Differential Part Numbers
Revision as of 00:27, 15 May 2016; view current revision
Categories: Propeller Shaft And Differential Carrier | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
H145 Differential
H165
H145 Composite
* 38300-18000 ASS'Y-CARRIER, with gear 37:9 (4.111) B10 Sedan & Coupe
* 38300-18100 ASS'Y-CARRIER, with gear 35:8 (4.375) B10 Van
* 38300-H0700 ASS'Y-CARRIER, with gear 35:8 (4.375) B10 Van
* 38300-15400 ASS'Y-CARRIER, with gear 35:8 (4.625) B20 Truck
* 38300-G0500 ASS'Y-CARRIER, with gear 35:8 (4.625) B20 Truck
* 38300-H1000 ASSY-CARRIER WITH GEAR 37:8(3.900) B110
* 38300-H1010 ASSY-CARRIER WITH GEAR 39:10(3.900) 0374-0874
1 38310-18000 COMP-CARRIER, gear B10
  fixing differential bearing cap
  2 38317-18000 WASHER 4
    38318-18000 NUT 4
  3 38315-18000 STUD 4
1 38310-G0400 COMP-CARRIER GEAR B110
  2 08915-14010 WASHER-LOCK FIXING DIFF BEARING CAP
  3 38315-G0400 BOLT FIXING DIFF BEARING CAP
4 38100-18000 SET-GEAR, hypoid with pinion (37 T:9 T) B10 Sedan & Coupe
4 38100-18100 SET-GEAR, hypoid with pinion (35 T:8 T) B10 Van
4 38100-H0700 SET-GEAR, hypoid with pinion (35 T:8 T) B10 Van
4 38100-15400 SET-GEAR, hypoid with pinion (37 T:8 T) B10 T
4 38100-G0400 SET-GEAR, hypoid with pinion (37 T:8 T) B10 T (from '67-Nov)
4 38100-H1000 SET-GEAR & PINION HYPOID B110 39:10T Sedan,Coupe
4 38100-H1100 SET-GEAR & PINION HYPOID B110 37:9T Van
5 38102-G0300 BOLT-drive gear 8
  38102-18000 BOLT-DRIVE GEAR 8
  38102-18100 BOLT-DRIVE GEAR 8
6 38103-G0400 STRAP-LOCK BOLT
7 38421-G0500 CASE DIFFERENTIAL
8 38423-18000 GEAR-SIDE DIFF BEVEL
9 38424-18000 WASHER-THRUST SIDE GEAR T=0.76 MM
9 38424-18001 WASHER-THRUST SIDE GEAR T=0.81 MM
9 38424-18002 WASHER-THRUST SIDE GEAR T=0.86 MM
9 38424-18003 WASHER-THRUST SIDE GEAR FOR SERVICE T=0.
9 38424-18004 WASHER-THRUST SIDE GEAR FOR SERVICE T=0.
9 38424-18005 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18006 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18007 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18008 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18009 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18010 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18011 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18012 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18013 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18014 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18015 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18016 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
10 38425-18000	MATE-PINION DIFF BEVEL
11 38426-18000 WASHER-THRUST PINION MATE
12 38427-18000 SHAFT-PINION MATE
13 38428-G0400 PIN-LOCK DIFF PINION
14 38440-H1000 ASSY-BEARING DIFF SIDE
* superseded 38440-18000 ASSY-BEARING DIFF SIDE
15 38453-H1000 SHIM-ADJUST SIDE BEARING T=0.05
15 38454-H1000 SHIM-ADJUST SIDE BEARING T=0.07
15 38455-H1000 SHIM-ADJUST SIDE BEARING T=0.10
15 38456-H1000 SHIM-ADJUST SIDE BEARING T=0.20
15 38457-H1000 SHIM-ADJUST SIDE BEARING T=0.50
16 38120-18000 ASSY-BEARING DRIVE PINION REAR
17 38140-18000 ASSY-BEARING DRIVE PINION FRONT
18 38165-H1000 SPACER-DRIVE PINION BEARING
