Also see:
Part Numbers Index Main articless for usage, photos, cross-reference Floor Trunk (boot) Jack
Front Floor
FRONT FLOOR PANEL USA/JAPAN, COUPE/SEDAN/VAN
41 FRONT FLOOR
74300-H1000 3 SPEED
74300-H1010 4 SPEED
74300-H1021 AUTOMATIC
42 74310-H1000 CROSS MEMBER-FRONT SEAT RH
43 74311-H1000 CROSS MEMBER-FRONT SEAT LH
74311-H1400 Van RHD
44 74314-H1001 BRACKET-FRONT SEAT INSIDE RH
45 74315-H1000 BRACKET-FRONT SEAT INSIDE LH
46 74316-H1000 BRACKET-FRONT SEAT OUTSIDE RH
47 74317-H1000 BRACKET-FRONT SEAT OUTSIDE LH
48 74320-H1000 FLOOR SIDE RH
49 74321-H1000 FLOOR SIDE LH
50 74810-H1001 ASSY-MEMBER SIDE FRONT RH
51 74811-H1001 ASSY-MEMBER SIDE FRONT LH
52 54532-H1001 BRACKET-TENSION ROD RH
53 54533-H1001 BRACKET-TENSION ROD LH
54 74800-H1000 ASSY-MEMBER CROSS FRONT
Rear Floor Coupe
REAR FLOOR PANEL (COUPE) 54 74500-H1801 FLOOR ASS'Y-rear 74500-H1800 to '70-Dec <x> 74500-H1801 55 84122-H1800 BRACKET-rear seat side 2 56 74860-H1000 CROSS MEMBER, rear seat, lower 57 74870-H1800 CROSS MEMBER, shock absorber 58 74882-H1800 CROSS MEMBER, rear end 59 74850-H2501 SIDE MEMBER, rear RH <> 74850-H1800 60 74851-H1800 SIDE MEMBER, rear LH 61 55208-H1000 BRACKET, shackle 2 62 84106-H1800 BRACKET, trunk trim, side rear 2 63 74528-H1800 REINFORCEMENT-bumper stay, rear 2
Truck
FLOOR PANEL
41 74300 FRONT FLOOR
74300-G1401 7510-7803
74300-G1160 7804-8808
74300-G1950 8809-8910
74300-95W00 8910-
42 74340 MEMBER-FRONT SEAT MOUNTING RH
74310-H1000 7510-8904
74330-95W00 8904-
43 74341 MEMBER-FRONT SEAT MOUNTING LH
74311-H1000 7510-8904
74331-95W00 8904-
74515 BRACKET-JACK MOUNTING
99602-H1400
44 74352M BRACKET-FRONT SEAT MOUNING, INNER RH
74314-H1001 8910-
45 74353M BRACKET-FRONT SEAT MOUNTING, INNER LH
74315-H1000 8910-
46 74352 BRACKET-FRONT SEAT MOUNTING, OUTER RH
74316-H1000 8910-
47 754353 BRACKET-FRONT SEAT MOUNTING, OUTER LH
74317-H1000 8910-
48 74320-G1000 INNER SILL RH
49 74321-G1000 INNER SILL LH
50 74802 MEMBER-SIDE, FRONT RH
74810-G1600 7510-7803 <x> 74810-G1601
74810-G1601 7804-8910
74810-G1900 8910-
51 74803 MEMBER-SIDE, FRONT LH
74811-G1601 7510-8503 <> 74811-H1001
74811-H1001 8504-8910
74811-G1900 8910-
52 74830 BRACKET-SUSPENSION ROD RH
54532-H1001
53 74831 BRACKET-SUSPENSION ROD LH
54533-H1001
54 74820 MEMBER-CROSS, FRONT
74800-H1000
74823 HOOK-FRONT RH
62682-H7000 7510-8503
62632-G1200 8504-
74824 HOOK-FRONT LH
62683-H7000 7510-8503
62633-G1200 8504-
8910- ONLY
74301A 74398-95W00 BOLT-PLATE 2
74301J 74354-95W00 REINFORCE-HAND BRAKE & SEAT BELT
74318 74306-G1001 REINFORCE BODY MOUNTING RH
74319 74307-G1001 REINFORCE BODY MOUNTING LH
74347 BRACKET-REAR ENGINE MOUNTING
74331-H1000 LEFT
74362-95W00 RIGHT
