Valves
Revision as of 10:26, 23 July 2015; view current revision
Category: Valvetrain
Datsun 1200 uses traditional 8mm stem diameter poppet valves.
Maintenance
See main article: Valve adjustment
Removal & Installation
  1. Remove the Cylinder Head
  2. Compress the valve springs and remove the keepers, then the springs
  3. Slide valve out of the head
  4. Coat valve mating surface with grinding compound. Slide new valve in and lap the valve. Clean the compound off.
  5. If needed, remove old seals and put new seals on
  6. Re-fit the valve springs
Stem Oil Seal
See main article: Valve Seals
* Intake valve head diameter: 35 mm
* Exhaust valve head diameter: 29 mm
* Stem diameter: 8 mm
* Overall length: 103.80 mm
* Seat angle: 45 degrees
* Head style: standard
* Stem end: NG
* 13201-H1000 VALVE-INTAKE [35mm]
* 13202-18000 VALVE-EXHAUST [29mm]
* 13201-H2300 VALVE-INTAKE A12GX [35mm]
* 13202-H2300 VALVE-EXHAUST A12GX [29mm]
Valve Keepers
Valve Spring Retainer Keeper (Valve lock)
* Stem diameter 0.252
* 7 degree angle
* SEALED POWER Part # VK215
* BECK/ARNLEY Part # 0230045
* 1976-1979 Buick Opel/Isuzu 1.8
* 1976-1978 Chevrolet Luv/Isuzu 1.8
* 1981-1995 Isuzu, various models
* 1988-1996 Honda/Isuzu 2.6
* Datsun A-series
* Datsun L-series 4 and 6
* Datsun Z-series
July 1972 change
13209-18000 RETAINER-VALVE SPRING (8) <> 13209-H2300 <>  13209-H2301
13209-H2302 RETAINER-VALVE SPRING (8) 0772- [without O-ring grooves]
13209-H2302 RETAINER-VALVE SPRING (8) B210
13210-73400 COLLET-VALVE 1 (16) A12 (MATERIAL C40) < 13210-U0100
13210-H1000 COLLET-VALVE 1 (16) A12 0272- <> 13210-U0100
13210-U0100 COLLET-VALVE (MATERIAL C1010) B210 > 13210-73400 $1.13 USD
Valve Guides
See main article: Valve Guides
Valve Springs
See main article: Valve springs
Others
For other A-series valves (A14, etc) and for competition valves, see:
* Cylinder_Head_Identification#Valves
* Big Valves
