The Datsun 1200 Accelerator Pedal (gas pedal, fuel pedal) on mounted to the floor on RHD models, and suspended on LHD models.
Also see Throttle Cable and Pedal Box
Throttle Cable ball-end fits into slot on end of Accelerator Pedal. Usually a clip goes over the cable ball-end. But as long as the cable is properly adjusted you can drive it for years without the clip.
full
Right-Hand Drive
The Arm is similar to LHD, but has no pedal welded on, and the spring is in a different spot.
18010-H1010 ARM-COMP,accelerator pedal AUTOMATIC * includes: 18100-H1010 ARM ASS'Y,accelerator pedal AUTO 18021-H1000 BRACKET-ACCELERATOR PEDAL SNAP RING
18010-H1000 LEVER ASSY-PEDAL [MANUAL] * includes 18215-27700 SPRING-PEDAL ROD 18135-14800 BUMPER-ACCELERATOR 18021-H1000 BRACKET-PEDAL LEVER 08310-51014 SCREW 18137-10600 RING-SNAP
18110-H1000 PEDAL-ACCELERATOR [foot rest] * 08310-51214 SCREW (2) * fixing pedal stopper 08360-63512 SCREW 08911-30610 NUT
Left-Hand Drive
Pedal bumper (just below Throttle Cable clip)
18010-H1902 COMP-ARM ACCELERATOR PEDAL AUTOMATIC 18100-H1602 ASSY-ARM ACCELERATOR PEDAL AUTO
18010-H1602 COMP-ARM ACCELERATOR PEDAL MANUAL 18100-H1902 ASSY-ARM ACCELERATOR PEDAL MANUAL
Above assemblies include: * 18017-H1600 PAD-ACCELERATOR PEDAL * 18021-H1600 BRACKET-ACCELERATOR PEDAL * 18215-H1601 SPRING-RETURN ACCELERATOR * 18137-10600 RING-SNAP E TYPE * 08310-S1614 SCREW-MACHINE M5 FOR BRACKET TO BODY FIX
* 18135-14800 BUMPER-ACCELERATOR PEDAL STOPPER * 18056-H1600 BOLT-PEDAL STOPPER
