The seal for the front crankshaft goes in the Timing Cover and seals the front pulley.
Front
- Nissan 13510-H1000 SEAL-OIL CRANKSHAFT FRONT
- BECK/ARNLEY 0521989
- SKF 14720
- TIMKEN 223830
- NATIONAL 223830 {Oil Seal; Acrylates / Shaft Size=1.496" Housing Bore=2.165" Outer Diameter=2.176" Width=0.276"}
- Nissan A-series
- Subaru 1972-1980 H4
- Subaru 1988-1991 H6
Repair Sleeve Timing Cover Repair Sleeve fixes a worn crankshaft pully surface caused by a poorly lubricated seal.
- before installation, be sure to put the slinger on correctly, and to grease the new seal.
- SKF Part # 99147
- NATIONAL Part # 99147 {Redi-Sleeve; 1.490" x 1.496" x .512"}
- TIMKEN Part # KWK99147 Kwik-Sleeve
Rear
- Nissan 12279-H1000 SEAL-OIL CRANKSHAFT REAR
- FEL-PRO Part # BS27493 {Rear Main Seal Set} OHV engine; Rear Main Seal Set; Rubber; One-piece
- TIMKEN Part # 712006
- NATIONAL Part # 712006 {Oil Seal; Silicone / Shaft Size=2.362" Housing Bore=3.228" Outer Diameter=3.236" Width=0.472"}
Repair Sleeve * TIMKEN Part # KWK99235 Kwik Sleeve, Optional Repair; Rear * NATIONAL Part # 99235 {Redi-Sleeve; 2.359" x 2.365" x .787"} Rear
