USA * 5-speed B310 USA * 720 32006-K2000 COMP SWITCH TOP AND OVER DRIVE * FS5W71B * 620 5-SPEED USA 0778-
32006-D0164 supercedes 32006-D0120/32006-D0102 $24 USD B11 USA CD17 720 USA L20B+Z20/Z22 M20 EUR CA18S+E15S B11 EUR E13S/E15S/E16S
RockAuto.com Standard Motor Products NS197 * 32006-K2400/32006-K2401/32006-K2464![]()
RockAuto.com Standard Motor Products NS195 * 32006-K2000/32006-K2004![]()
B110
JAPAN - not used
USA 32006-H3900 COMP.-SWITCH,NEUTRAL 4 SPEED 0172-0673 32006-H6000 COMP-SWITCH,NEUTRAL 4 SPEED 0773- <> 32006-H3900 F4W56L 32006-H6000 COMP-SWITCH 4TH LAMP 4 SPEED 0473- F4W56A
B210 NORTH AMERICA COMP-SWITCH TOP
4-speed F4W56A -0874 A13 32006-H6500 COMP-SWITCH 4TH
4-speed F4W60 0974- A14 32006-H6500 0974-0776 32006-K2000 USA 0876-0777 32006-K2400 CAN 0876-0777 32006-K2000 0877-
5-speed FS5W63A COUPE ONLY 32006-K2400 0476-0776 32006-K2000 0876-
B310
B310 USA A12 56-series 4-speed * 32006-K2000 SWITCH COMP-4TH <> 32006-D0120 <> 32006-D0102 A14/A15 60-series 4-speed * SWITCH COMP-TOP (0879-) - same as 56-series FED, CAN A14/A15 FS5W60L & FS5W60A 32006-D0102 SWITCH COMP-TOP <> 32006-D0120 32006-K2000 SWITCH COMP-TOP 32130-H9000 32130-H9010 32130-H9705
