<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference Driveshaft
Truck
Short Body
PROPELLER SHAFT (Short Body)
1 37000-G1000 SHAFT ASS'Y-propeller (up to '72-2)
2 37000-G1010 SHAFT ASS'Y-propeller (from '72-3)
37000-G1011 SHAFT ASS'Y-propeller (from '73-9) 2 JOINT ATSUGI
fixing propeller shaft
2 01111-00081 BOLT (ℓ=25 mm) 4
01111-00051 BOLT (ℓ=25 mm) 4
3 08911-20810 NUT 4
4 08915-13810 WASHER-lock 4
Long Body
1974
1974 PROPELLER SHAFT (Long Body) 1 37000-G1400 SHAFT ASS'Y-propeller (up to '73-8) 37000-G1410 SHAFT ASS'Y-propeller (from '73-9) 2 01111-00051 BOLT 4 3 08911-20810 NUT 4 4 08915-13810 WASHER-lock 5 37510-G1401 BRACKET-center bearing, lower 6 08154-02010 BOLT 2 7 08915-14010 WASHER-lock 2 8 37522-P0101 INSULATOR-center bearing 9 37525-P0101 CUSHION-center bearing 10 74345-G1401 BRACKET ASS'Y-center bearing, upper
1997
FIG.H74-01 (74345) 37000 SHAFT ASSY-PROPELLER 37000-G1410 LB 7510-9204 3 JOINT ATSUGI 37000-95W00 LB 9204- 3 JOINT 37000A BOLT-FIX PROPELLER SHAFT 01111-00051 4 08915-13810 WASHER 08911-20810 NUT 37000H NUT LB 37163-G1400 7510-7712 <2,0> 73163-G1401 37163-G1401 7801- 37000J WASHER-LOCK LB -7712 38215-61001 -7712 37512 BRACKET-CENTER BEARING LB 37510-G1401 7510-8503 <2,0> 37510-G1402 37510-G1402 8504- 08154-02010 BOLT 08915-14010 WASHER 37521K BEARING KIT-CENTER LB 37521-Y0125 7510-9204 37521-W1025 9404- 08911-20810 NUT 08915-13810 WASHER 73525 CUSHION-CENTER BEARING LB 37525-P0101
1 37000-H5100 COMP-SHAFT PROPELLER WITH JOINT SHELL AUTOMATIC 0373- 2 37000-H5100 37000-H1001 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37000-H1000 37000-H1010 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37000-H1001 37000-H1011 COMP-SHAFT PROPELLER WITH JOINT MANUAL 0972- 0 37000-H1010 37000-H3100 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37000-H1011 37000-H3100 COMP-SHAFT PROPELLER WITH JOINT SHELL MANUAL 0373- 2 37000-H1011 37000-H1101 COMP-SHAFT PROPELLER WITH JOINT AUTOMATIC 37000-H1110 COMP-SHAFT PROPELLER WITH JOINT AUTOMATIC 0671- 2 37000-H1101 37000-H1000 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37111-20300 ASSY-YOKE SLEEVE AUTOMATIC 37111-18001 ASSY-YOKE SLEEVE MANUAL 3 37117-18000 YOKE-FLANGE 4 37125-18025 ASSY-JOURNAL WITH BEARING (2) 37125-H1025 KIT-JOURNAL WITH BEARING (2) 2 37125-18025 5 37130-18000 ASSY-RACE BEARING WITH OIL SEAL (8) 37125-H1025 ASSY-RACE BEARING WITH OIL SEAL (8) AUTOMATIC 2 37130-18000 6 37147-18000 RING-SNAP BEARING RACE T=1.48 (8) 37148-18000 RING-SNAP BEARING RACE T=1.50 (8) 37149-18000 RING-SNAP BEARING RACE T=1.52 (8) 37146-18000 RING-SNAP BEARING RACE T=1.46 (8) 7 08120-82210 BOLT-HEX M8X1.25 (4) 01111-00061 BOLT-FIX PROPELLER SHAFT (4) AUTOMATIC 2 08120-82210 01111-00151 BOLT-FIX PROPELLER SHAFT (4) 3N71B 0371- 2 01111-00061 8 08911-20810 NUT-HEX M8X1.25 (4) 9 08915-13810 WASHER-LOCK M8 (4)
1973 LB110 USA Parts Catalog, page 56-1