74510E 01551-00063 CLIP 2
74514A 74352-H1000 PLATE-BOLT
74810 BOARD-SPLASH SHIELD 62611-H1000 7510-8004 <2,0> F2611-H1000 F2611-H1000 8005-8503 62611-H1000 8504-8910 08630-61226 SCREW 4
FRONT FLOOR TRIMMING
SPARE WHEEL HANGER 1 57210-G1000 HANGER ASS'Y-spare wheel -8503 <2,0> 57210-G1900 57210-G1900 CARRIER-SPARE TIRE 8504- 2 57211-H1400 BOLT-clamp [57210A] 3 57212-H1400 SUPPORT-BOLT CLAMP 4 08915-53810 WASHER-plain 5 00840-81610 PIN-clevis <> 36407-00100 36407-00100 PIN-CLEVIS [57212A] 6 00921-21810 PIN-cotter 3 7 00840-83010 PIN-clevis 2
Sedan
1 74300-H1021 ASSY-FLOOR FRONT SEDAN AUTOMATIC 1 74300-H1010 ASSY-FLOOR FRONT SEDAN 4 SPEED 2 74310-H1000 ASSY-MEMBER CROSS FRONT SEATRH SEDAN 3 74311-H1000 ASSY-MEMBER CROSS FRONT SEATLH SEDAN 4 74314-H1000 BRACKET-FRONT SEAT INSIDE RH SEDAN 4 74314-H1001 BRACKET-FRONT SEAT INSIDE RH SEDAN 5 74315-H1000 BRACKET-FRONT SEAT INSIDE LH SEDAN 6 74316-H1000 BRACKET-FRONT SEAT OUTSIDE RH SEDAN 7 74317-H1000 BRACKET-FRONT SEAT OUTSIDE LH SEDAN 8 74320-H1000 ASSY-FLOOR SIDE RH SEDAN 9 74321-H1000 ASSY-FLOOR SIDE LH SEDAN 10 74500-H7000 ASSY-FLOOR REAR SEDAN 0772- 10 74500-H1000 ASSY-FLOOR REAR SEDAN 10 74500-H2800 ASSY-FLOOR REAR SEDAN 11 74528-H1000 REINFORCEMENT-BUMPER STAY REAR SEDAN 11 74528-H7000 REINFORCEMENT-BUMPER STAY REAR SEDAN 0772- 12 74860-H1000 ASSY-MEMBER CROSS REAR SEAT LOW SEDAN 13 74850-H1000 ASSY-MEMBER SIDE REAR RH SEDAN 14 74851-H1000 ASSY-MEMBER SIDE REAR LH SEDAN 15 55208-H1000 ASSY-BRACKET SHACKLE SEDAN 16 74810-H1001 ASSY-MEMBER SIDE FRONT RH SEDAN 17 74811-H1001 ASSY-MEMBER SIDE FRONT LH SEDAN 18 54532-H1001 ASSY-BRACKET TENSION ROD RH SEDAN 19 54533-H1001 ASSY-BRACKET TENSION ROD LH SEDAN 20 74800-H1000 ASSY-MEMBER CROSS FRONT SEDAN 21 74933-H1000 INSULATOR-TUNNEL FRONT SEDAN MANUAL 22 74933-H1020 INSULATOR-FLOOR COVER SEDAN AUTO 23 74931-H1000 INSULATOR-FLOOR FRONT RH SEDAN 24 74932-H1000 INSULATOR-FLOOR FRONT LH SEDAN 25 74934-H1000 INSULATOR-FLOOR,REAR,RH (2) SEDAN (DX) 26 74934-H1025 SET-INSULATOR FLOOR REAR RH SEDAN (DX) 0570- G5930-89902 INSULATOR-FLOOR FRONT LH SEDAN 27 74937-H1000 INSULATOR-TUNNEL REAR SEDAN (DX) 28 74965-H1000 BOOTS-HAND BRAKE SEDAN (DX) 28 74965-H7300 BOOTS-HAND BRAKE SEDAN (DX) 29 74936-H1000 INSULATOR-REAR SEAT LOWER SEDAN(DX) 29 G5930-89902 INSULATOR-REAR SEAT LOWER SEDAN(DX) 30 01658-00041 PLUG-RUBBER 39 (4) SEDAN 30 01658-00021 PLUG-RUBBER 25 FRONT FLOOR HOLE (4) SEDAN 31 57210-18000 HANDLE-SPARE WHEEL CLAMP SEDAN 31 74630-21002 HANDLE-SPARE WHEEL CLAMP SEDAN 0171- 32 84905-H1900 ASSY-COVER SPARE TIRE OP SEDAN 1270- 32 84905-H7000 ASSY-COVER SPARE TIPE SEDAN 0772- 33 74365-73000 PLUG-ANCHURAGE HOLE (4) SEDAN 34 74963-20900 BOOT-CONTROL LEVER SEDAN 4 SPEED 35 32021-35000 PLUG-INSPECTION HOLE SEDAN 36 74882-H1000 MEMBER-CROSS READ END SEDAN