18 38165-H1001 SPACER-DRIVE PINION BEARING 0374-
19 38154-G0400 WASHER-ADJUST DRIVE PINION T=2.74
19 38154-G0401 WASHER-ADJUST DRIVE PINION T=2.77
19 38154-G0402 WASHER-ADJUST DRIVE PINION T=2.80
19 38154-G0404 WASHER-ADJUST DRIVE PINION T=2.86
19 38154-G0406 WASHER-ADJUST DRIVE PINION T=2.92
19 38154-G0403 WASHER-ADJUST DRIVE PINION T=2.83
19 38154-G0405 WASHER-ADJUST DRIVE PINION T=2.89
19 38154-G0407 WASHER-ADJUST DRIVE PINION T=2.95
19 38154-G0408 WASHER-ADJUST DRIVE PINION T=2.98
19 38154-G0409 WASHER-ADJUST DRIVE PINION T=3.01
19 38154-G0410 WASHER-ADJUST DRIVE PINION T=3.04
19 38154-G0411 WASHER-ADJUST DRIVE PINION T=3.07
19 38154-G0412 WASHER-ADJUST DRIVE PINION T=3.10
19 38154-G0413 WASHER-ADJUST DRIVE PINION T=3.13
19 38154-G0414 WASHER-ADJUST DRIVE PINION T=3.16
19 38154-G0415 WASHER-ADJUST DRIVE PINION T=3.19
19 38154-G0416 WASHER-ADJUST DRIVE PINION T=3.22
19 38154-G0417 WASHER-ADJUST DRIVE PINION T=3.25
20 38189-18000 SEAL-OIL DRIVE PINION
21 38210-H1000 ASSY-FLANGE COMPANION WITH DAMPER
21 38210-18000 ASSY-FLANGE COMPANION
22 38215-01300 WASHER-PLAIN -0274
23 38216-H1000 NUT-DRIVE PINION 0374-
23 38216-18000 NUT-DRIVE PINION
24 38320-18010 GASKET-GEAR CARRIER
25 08915-13810 WASHER-LOCK
26 08911-20810 NUT
H165
The H165 was used all years of the 1200 Sunny Truck.
FINAL DRIVE
 fits early housing:
  38300-A6400 GEAR CARRIER ASS'Y (37/9) (H165A type)
  38300-N5201 GEAR CARRIER ASS'Y (37/9) (H165B type) (from '73-1)
 fits 2nd housing:
  38300-N5200 GEAR CARRIER ASS'Y (37/9) (H165B type) (from '73-9)
  38100-W9000 HC41 7907-8605
  38100-G3300 HC41 8605-
 1 38310-A6100 GEAR CARRIER COMP. <x> 38310-N5000
   38310-N5000 GEAR CARRIER COMP. 7301-8109
   38310-W8500 CARRIER COMPL-GEAR 8110-
 2 38310-N5000  BOLT-diff bearing cap 4
   08915-14010  WASHER-lock 4
  38315-U1500  BOLT-bearing cap (from '72-5) 4 <> 38310-N5000 + 08915-14010
 3 38100-28500 HYPOID GEAR & PINION SET (37/9) <x> 38100-N5200
   38100-N5200 HYPOID GEAR & PINION SET (37/9) (from '73-1)
 4 38102-28500 BOLT-drive gear -7906 8
   38102-W8500 BOLT-DRIVE GEAR 7907-8605 8
   38102-11S00 BOLT-DRIVE GEAR 8605- 8
 5 38103-28501 STRAP-lock bolt -7906 4
   38103-W8501 STRAP-LOCK,BOLT 7906-8605 4
 6 38421-28500 CASE-diff
   38421-N5000 7510-7906 FLANGE OFFSET 29.0 <0> 38421-W8500
   38421-W8500 7907-8605 FLANGE OFFSET 31.5
   38421-G3000 8605-     CASE-DIFFERENTIAL
 7 38423-28500 GEAR-side, diff bevel 2
 8 38425-28500 PINION-mate, diff bevel 2
 9 2 of thickness as required
   38424-04101 WASHER-thrust, side gear (t=0.785)
   38424-08000 WASHER-thrust, side gear (t=0.835)
   38424-08001 WASHER-thrust, side gear (t=0.885)
   38424-08002 WASHER-thrust, side gear (t=1.035)
   38424-08003 WASHER-thrust, side gear (t=1.185)
10 38426-04100 WASHER-thrust, pinion mate 2
11 38427-28500 SHAFT-diff pinion -8410 <2,0> 38427-28501
   38427-28501 SHAFT-PINION MATE 8411-
12 38428-21001 PIN-lock, pinion shaft <> 38428-U1500
   38428-U1500 PIN-lock, pinion shaft (from '72-5)
13 38440-61501 BEARING ASS'Y-diff side 2
14 38453-28500 SHIM-adjust, drive gear  (t=0.050) 2
   38454-28500 SHIM-adjust, drive gear  (t=0.750) 2
   38455-28500 SHIM-adjust, drive gear  (t=0.105) 3
