Also see:
Part Numbers Index Main article for usage, photos, cross-reference Door Door Hinge Door Glass Weatherstripping
Sedan
REAR DOOR (4 DOOR SEDAN)
1 82102-H1000 ASS'Y-PANEL, rear door (R.H.) STD
82102-H1100 ASS'Y-PANEL, rear door (R.H.) DX,GL,GX
82103-H1000 ASS'Y-PANEL, rear door (L.H.) STD
82103-H1100 ASS'Y-PANEL, rear door (L.H.) DX,GL,GX
2 82210-H1001 ASS'Y-SASH, rear door (R.H.)
82211-H1001 ASS'Y-SASH, rear door (L.H.)
3 82220-H1000 ASS'Y-SASH, partition, rear door (R.H.)
82221-H1000 ASS'Y-SASH, partition, rear door (L.H.)
4 82336-H1000 RUBBER-glass run "D" (2)
82336-H1001 RUBBER-glass run "D" (from '70-Oct.) (2) > 82336-H1000
5 08320-40612 SCREW-fixing partition to sash (2)
fixing partition to inner parcel
6 08915-53610 WASHER-plain (2)
7 08915-13610 WASHER-lock (2)
8 08410-61012 SCREW (2)
9 82254-H1000 GLASS-rear door corner (R.H.) STD
82254-H1100 GLASS-rear door corner (R.H.) DX,GL,GX
82255-H1000 GLASS-rear door corner (L.H.) STD
82255-H1100 GLASS-rear door corner (L.H.) DX,GL,GX
10 82242-H1000 WEATHERSTRIP-partition rear door (2)
REAR DOOR HINGE (4 DOOR SEDAN)
11 82400-H1001 HINGE ASS'Y-rear door, upper (R.H.)
82401-H1001 HINGE ASS'Y-rear door, upper (L.H.)
12 82402-H1000 HINGE ASS'Y-rear door, lower (2)
H0400-73002 BUSHING-door hinge (8)
fixing hinge
13 01221-00031 BOLT-with plain & lock washer (fixing hinge to pillar) (12)
14 08120-82062 BOLT-with lock washer (fixing hinge to door) (10)
or, fixing hinge
13 77720-89913 BOLT-special (fixing pillar) (12)
77740-89912 WASHER-plain special (fixing pillar) (12)
14 08120-82062 BOLT-with lock washer (fixing door) (10)
or, fixing hinge
13,14 011-21000 BOLT-with plain & lock washer (22)
REAR DOOR FITTING (4 DOOR SEDAN) 15 82830-H1000 WEATHERSTRIP ASS'Y-rear door (R.H.) 82831-H1000 WEATHERSTRIP ASS'Y-rear door (L.H.) 16 ※左右Setで左?性?り。 82820-H1000 MOULDING ASS'Y-rear door outside (R.H.) <※> 82820-H3100 82820-H3100 MOULDING ASS'Y-rear door outside (R.H.) (from '72-4) 82821-H1000 MOULDING ASS'Y-rear door outside (L.H.) <※> 82821-H3100 82821-H3100 MOULDING ASS'Y-rear door outside (L.H.) (from '72-4) 17 80825-H1000 CLIP-moulding, door outside (8) 18 82836-H1000 WEATHERSTRIP-rear door inside (R.H.) 82837-H1000 WEATHERSTRIP-rear door inside (L.H.) 19 80860-H1000 STOPPER ASS'Y-door glass (2) 20 08310-61214 SCREW 21 86865-21010 RUBBER-bumper, rear door (2) 22 82804-H1000 SCREEN-seal (2) 23 80840-21001 COVER-drain hole (4) 24 96502-H1001 ASH TRAY ASS'Y (1) STD (2) DX,GL,GX 25 08520-51212 SCREW (1) STD (2) DX,GL,GX
REAR DOOR TRIMMING (4 DOOR SEDAN)
26 82900-H1000 FINISHER ASS'Y-rear door (R.H.) STD
82900-H3100 FINISHER ASS'Y-rear door (R.H.) STD 1972
82901-H3100 FINISHER ASS'Y-rear door (L.H.) STD
82901-H3100 FINISHER ASS'Y-rear door (L.H.) STD 1972
27 82900-H1100 FINISHER ASS'Y-rear door (R.H.) (Black) DX,GL,GX
82900-H3200 FINISHER ASS'Y-rear door (R.H.) (Black) DX,GL,GX 1972
82900-H1101 FINISHER ASS'Y-rear door (R.H.) (Yellow) DX
82900-H3201 FINISHER ASS'Y-rear door (R.H.) (Yellow) DX 1972
82901-H1100 FINISHER ASS'Y-rear door (L.H.) (Black) DX,GL,GX
82901-H3200 FINISHER ASS'Y-rear door (L.H.) (Black) DX,GL,GX 1972
82901-H1101 FINISHER ASS'Y-rear door (L.H.) (Yellow) DX
82901-H3201 FINISHER ASS'Y-rear door (L.H.) (Yellow) DX 1972
28 80919-89900 CLIP-door finisher (12)
29 80929-32200 CAP-door finisher (12)
30 80960-H1000 HANDLE-pull (M5) (2) STD < 80960-H1001
80960-H1001 HANDLE-pull (M6) (2) STD
fixing pull handle
31 08310-52042 SCREW (M5) (4)
08310-62042 SCREW (M6) (4)
32 08915-43542 WASHER-plain (M5) (4)
08915-43642 WASHER-plain (M6) (4)
33 80940-H1100 ARM REST COMP (2) DX,GL,GX
fixing arm rest
34 08410-62012 SCREW (4)
35 08915-13610 WASHER-lock (4)
Van
Van
REAR DOOR (VAN) 1 82102-H1400 ASS'Y-PANEL, rear door (R.H.) 82102-H1400 ASS'Y-PANEL, rear door (R.H.) 2 82210-H1401 ASS'Y-SASH, rear door (R.H.) 82211-H1401 ASS'Y-SASH, rear door (L.H.) 3 82220-H1400 ASS'Y-SASH, partition, rear door (R.H.) 82221-H1400 ASS'Y-SASH, partition, rear door (L.H.) 4 82336-H1400 RUBBER-glass run "D" 2 5 83-20406-12 SCREW-fixing partition to sash 2 fixing partition to inner panel 6 89-15536-1 WASHER-plain 2 7 89-15136-1 WASHER-lock 2 8 84-10610-12 SCREW 2 9 82254-H1400 GLASS-rear door corner (R.H.) VS, VP 82254-H1500 GLASS-rear door corner (R.H.) 82255-H1400 GLASS-rear door corner (L.H.) VS, VP 82255-H1500 GLASS-rear door corner (L.H.) V-Dx. 10 82242-H1400 WEATHERSTRIP-partition rear door 2 V-Dx.
12 82402-H1000 HINGE ASS'Y-rear door, lower 2
fixing pillar
13 77720-89913 BOLT-special 12
14 77740-89912 WASHER-plain special 12
15 81-20820-62 BOLT-with lock washer (fixing door) 22
011-2100033 BOLT-with plain & lock washer 22
* <> (77720-89913 + 77740-89912 + 81-20820-62)
H0400-73002 BUSHING-door hinge 8
