The engine number is stamped on the engine block itself. It positively identifies the engine size (e.g. A12) as well as the serial number. The mark is always on the left (distributor) side of a Datsun A-series engine, but the location varies with the year. If you do not see the number, wipe the grease off the engine block.
Engine Number
A12 Engine ID Mark 1970-1973
photo:
photo:
photo:
Stamp is below #4 spark plug, on jutting pad
A12 ID Mark 1974-1995 Type A
A12 ID Mark 1974-1995 Type B
A12-E
Stamp is below #2 & #3 spark plugs, center of block, above fuel pump, forward of distributor
Old A13 ID Mark 1974
A12A ID Mark 1979-1982
Stamp is below #4 spark plug, on vertical pad
Early A14 Engine ID Mark
Early Tall-Block
Stamp is below #4 spark plug, aft of distributor
Late A14 Engine and A15 Engine ID Mark location
Late Tall-Block
1974(?) A12 vs 1974 A13
A12^ A13 below
Matching Numbers
If the engine is the original one, the serial number will match that on the Model Number Plate.
Nissan A Engines: Overview | A10 | A12 | A12A | A13, old | A13, new | A14 | A15
