tapered Pipe Thread
Heater Hose 27070-H1000 CONNECTOR-WATER INLET [rear of cylinder head] $4.13 3/8 BSPT
The oil pressure switch threads is 1/8 BSPT (british standard pipe tapered) See Oil Pressure Sender.
3/8" Flywheel bolts, early A12
Fast Search Slow Search
Google Ad |
![]() BSPTRevision as of 03:59, 23 July 2015; view current revision Printable version | Disclaimers | Privacy policy | Current revision Category: Disambiguation tapered Pipe Thread Heater Hose 27070-H1000 CONNECTOR-WATER INLET [rear of cylinder head] $4.13 3/8 BSPT The oil pressure switch threads is 1/8 BSPT (british standard pipe tapered) See Oil Pressure Sender. 3/8" Flywheel bolts, early A12 |
