Seat Rails
Revision as of 02:38, 21 August 2016; view current revision
Category: Interior
Seat rails are two kinds: 1) Full adjustable fore-aft sliding 2) Non-sliding (truck passenger side).
Unbolt the rails from your seats and bolt them to the new seat.
Left side seat - Coupe & all USA (sedan & coupe)
5185.jpg Seat Slide (aka Seat Rail)
Dimensions - Bolt holes To floor
  • Side to side: 15-11/16 inch
  • Front to back: 12-3/16 inch
USA seat with switch
Left seat slide
Left side Rail
Left-hand Slide
B110 rails in B10 (one-piece slide cut into two)
If you don't have the B110/B210 rails, you can adapt B310 slides:
5086.jpgAlbum 5086
Modifying B310 brackets to fit B110 chassis
Location
The seat rails bolt to the floor risers.
Front Riser "A", Rear risers "B" and "C"
fullsize
Front Riser "A"
fullsize
Lowering
Seat Rail
Converter Seats
1200s from Oct 1989 have a Catalytic Convertor.
Passenger side rail is shaped differently to clear the Catalytic Convertor bulge in the floor
Truck
Truck driver's seat has an adjustable slide. The passenger seat is a fixed (non-adjustable) "seat riser" bracket.
87500-G1000 SLIDE ASS'Y-driver seat ドライバ- シート スライド -1974
87501-G1000 SLIDE-RH SEAT, OUTSIDE スライド、RH シート アウトサイド
87502-G1000 SLIDE-RH SEAT, INSIDE スライド、RH シート インサイド
87556
87505-G1000 BRACKET ASSY-FRONT SEAT, LH ブラクット アッセンブリ、フロント シートLH
 RISER ASS'Y-seat シート ライザー
 [non-adjustable]
08110-81862 BOLT fixing slide to floor (8)
08915-43810 WASHER fixing slide to floor (8)
08310-82014 SCREW fixing slide to seat (8)
 08310-81812 -7510
08915-13810 WASHER fixing slide to seat (8)
Bride
The famous Bride rails for Sunny Truck
200 mm seat travel fore-to-aft
Late Sunny Truck with converter bulge 1989-up
Left seat Dimensions - Bolt holes To floor
  • Front to back (left side): 12-3/16 inch
  • Front to back (right side) goes 1-1/2 farther back, and 1-1/2 farther forward compared to left side
    • slanted tabs
      15-1/2" at base, 16-1/4" at bottom edges
      front tab: 1-7/16" long
      rear tab: 1-3/8" long
Bride B122 Part Numbers
  • LH: code N030VO type V*1 TTM-L No. 939063
  • RH: code N029VO type V*1 TTM-L No. 939064
  • V type: for Bride full bucket, 30 mm height
  • S type: for Bride reclining seat
  • VF type: for Bride full bucket, no slide (fixed position)
th_000.jpg th_001.jpg th_002.jpg th_003.jpg th_004.jpg th_005.jpg th_006.jpg th_007.jpg th_008.jpg th_009.jpg th_010.jpg th_011.jpg th_012.jpg th_013.jpg th_014.jpg th_015.jpg th_016.jpg th_017.jpg th_018.jpg th_019.jpg th_020.jpg th_021.jpg th_022.jpg th_023.jpg th_024.jpg th_025.jpg th_026.jpg th_027.jpg th_028.jpg th_029.jpg th_030.jpg th_031.jpg th_032.jpg th_033.jpg th_037.jpg th_038.jpg th_039.jpg
シート スリイド シート リイザー ブラケット
