Oil filter
Revision as of 08:07, 2 December 2015; view current revision
Category: Engine Lubrication System
Datsun 1200 takes a traditional spin-on oil filter with 76-82 mm diameter and threads of 3/4-16 (fine thread).
Pretty much any A-series filter fits. Or any with the same threads and diameter. Few are too long for the 1200.
Nissan
15208-H8920 Oil Filter 130mm length $7.08
* formerly: 15208-H1010 115 height $8.27 USD 0272-7910
** formerly: 15208-13211/15208-13212 145 length
15208-55Y00 Oil Filter $7.08 USD
formerly:
* 15208-H8911 FILTER ASSY-OIL 7911-8502
* 15208-H8903 FILTER ASSY-OIL 8502-
Specifications:
Threads: 3/4-16-UNF-2B
Outside Diameter: 80
Seal diameter: 70mm (original spec) or 63mm (revised spec)
Australia/New Zealand:
Ryco Z145A (102mm tall)
Ryco Z37 (143mm tall)
http://www.rockauto.com ELEMENT-oil filter, cartridge
PRO-TEC 150 $2.43
BECK/ARNLEY 0418723 $4.41
BOSCH 72133 $4.41
WIX 51361 $4.67
ACDELCO PF34 $4.88
FRAM PH3639 $6.00
Tokio FL-208(Y) 1300, 1500 C-201
FRAM ExtraGuard PH3639
Purolator #L30042
Deutsch #D601
Purolator PER42 (DATSUN,TOYOTA)
Purolator L30042
Pennzoil PZ8
Champion PH2822,2825
AC PF1026 (?)
Newer A-series filter PN 15208-H8920 (Length: 130)
Tokio FL-208
C-208
CKO-1218
SP-842
FC 208
15208H8923
T-3135
NISSAN 15208-55Y00
 Fits these USA models:
* B14U 1998- GA16DE
* B14X 1995- GA16DE
* D21 1986-1992 VG30, Z24, VG30E
* D21U 1995- KA24Em VG30
* S13 1991- KA24E
* S14 1994- KA24DE
* U13U 1993- KA24DE
* V40 1992-1997 VG30E
* WD21 1987-1989 Z24I, VG30E
* B12 1989- GA16I
* B13 1991- GA16DE
* J3- 1992- VG30E
* M11 1991- KA24E
* Z31 1991- VG30, VG30T
Ford F1 Filter
TIP: Use a Ford oil filter #F-1 on your 1200. You only need to use a rotary grinder to grind 1/4 inch off the engine boss. The rotary bit cuts cast iron like butter. Then it fits.
  • bigger capacity
  • In the US, it is less expensive than the small "import" filter
Other A-series
NISSAN SUNNY,CHERRY (Length: 100)
FL-207
15208-H8916
15208-H8911
15208-H8994
SP-929
15208-H8917
15208-H8912
15208-H8905
15208-H8904
15208-H8903
15208-H1011
15208-H1010
Purolator L24457
Pennzoil PZ27
Champion PH2827,2903 NISSAN,SUBARU
AC Delco PF8903
Wix 51361
Champ PH2827
Fram ExtraGuard PH3682
Fram ToughGuard TG3682
Fram DoubleGuard DG3682
Fram X2 XG3682
Fram PH3682 Fits:
* Kubota 66021-36060/66021-36061
* Komatsu 15208-01B02
* Komatsu 15208-H8911
* Komatsu 15208-H8920
* Komatsu 37Z-02-OF201/37Z-02-OF201L
* Nissan 15208-55Y00
* Nissan 15208-60U01/15208-60U02
* Nissan 15208-H8901/15208-H8903
* Nissan 15208-H8911/15208-H8916/15208-H8917
* Nissan 15208-H8994
* Subaru 15208-AA000/15208-AA001
* Subaru SOA5165100
* Volkswagen Fastback 1966-1973
* Volkswagen Squareback 1966-1973
* Volkswagen Karmann Ghia 1955-1974
* Volkswagen Thing 1973-1974
B210, B310, F10
Fram ExtraGuard PH46
Purolator L10168 (Audi 5000 Turbo)
AC DuraGuard PF34: PF34 #6437982
AC PF34 fits:
* 74-82 DATSUN F10,210,B210,310
* 78-80 FORD FIESTA L4-1.6L
* 71-73 PINTO L4-1.6L
* 72-75 CHEV LUV TRUCK
* 83-90 MERCEDES-BENZ 4 CYL
* 70-79 SUBARU
* 86-90 TOYOTA VAN 2.2L, 69-80 W/KC, RC ENGINES
* 81-84 STARLET
* 84-85 TERCEL L4-2.0L
Remote Filter
Use any style remote filter with a Ford V8 style Oil Pump Coolers adapter.
