The Rear Engine Crossmember is more commonly called the gearbox crossmember. Nissan calls it the "Rear Engine Mounting Member". This transmission crossmember holds the rear engine insulator (rubber transmission mount). The crossmember matches the car, while the insulator matches the transmission type.
Crossmember
Manual Transmission
B10
B110
11322-H1002 MEMBER-engine mounting, rear 3-speed, 4-speed
11322-H7200 MEMBER-engine mounting, rear 5-speed < 11322-H7201 from '72-10
- The 5-speed crossmember has a deeper dip, but is otherwise the same
- Both crossmembers use the same rubber insulator
When fitting a GX5 gearbox, you may use the 4-speed crossmember with spacers:
Japan 11322-H5000 MEMBER-engine mounting, rear 3-speed, 4-speed (56-series) 11322-H7400 MEMBER-engine mounting, rear from 7510 Van (also replaces 11322-H5000) 11322-H7500 MEMBER-engine mounting, rear A14 B210 60-series 4-speed![]()
11322-H5700 MEMBER-engine mounting, rear A12 5-speed F5C56 11341-H7500 MEMBER-engine mounting, rear A14 B210 5-speed 63-series
USA AUTO, MEMBER-ENGINE MOUNTING REAR 11341-H5200 11341-H7320 0974-0776 11340-H7500 AUTO -1276 11340-H7600 AUTO -1276 0177- <> 11340-H7500
USA MANUAL, MEMBER-ENGINE MOUNTING REAR 11322-H6200 11310-H6200 0973-0874 <5> 11322-H6200 11322-H7300 0974- 11341-H7310 FSW63A 5-speed from April 1976![]()
B310
Also see 60-series swap notes
60L 5-speed and all 60-series 4-speeds use the same crossmember and rubber insulator. The later 60A 5-speed uses a slightly different crossmember and insulator.
11340 MEMBER ASSY-ENGINE MOUNTING REAR
11340-H8500 B310 56-series 4-speed [2-bolt]
* 11321-H1000 INSULATOR-ENGINE MOUNTING REAR
11340-H8600 B310 60-series 4-speed & 60L 5-speed [4-bolt]
* 11320-W5000 INSULATOR-ENGINE MOUNTING REAR
11340-H8610 60A 5-speed <x> 11340-H8600
* 11320-H9100 INSULATOR-ENGINE MOUNTING REAR
11340-H8700 AUTOMATIC
* 11320-W5800 INSULATOR-ENGINE MOUNTING REAR
B310 has several holes in the body for the 4 crossmember types.
- Auto, 60L, and 60A all look similar and are 4-bolt. It is assymetrical
- 56-series looks different and is 2-bolt
- 3 holes on left side are 39.6 and 43.2 mm apart (front to back)
- 3 holes on right side are 43.6 and 40 mm apart
56-series 4-speed 11341-H9110 A12.(CAN.1278- , USA.0879-) * INSULATOR 11321-H6201
60-series F4W60/FS5W60L 11341-H8600 <> 11341-H9100 11341-H8600 MT intr-0779 11341-H9100 MT intr-0779.(FED+CAN) 11341-H9100 MT.F4 0879-1079.(FED+CAN) 11341-H8600 MT.F4 0879-exit.(CAL) * INSULATOR 11320-H9100
60-series 5-speed FS5W60A 11340-H8610 MT.FS5W60A 0879- CAL 11340-H9700 MT.FS5W60A 0879- FED+CAN * both use INSULATOR 11320-H9100
AUTOMATIC 11341-H9300 AT.FED+CAL 11341-H8700 AT.CAL * both use INSULATOR 11320-W5800
Automatic Transmission
- 11322-H1020 MEMBER-engine mounting, rear Automatic B110
- 11322-H5200 MEMBER-engine mounting, rear Automatic early B210
- 11340-H7500 MEMBER-engine mounting, rear Automatic late B210
- 11341-H8700 MEMBER-engine mounting, rear Automatic B310
Rubber Insulator
There are different types of rear insulators.
The 56-Series Transmission type of mount bolts to the crossmember from the sides of the mount, just like these stock 1200 mounts:
This type, used with 60-Series Transmission, straddles the crossmember and bolts from the bottom:
Automatic is yet again different.
56-series 11321-18000 INSULATOR F4.56-series B110, B10 11321-H6201 INSULATOR F4.56-series B310
60-series 11323-H7500 INSULATOR B210 11320-H9100 INSULATOR B310
63-series 11323-H7510 INSULATOR B210 FS5W63A A14/5-speed
AUTOMATIC 11321-20300 INSULATOR AT B10 11321-H1020 INSULATOR AT B110 11321-H2521 INSULATOR AT B210 early 11321-H7321 INSULATOR AT B210 late 11320-W5800 INSULATOR AT B310
56-series
PN 11321-H1000 INSULATOR ASS'Y-engine mounting, rear manual trans $35.83 USD * B110, B210, B310 * 56-series transmission (3-speed, 4-speed and 5-speed)![]()
* Are 11321-H1000, 11321-H5000, 11320-H5000 all the same?
LATE B210 A12 11323-H7400 INSULATOR ASS'Y-engine mounting, rear MT
Anchor 2489
B10
B10 MT mount looks identical to the newer B110/B210/B310 version.
11321-18000, 11321-20300 ASS'Y INSULATOR-rear![]()
60-series
- 11321-H7500 INSULATOR ASS'Y-engine mounting, rear manual trans: A14 B210 4-speed (60-Series)
- 11320-H9100 INSULATOR-ENGINE MOUNTING REAR B310 5-speed (60-series) from 7911 $120.48 USD
- superceded 11320-W5000 INSULATOR-ENGINE MOUNTING REAR B310 KB310HF,B310HF (A12) 5-speed, A14 4-speed
- Anchor Industries 2489
- 1972-1982 Nissan Vehicles
63-Series
B210 USA B210 11323-H7310 COMP.-INSULTOR ENGINE MOUNTING REAR 5-SPEED 0476- * DEA A7316
4-speed * DEA A6360
B110: Similar to 56-series M/T insulator B210: Has shift bracket integrated B310: Rationalized to use 60/71 series M/T insulator
B110
11321-H1020 INSULATOR ASS'Y-engine mounting, rear auto trans B110 $54.18 USD* Anchor 8115 $8.13 RockAuto.com * Westar EM-8115
B10
Datsun 1000 11321-20300 ASS'Y INSULATOR-rear Coupe Automatic B10
JAPAN 11321-H2521 INSULATOR ASS'Y-engine mounting, rear auto trans early B210 11321-H7321 INSULATOR ASS'Y-engine mounting, rear auto trans late B210 $117 USD
1974 USA 11320-H6900 Insul Mount USA -0874 $120 USD![]()
* DEA A2760 * Westar EM-2760 CANADA * Pioneer 622760
B310
11320-W5800 INSULATOR-ENGINE MOUNTING REAR B310 auto trans $79.77 USD * C120, S110, S12?![]()
* Anchor 2488 ** S12 CA20E MT ** S12 CA18ET ** B210 A14 AT ** B310 some ** B210 1978
11320-W5000 910, B310, C120, F30
Also See
For swap details and other information, see:
* Transmission Interchange#Gearbox_Crossmember * 56-Series Transmission * 60-Series Transmission * 63-Series Transmission
Conversions
See the following:
* Putting F5C56A into 4-speed cars: 56-Series_Transmission#56_5-speed_swap_Notes * Putting 60-series transmission into 1200: 60-Series_Transmission#Swap_Notes
ミッション メンバー