Coupe
1 74300-H1021 ASSY-FLOOR,FRONT COUPE,AUTOMATIC 1 74300-H1010 ASSY-FLOOR FRONT COUPE,MANUAL 2 74310-H1000 ASSY-MEMBER CROSS FRONT SEATRH COUPE 3 74311-H1000 ASSY-MEMBER CROSS FRONT SEATLH COUPE 4 74314-H1000 BRACKET-FRONT SEAT INSIDE RH COUPE 4 74314-H1001 BRACKET-FRONT SEAT INSIDE RH COUPE 2 74314-H1000 5 74315-H1000 BRACKET-FRONT SEAT INSIDE LH COUPE 6 74316-H1000 BRACKET-FRONT SEAT OUTSIDE RH COUPE 7 74317-H1000 BRACKET-FRONT SEAT OUTSIDE LH COUPE 8 74320-H1000 ASSY-FLOOR SIDE RH COUPE 9 74321-H1000 ASSY-FLOOR SIDE LH COUPE 10 74500-H1800 ASSY-FLOOR REAR COUPE 10 74500-H1905 ASSY-FLOOR REAR COUPE 0171- 10 74500-H1906 ASSY-FLOOK REAR COUPE 2 74500-H1905 10 74500-H7100 ASSY-FLOOR REAR COUPE 0772- 0 74500-H1906 11 74528-H1800 REINFORCEMENT-BUMPER STAY REAR (2) COUPE 12 84122-H1800 BRACKET-SEAT REAR SIDE (2) COUPE 13 74860-H1000 ASSY-MEMBER CROSS REAR SEAT LOWER COUPE 14 74870-H1800 ASSY-MEMBER CROSS SHOCK ABSORBER COUPE 15 74882-H1800 MEMBER-CROSS REAR END COUPE 16 74850-H1800 ASSY-MEMBER SIDE REAR RH COUPE 16 74850-H2501 ASSY-MEMBER SIDE REAR RH COUPE 2 74850-H1800 17 74851-H1800 ASSY-MEMBER SIDE REAR LH COUPE 18 55208-H1000 ASSY-BRACKET SHACKLE RH COUPE 19 55208-H1800 ASSY-BRACKET SHACKLE LH COUPE 20 84106-H1800 BRACKET-TRUNK ROOM TRIM REARSIDE (2) COUPE 21 74810-H1001 ASSY-MEMBER SIDE FRONT RH COUPE 22 74811-H1001 ASSY-MEMBER SIDE FRONT LH COUPE 23 54532-H1001 ASSY-BRACKET TENSION ROD RH COUPE 24 54533-H1001 ASSY-BRACKET TENSION ROD LH COUPE 25 74800-H1000 ASSY-MEMBER CROSS FRONT COUPE 26 74933-H1000 INSULATOR-TUNNEL FRONT COUPE,MANUAL 26 74933-H1020 INSULATOR-TUNNEL,FRONT COUPE,AUTOMATIC 27 74931-H1000 INSULATOR-FLOOR FRONT RH COUPE 28 74932-H1000 INSULATOR-FLOOR FRONT LH COUPE 29 74934-H1000 INSULATOR-FLOOR REAR (2) COUPE 30 74934-H1025 SET-INSULATOR FLOOR REAR RH COUPE 0570- 2 74934-H1000 31 74937-H1000 INSULATOR-TUNNEL REAR COUPE 32 74965-H1000 BOOT-HAND BRAKE COUPE 33 74936-H1000 INSULATOR-REAR SEAL LOWER COUPE 34 84124-H1801 BRACKET-FUEL TANK MOUNTING RH COUPE 35 01658-00021 PLUG-RUBBER 25D (4) COUPE 35 01658-00041 PLUG-RUBBER 39D (4) COUPE 0 01658-00021 36 57210-18000 HANDLE-SPARE WHEEL CLAMP COUPE 36 74630-21002 HANDLE-SPARE WHEEL CLAMP COUPE 0171- 0 57210-18000 37 99606-H1800 CLAMP-JACK HANDLE (2) COUPE 38 74962-H1905 PROTECTOR-BREATHER TUBE COUPE 39 74365-73000 PLUG-ANCHORAGE (2) COUPE 40 74963-20900 BOOT-CONTROL LEVER COUPE 41 32021-35000 PLUG-INSPECTION HOLE 55D COUPE 42 74891-H2500 ASSY-COVER INSPECTION HOLE COUPE 43 08510-61212 SCREW (6) COUPE
