Bosch 021 electronic Ignition module (ignitor) is small and readily available. It allows for a high energy module conversion. It is typically used with a Pertronix points-replacement conversion kit -- the Pertonix Ignitor is not high energy. Think of the Bosch 021 as a high-power relay for low-energy ignition sensors. Or use it with a stock Datsun/Nissan electronic ignition distributor if the factory ignitor is missing or damaged. It is practically the same as GM HEI.
This ICM works with Datsun and Nissan reluctance (EI) distributors. However if you already have the stock Nissan EI unit, it's even more reliable than the Bosch unit -- so use it.
Sources
Australia-produced vehicles * 1983-1984 Series 2 Bluebird EI
ICM
BIM024 (021) module used by 1977-1996 various model engines. These modules are said to fail frequently.
- Number on Ignition Module: 9222 067 021
- Ignition Module as a retail boxed item: 9222 067 024 or BIM024
Bosch 9222067021 691 D (terminals marked 3, 7, 15, 16)
Wiring Diagram for reluctance-type electronic distributor
Terminal 3 distributor 7 distributor 15 12V 16 Coil Negative Case ground/earth
Wiring with the Datsun wire colors (example: D4F "Remote Ignitor")
Coil
It is recommended to use a high-energy coil. The standard 12V low energy coil may be used if you retain the ballast resistor
See Main Article: EI Coil
- remove ballast resistor and use 12V high energy coil (like the Bluebird EI coil). The High-Energy is in the coil. The ignitor only needs to handle enough current to power the coil.
OR
- keep the ballast resistor and use 12V low energy coil (like standard 1200 coil)
Either one will work with the Bosch module
