Datsun 1200 sedans have a regular trunk (boot) at the rear of the car. Coupes, being fastbacks but not hatchbacks, have a teensy weensy trunk lid at the back. The sedan trunk is very roomy for a car this size, and can hold about eight grocery bags, or luggage for five people. The lids are secured with a key lock.
In sedans, the Fuel tank is inside the trunk, next to the rear Seat, hidden behind a finisher panel.
Standard Equipment
The trunk came factory equipped with:
- Scissor Jack
- S-shaped Jack Handle
- Wheel Wrench in black Bag
For more details, see: Jack
- Spare Tire
Locks
See main article: Locks
Sedan
84830-H1000 BUMPER-trunk lid (2)
Moulding
Option: trunk lid trim. Also used on PB110.
84820-H1000 HANDLE-TRUNK SEDAN 84821-H1000 WASHER-TRUNK LID HANDLE SEDAN 84832-H1000 SPACER-TRUNK LID SEDAN (3) 08310-50812 SCREW (3) 08915-13510 WASHER (3)
トランク モール
Finishing Panels
The trunk finishing panels are made out of pressboard:
Coupe
Coupe has a small trunk lid.
Fitting
The 1200 coupe has interior plastic covers inside -- lots 'o plastic. There is plastic on the bottom side of the trunk lid too.
Floor trim panel fasteners are fastened by the typical B110 sheet screws (B210 changed to bolts/machine screws).
Trunk Lid Finish panel
- 84911-H1800 FINISH-TRUNK LID T=1.5
- 84905-H1800 STOPPER-TRIM TRUNK FLOOR
Rear Floor
- 08510-51612 SCREW-TAPPING M5 FIX TRIM (16)
- 08963-20540 NUT-SPRING TYPE A M5 FIX TRIM (16)
- 08915-43510 WASHER-PLAIN M5 FIX TRIM (16)
- 84902-H2500 TRIM-TRUNK FLOOR CENTER
- 84902-H7100 TRIM-TRUNK FLOOR CENTER (BLUE,LB-211
- 84902-H7101 TRIM-TRUNK FLOOR CENTER (BEIGE,LH-20
- 84902-H7102 TRIM-TRUNK FLOOR CENTER (BLACK,LG-13
- 84902-H1800 TRIM-TRUNK FLOOR CENTER
Rear Side
- 01553-00291 CLIP-TRIM (14)
- 66919-H1099 CLIP-TRIM (15)
- 84921-H1800 FINISH-TRUNK SIDE RH T=1.5
- 84921-H1900 FINISH-TRUNK SIDE RH T=2
- 84921-H2500 FINISH-TRUNK SIDE RH T=1,5
- 84922-H1800 FINISH-TRUNK SIDE LH T=1.5
- 84922-H2500 FINISH-TRUNK SIDE LH T=1.5
Rear
- 01553-00291 CLAMP (24)
- 84931-H1800 FINISH-TRUNK REAR T=2
- 84931-H1801 FINISH-TRUNK REAR T=2
- 84931-H2501 FINISH-TRUNK REAR T=2
Plastic Panel Fasteners
- 01553-00291 CLAMP/CLIP
- superseded 66919-H1001 CLIP-TRIM
76983-68400 LOCK-MALE 76982-68400 ASSY-LOCK FEMALE 08410-41210 SCREW-TAPPING 08915-43410 WASHER-PLAIN 08915-13410 WASHER-LOCK
84932-H1800 MASK-REAR LAMP T=2 84932-H2500 MASK-REAR LAMP T=2 84941-H1800 COVER-TRUNK LID HINGE 84939-H1800 WELT-TRUNK FINISH
Floor Fitting
- 32021-35000 PLUG-INSPECTION HOLE 55D USA
- 74891-H2500 ASSY-COVER INSPECTION HOLE
- 08510-61212 SCREW (6)
Weatherstrip
84810-H1001 WEATHERSTRIP-TRUNK LID Sedan $53.73 USD * superseded 84810-H1800 WEAHERSTRIP-TRUNK LID Coupe
Boot (trunk) seal is same material as 510. Possibly 510 part will fit with trimming for length.
84806-A4600 Weatherstrip 510 $60.75 USD
510 Trunk Weather Strip 84810-21001