   38456-28500 SHIM-adjust, drive gear  (t=0.200) 3
   38457-28500 SHIM-adjust, drive gear  (t=0.500) 2
15 38120-13201 BEARING ASS'Y-pinion rear
16 38140-13201 BEARING ASS'Y-pinion front
17 to '72-12, choose 1
     38165-28500 SPACER-pinion bearing (l=48.40)
     38166-28500 SPACER-pinion bearing (l=48.60)
     38167-28500 SPACER-pinion bearing (l=48.80)
     38168-28500 SPACER-pinion bearing (l=49.00)
   from '73-1
     38165-N5000 SPACER-pinion bearing
19 to '72-12, choose 1
     38127-09400 WASHER-adjust, pinion bearing (t=2.58-2.60)
     38128-09400 WASHER-adjust, pinion bearing (t=2.56-2.58)
     38129-09400 WASHER-adjust, pinion bearing (t=2.54-2.56)
     38130-09400 WASHER-adjust, pinion bearing (t=2.52-2.54)
     38131-09400 WASHER-adjust, pinion bearing (t=2.50-2.52)
     38132-09400 WASHER-adjust, pinion bearing (t=2.48-2.50)
     38133-09400 WASHER-adjust, pinion bearing (t=2.46-2.48)
     38134-09400 WASHER-adjust, pinion bearing (t=2.44-2.46)
     38135-09400 WASHER-adjust, pinion bearing (t=2.42-2.44)
     38136-09400 WASHER-adjust, pinion bearing (t=2.40-2.42)
     38137-09400 WASHER-adjust, pinion bearing (t=2.38-2.40)
     38138-09400 WASHER-adjust, pinion bearing (t=2.36-2.38)
     38139-09400 WASHER-adjust, pinion bearing (t=2.34-2.36)
     38140-09400 WASHER-adjust, pinion bearing (t=2.32-2.34)
     38141-09400 WASHER-adjust, pinion bearing (t=2.30-2.32)
20 as required [not shown in 1997 catalog]
     38153-28500 SHIM-adjust, side bearing (t=0.050)
     38154-28500 SHIM-adjust, side bearing (t=0.075)
     38155-28500 SHIM-adjust, side bearing (t=0.105)
     38156-28500 SHIM-adjust, side bearing (t=0.200)
     38157-28500 SHIM-adjust, side bearing (t=0.500)
21 from '71-1 as required:
   early
    38154-U1500 WASHER-adjust drive pinion (t=3.09)
    38154-U1501 WASHER-adjust drive pinion (t=3.12)
    38154-U1502 WASHER-adjust drive pinion (t=3.15)
    38154-U1503 WASHER-adjust drive pinion (t=3.18)
    38154-U1504 WASHER-adjust drive pinion (t=3.21)
    38154-U1505 WASHER-adjust drive pinion (t=3.24)
   -8503
    38154-U1506 WASHER-adjust drive pinion (t=3.27)
    38154-U1507 WASHER-adjust drive pinion (t=3.30)
    38154-U1508 WASHER-adjust drive pinion (t=3.33)
    38154-U1509 WASHER-adjust drive pinion (t=3.36)
    38154-U1510 WASHER-adjust drive pinion (t=3.39)
    38154-U1511 WASHER-adjust drive pinion (t=3.42)
    38154-U1512 WASHER-adjust drive pinion (t=3.54)
    38154-U1513 WASHER-adjust drive pinion (t=3.48)
    38154-U1514 WASHER-adjust drive pinion (t=3.51)
    38154-U1515 WASHER-adjust drive pinion (t=3.54)
    38154-U1516 WASHER-adjust drive pinion (t=3.57)
    38154-U1517 WASHER-adjust drive pinion (t=3.60)
    38154-U1518 WASHER-adjust drive pinion (t=3.63)
    38154-U1519 WASHER-adjust drive pinion (t=3.66)
   8504-
    38154-W1060 (t=3.09)
    38154-W1061 (t=3.12)
    38154-W1062 (t=3.15)
    38154-W1063 (t=3.18)
    38154-W1064 (t=3.21)
    38154-W1065 (t=3.24)
    38154-W1066 (t=3.27)
    38154-W1067 (t=3.30)
    38154-W1068 (t=3.33)
    38154-W1069 (t=3.36)
    38154-W1070 (t=3.39)
    38154-W1071 (t=3.42)
    38154-W1072 (t=3.45)
