LR135
Revision as of 00:50, 1 April 2015; view current revision
Category: Charging System
Late model 35A with integral regulator came factory on Japan-market 1200s from October 1981.
The LR135 is the same dimensions as the externally-regulated LT135 (which was used by Datsun B110).
Hitachi (left) versus Mitsu (right). Bolt-on compatible, OEM (factory 1200 units)
Mitsubishi A1T22971
= Sources
AUS
N10 Pulsar with E13 engine
  • 1979 Datsun 620 Pickup 35A L20B engine
  • 1980 Datsun 720 pickup 35A L20B engine
Vehicles: B122、720、C122、TC22、E23、E20、E23、BF22、BGF22、PF22、PGF22、VB11
Engines: A12、A12S、Z16、Z18、L18、J16、Z18S、H20、Z20S、H20S、Z20、J15、J16、B210、B310、A14、A14E、E13S
RockAuto.com $50 and up
Baxter's Australia
  • 23100-B9810 Mitsubishi A1T22971 $90
  • 23100-B9802R Reman Alternator $260.33 from Nissan
  • 23100-B9802 ALTERNATOR ASSY Hitachi 8110-8910
  • 23100-B9810 ALTERNATOR ASSY Mitsubishi 8110-
  • 23100-B9800 Hitachi LR135
  • 23100-B9801
  • 23100-B9805
JDM 1990-1994 Nissan Sunny Truck
USA 1978-1979 Datsun 620 Pickup 35A
USA 1980 Datsun 720 Pickup with L20B 35A
Upgrade Compatibility
The LR135 is a DIRECT BOLT-ON for the stock 1200 35A alternator, and requires a one-wire connection. You can unplug or discard any external voltage regulator.
It bolts on, and uses the same fan belt as the 35A older LT135 alternator. Just be sure to disconnect the external voltage regulator.
The LR135 will fit B110, but has S+L wiring instead of F+N wiring. So one or two jumper wires are required.
Dimensions
Dimensions are the same as the LT135 externally-regulated alternator.
Distance between lower mounting ears: 80mm
Distance between Adjustment bolt and mount bolt: 156mm
Fan belt center: 29mm from front bolt face
Pulley diameter: 69mm
The LR135 has LS wiring like many modern Japanese alternators. The L-terminal goes to the CHG lamp, and the S-terminal goes to either IGN or straight to the battery.
