Crankshaft Seal
Revision as of 07:08, 3 January 2016; view current revision
Category: Engine Mechanical
The seal for the front crankshaft goes in the Timing Cover and seals the front pulley.
Front
  • Nissan 13510-H1000 SEAL-OIL CRANKSHAFT FRONT $7.24 USD
RockAuto.com
  • BECK/ARNLEY 0521989
  • SKF 14720
  • TIMKEN 223830
  • NATIONAL 223830 {Oil Seal; Acrylates / Shaft Size=1.496" Housing Bore=2.165" Outer Diameter=2.176" Width=0.276"}
Specs
* Shaft size: 38 mm
* Housing bore: 55 mm
* Outer diameter: 55.3 mm
* Width: 7 mm
  • Nissan A-series
  • Subaru 1972-1980 H4
  • Subaru 1988-1991 H6
Repair Sleeve Timing Cover Repair Sleeve fixes a worn crankshaft pully surface caused by a poorly lubricated seal.
  • before installation, be sure to put the slinger on correctly, and to grease the new seal.
  • SKF Part # 99147
  • NATIONAL Part # 99147 {Redi-Sleeve; 1.490" x 1.496" x .512"}
  • TIMKEN Part # KWK99147 Kwik-Sleeve
Rear
Installation
12279-H2301 Rear Main Seal
Also apply sealant here
Removal
  1. Remove oil pan
  2. Remove rear main bearing
  3. Lift out old seal
If replacing the rear main seal when changing a clutch, you may remove it with the oil pan still in place:
  1. Puncture seal with an awl, tiny screwdriver, or similar implement. Punch through the eddge of the seal, by gently tapping through with hammer
  2. Carefully pry out slightly and work your way around the circumference until free
  • Nissan 12279-H2301 SEAL-OIL CRANKSHAFT REAR $81 USD
  • 12279-H2301 is for all A12/A14/A14 engines
Seal specifications
* Shaft Size 60 mm
* Housing Bore 82 mm
* Outer Diameter 82.2 mm
* Width 12 mm
  • FEL-PRO Part # BS27493 {Rear Main Seal Set} OHV engine; Rear Main Seal Set; Rubber; One-piece
  • TIMKEN Part # 712006
  • NATIONAL Part # 712006 {Oil Seal; Silicone / Shaft Size=2.362" Housing Bore=3.228" Outer Diameter=3.236" Width=0.472"}
  • Corteco/Detroit Gasket 17209
Repair Sleeve
* TIMKEN Part # KWK99235 Kwik Sleeve, Optional Repair; Rear
* NATIONAL Part # 99235 {Redi-Sleeve; 2.359" x 2.365" x .787"} Rear