    38154-W1073 (t=3.48)
    38154-W1074 (t=3.51)
    38154-W1075 (t=3.54)
    38154-W1076 (t=3.57)
    38154-W1077 (t=3.60)
    38154-W1078 (t=3.63)
    38154-W1079 (t=3.66)
22 38189-02700 SEAL-oil, drive pinion
23 38210-16500 FLANGE ASS'Y-companion <x> 38210-N1200
   38210-N1200 FLANGE ASS'Y-companion (from '73-)
25 to '72-4
    38215-21000 WASHER-drive pinion
    38216-21000 NUT-drive pinion
   from '72-5
    38216-U1500 NUT-pinion
   8110-
     38216-U3000 NUT-DRIVE PINION
25 38320-04110 GASKET-gear carrier
   83820-N5000 GASKET-GEAR CARRIER 7510-
26 08120-82562 BOLT -8109 8
   38321-N5000 BOLT-FINAL DRIVE 8110- 8
27 08915-13810 WASHER-lock 8
   08915-23810 WASHER 7510-8004 8
   08915-13810 WASHER 8005- 8
28 08911-20810 NUT 8 [not shown in 1997 catalog]
1 38300-H1000 ASSY-CARRIER WITH GEAR 39:10(3.900)
2 38310-G0400 COMP-CARRIER GEAR
3 38315-G0400 BOLT FIXING DIFF BEARING CAP (4)
4 08915-14010 WASHER-LOCK FIXING DIFF BEARING CAP (4)
5 38100-H1000 SET-GEAR & PINION HYPOID 39:10
6 38102-G0300 BOLT-DRIVE GEAR (8)
7 38103-G0400 STRAP-LOCK BOLT (4)
8 38421-G0500 CASE DIFFERENTIAL
9 38423-18000 GEAR-SIDE DIFF BEVEL (2)
10 38424-18000 WASHER-THRUST SIDE GEAR (0)
10 38424-18001 WASHER-THRUST SIDE GEAR (0)
10 38424-18002 WASHER-THRUST SIDE GEAR (0)
11 38425-18000 MATE-PINION DIFF BEVEL (2)
12 38426-18000 WASHER-THRUST PINION MATE (2)
13 38427-18000 SHAFT-PINION MATE
14 38428-G0400 PIN-LOCK DIFF PINION
15 38440-H1000 ASSY-BEARING DIFF SIDE (2) 0772- 2 38440-18000
15 38440-18000 ASSY-BEARING DIFF SIDE (2)
16 38453-H1000 SHIM-ADJUST SIDE BEARING T=0.05 (0)
16 38454-H1000 SHIM-ADJUST SIDE BEARING T=0.07 (0)
16 38455-H1000 SHIM-ADJUST SIDE BEARING T=0.10 (0)
16 38456-H1000 SHIM-ADJUST SIDE BEARING T=0.20 (0)
16 38457-H1000 SHIM-ADJUST SIDE BEARING T=0.50 (0)
17 38120-18000 ASSY-BEARING DRIVE PINION REAR
18 38140-18000 ASSY-BEARING DRIVE PINION FRONT
19 38165-H1000 SPACER-DRIVE PINION BEARING
20 38154-G0406 WASHER-ADJUST DRIVE PINION T=2.92 (0)
20 38154-G0407 WASHER-ADJUST DRIVE PINION T=2.95 (0)
20 38154-G0414 WASHER-ADJUST DRIVE PINION T=3.16 (0)
20 38154-G0417 WASHER-ADJUST DRIVE PINION T=3.25 (0)
20 38154-G0404 WASHER-ADJUST DRIVE PINION T=2.86 (0)
20 38154-G0400 WASHER-ADJUST DRIVE PINION T=2.74 (0)
20 38154-G0401 WASHER-ADJUST DRIVE PINION T=2.77 (0)
20 38154-G0402 WASHER-ADJUST DRIVE PINION T=2.80 (0)
20 38154-G0415 WASHER-ADJUST DRIVE PINION T=3.19 (0)
20 38154-G0405 WASHER-ADJUST DRIVE PINION T=2.89 (0)
20 38154-G0416 WASHER-ADJUST DRIVE PINION T=3.22 (0)
20 38154-G0408 WASHER-ADJUST DRIVE PINION T=2.98 (0)
20 38154-G0409 WASHER-ADJUST DRIVE PINION T=3.01 (0)
20 38154-G0410 WASHER-ADJUST DRIVE PINION T=3.04 (0)
20 38154-G0411 WASHER-ADJUST DRIVE PINION T=3.07 (0)
20 38154-G0412 WASHER-ADJUST DRIVE PINION T=3.10 (0)
20 38154-G0413 WASHER-ADJUST DRIVE PINION T=3.13 (0)
20 38154-G0403 WASHER-ADJUST DRIVE PINION T=2.83 (0)
21 38189-18000 SEAL-OIL DRIVE PINION
22 38210-H1000 ASSY-FLANGE COMPANION WITH DAMPER FOR SERVICE
22 38210-18000 ASSY-FLANGE COMPANION
23 38215-01300 WASHER-PLASN
24 38216-18000 NUT-DRIVE PINION
25 38320-18010 GASKET-GEAR CARRIER
26 08915-13810 WASHER-LOCK (8)
27 08911-20810 NUT (8)
