Steering Linkage Part Numbers
Revision as of 04:38, 4 September 2017; view current revision
Categories: Steering System | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
Steering Linkage
STEERING LINKAGE
 1 48530-H1000 IDLER ASS'Y-steering
 2 48551-H1000  ARM-idler-steering (ARM-PITMAN)
 3 48544-H1000  BUSHING-idler, upper 2
 4 48541-H1000  WASHER-idler, upper
 5 08912-44210  NUT
   fixing idler to frame
   6 48362-H1000 BOLT 2
   7 08915-53810 WASHER-plain 2
   8 48366-H1000 NUT 2
 9 48502-H1000 ARM-steering gear
   fixing steering gear arm
   10 08911-24610 NUT
   11 08915-14610 WASHER-lock
12 48560-H1000 ROD ASS'Y-cross
13 48522-H1001  COVER-dust, cross rod 2 -8910
   48522-G1500 8910- <> 48522-H1001
14 48526-18000  CLAMP-dust cover 2
15 40189-73000  PLUG-filler 2
16 48577-H1001  SEAL-dust, idler arm
17 08921-32010  PIN-cotter 2
18 01227-00011  NUT 2 -8503
   01227-00091  NUT 2 8504-
19 48510-H1001 ROD ASS'Y-side (R.H.) (up to '72-9)
   48510-H1002 ROD ASS'Y-side (R.H.) (from '72-10) <x*> 48510-H1001
   * Replacement only as a set
20 48630-H1001 ROD ASS'Y-side (L.H.) (up to '72-9)
   48630-H1002 ROD ASS'Y-side (L.H.) (from '72-10) <x*> 48630-H1001
   Up to '72-9, each side rod assembly include separate parts:
     21 48520-H1001 SOCKET ASS'Y-side rod, outer (R.H.)
     22 48521-H1001 SOCKET ASS'Y-side rod, inner (R.H.)
     23 48640-H1001 SOCKET ASS'Y-side rod, outer (L.H.)
     24 48641-H1001 SOCKET ASS'Y-side rod, inner (L.H.)
     25 48522-H1001  COVER-dust, side rod 2
     26 48526-18000  CLAMP-dust cover 2
     27 40189-73000  PLUG-filler 2
     28 01227-00011  NUT 2
     29 08921-32010  PIN-cotter 2
     30 48512-H1001 BAR-side rod 2
     31 01211-00011 NUT-lock, side rod (R.H.) 2
     32 01211-00021 NUT-lock, side rod (L.H.) 2
33 48510-H1025 ROD KIT-side (R.H.) (from '72-10)
34 48630-H1025 ROD KIT-side (L.H.) (from '72-10)
35 01227-00011 NUT (from '72-10) 4
   01227-00091 NUT  8504- 4
36 08921-32010 PIN-cotter (from '72-10) 4
1 48510-H1025 KIT-ROD SIDE RH 1072- 2 48510-H1002
1 48510-H1001 ASSY-ROD SIDE RH
1 48510-H1002 ASSY-ROD SIDE RH 1072- 6 48510-H1001
2 48520-H1001 ASSY-SOCKET SIDE ROD RH OUTER
3 48521-H1001 ASSY-SOCKET SIDE ROD RH INNER
4 48522-H1001 COVER-DUST SIDE ROD (2)
5 48526-18000 CLAMP-DUST COVER (2)
6 40189-73000 PLUG-FILLER (2)
7 01227-00011 NUT-HEX SLOTTED (3)
8 08921-32010 PIN-COTTER 3.2X20 (2)
9 48512-H1001 BAR-SIDE ROD
10 01211-00011 NUT-LOCK SIDE ROD RH
11 01211-00021 NUT-LOCK SIDE ROD LH
12 48630-H1002 ASSY-ROD SIDE LH 1072- 6 48630-H1001
12 48630-H1025 KIT-ROD SIDE LH 1072- 2 48630-H1002
12 48630-H1001 ASSY-ROD SIDE LH
13 48640-H1001 ASSY-SOCKET SIDE ROD LH OUTER
14 48641-H1001 ASSY-SOCKET SIDE ROD LH INNER
15 01211-00021 NUT-LOCK SIDE LH
16 48526-18000 CLAMP-DUST COVER (2)
17 40189-73000 PLUG-FILLER (2)
18 01227-00011 NUT-HEX SLOTTED (2)
19 08921-32010 PIN-COTTER 3.2X20 (2)
20 48512-H1001 BAR-SIDE ROD
21 01211-00011 NUT-LOCK SIDE RH
22 48530-H1600 ASSY-IDLER STEERING
23 48551-H1000 ARM-IDLER STEERING
24 48544-H1000 BUSH-IDLER (2)
25 48541-H1000 WASHER-IDLER UPPER
26 54324-21000 NUT-HEX SELF LOCK
26 54324-N0100 NUT-HEX SELF LOCK 2 54324-21000
27 48362-H1000 BOLT IDLER FIX TO FRAME (2)
28 08915-53810 WASHER-PLAIN M8 IDLER FIX TO FRAME (2)
29 48366-H1000 NUT IDLER FIX TO FRAME (2)
30 48560-H1600 ASSY-CROSS ROD STEERING
31 48522-H1001 COVER-DUST CROSS ROD
32 48526-18000 CLAMP-DUST COVER
33 40189-73000 PLUG-FILLER (2)
34 48577-H1001 SEAL-DUST IDLER ARM
35 01227-00011 NUT-HEX SLOTTED (2)
36 08921-32010 PIN-COTTER 3.2X20 (2)
ARM-steering gear: see Steering Gear Part Numbers
