<-- back to Part Numbers Index
Also see: Main articles for usage, photos, cross-reference Door Cards Door Handles Weatherstripping Moulding (trim molding)
Truck
DOOR FITTING 27 80830-H1000 WEATHERSTRIP ASS'Y-door (R.H.) 27 80830-H1001 WEATHERSTRIP ASS'Y-door (R.H.) < 80830-H1000 27 80831-H1000 WEATHERSTRIP ASS'Y-door (L.H.) 27 80831-H1001 WEATHERSTRIP ASS'Y-door (R.H.) < 80830-H1001 28 80820-H1000 MOULDING ASS'Y-door outer (R.H.) 28 80820-H3100 MOULDING ASS'Y-door outer (R.H.) <> 80820-H1000 28 80821-H1000 MOULDING ASS'Y-door outer (L.H.) 28 80821-H3100 MOULDING ASS'Y-door outer (L.H.) <> 80821-H1000 29 80825-H1000 CLIP-moulding 8 30 80836-H1000 WEATHERSTRIP ASS'Y-door inside (R.H.) 30 80837-H1000 WEATHERSTRIP ASS'Y-door inside (L.H.) 31 80860-H1000 STOPPER ASS'Y-door glass 2 32 08310-61214 SCREW-with washer (fixing stopper) 2 33 80832-H1000 RUBBER-bumper, door 34 80804-H1000 SCREEN-seal, door inside -8102 2 <> 80804-G1900 80804-G1900 SCREEN-SEALING,FRONT DOOR 8103-8104 1 <5,0> 80804-G1900 80804-G1901 SCREEN-SEALING,FRONT DOOR 8105- 2 35 80840-21001 COVER-drain hole 4 36 80886-H1000 RUBBER-door cover (R.H.) 36 80887-H1000 RUBBER-door cover (L.H.)
DOOR TRIMMING 37 80900-H1000 FINISHER ASS'Y-door (R.H.) (up to '71-11) 80900-H3100 FINISHER ASS'Y-door (R.H.) (from '71-12) 80901-H3100 FINISHER ASS'Y-door (L.H.) (up to '71-11) 80901-H1000 FINISHER ASS'Y-door (L.H.) (from '71-12) 38 80919-89900 CLIP-door finisher 6 39 808929-32200 CAP-door finisher clip 6 40 80960-H1001 HANDLE-pull 2 Fixing pull handle 41 08310-62042 SCREW 4 42 08915-43642 WASHER-plain 4
SIDE VISOR 43 K5040-00037 VISOR SET-side (op.) K5040-00038 SIDE-visor (R.H.) (op.) K5040-00039 SIDE-visor (L.H.) (op.)
LATE DOOR TRIMMING
(LATE) DOOR TRIMMING フロント ダア トリミング <トリム>
80801 80912-G1900 POCKET-DOOR 8110-8910 BROWN/RH 80912-95W00 POCKET-DOOR 8910- GRAY/RH 80900 FINISHER ASSY-FRONT DOOR,RH 80900-H3100 7510-7803 BLACK 80900-G1060 7804-7907 DARK BROWN 80900-G1660 7908-8104 BROWN 80900-G1901 8105-8910 BROWN 80900-95W00 9810- GRAY
80900A CLIP-FINISHER 80919-89900 -8102 6 02809-19100 8103- 6 <> 80919-89900
80900J CAP-FINISHER CLIP 80929-32200 -8102 6
80901 FINISHER ASSY-FRONT DOOR,LH 80901-H3100 -7803 BLACK 80901-G1060 7804-7907 DARK BROWN 80901-G1660 7908-8104 BROWN 80901-G1900 8105-8910 BROWN 80901-95W00 8910- GRAY
80901F BRACKET-DOOR FINISHER 80914-95W00 8910- 2 80950 HANDLE-PULL,FRONT DOOR 80960-H1001 -7803 BLACK 2 80960-G1060 7804-7907 DARK BROWN 2 80960-G2500 7908-8910 BROWN 2 80960-95W00 8910- GRAY 2
80950A SCREW 01452-00015 9007- 2 80950C WASHER-PLAIN 01311-00155 8910-9007 2
Sedan
1 80830-H1202 ASSY-WEATERSTRIP FRONT DOOR RH SEDAN 2 DOOR 0770- 1 80830-H1200 ASSY-WEATHERSTRIP FRONT DOORRH SEDAN 2 DOOR 2 80831-H1200 ASSY-WEATHERSTRIP FRONT DOORLH SEDAN 2 DOOR 2 80831-H1202 ASSY-WEATHERSTRIP FRONT DOORLH SEDAN 2 DOOR 0770- 3 80834-H1000 SPACER-WEATHERSTRIP FRONT DOOR RH SEDAN 2 DOOR 4 80835-H1000 SPACER-WEATHERSTRIP FRONT DOOR LH SEDAN 2 DOOR 5 80820-H1200 ASSY-MOULDING FRONT DOOR OUTER RH SEDAN 2 DOOR 5 80820-H3600 ASSY-MOULDING FRONT DOOR OUTER RH SEDAN 2 DOOR 6 80821-H1200 ASSY-MOULDING FRONT DOOR OUTER LH SEDAN 2 DOOR 6 80821-H3600 ASSY-MOULDING FRONT DOOR OUTER LH SEDAN 2 DOOR 7 80825-H1000 CLIP-MOULDING DOOR OUTER (8) SEDAN 2 DOOR 8 80836-H1200 WEATHERSTRIP-FRONT DOOR INSIDE RH SEDAN 2 DOOR 9 80837-H1200 WEATHERSTRIP-FRONT DOOR INSIDE LH SEDAN 2 DOOR 10 80860-H1000 ASSY-STOPPER DOOR GLASS (2) SEDAN 2 DOOR 11 08310-61214 SCREW-MACHINE WITH SPRING WASHER M6 (2) SEDAN 2 DOOR 12 80832-H1000 RUBBER-BUMPER FRONT DOOR (2) SEDAN 2 DOOR 13 80804-H1200 SCREEN-SEAL FRONT DOOR INSIDE (2) SEDAN 2 DOOR 14 80840-21001 COVER-DRAIN HOLE (2) SEDAN 2 DOOR 15 80886-H1200 RUBBER-DOOR COVER RH SEDAN 2 DOOR 16 80887-H1200 RUBBER-DOOR COVER LH SEDAN 2 DOOR 17 80900-H7002 ASSY-FINISH,FRONT DOOR RH (BLACK,LG-13 SEDAN 2 DOOR 0173- 17 80900-H7001 ASSY-FINISH,FRONT DOOR RH (BEIGE,LH-20 SEDAN 2 DOOR 0772- 17 80900-H7000 ASSY-FINISH,FRONT DOOR RH (BLUE,LB-211 SEDAN 2 DOOR 0772- 17 80900-H1301 ASSY-FINISH,FRONT DOOR RH (YELLOW) SEDAN 2 DOOR(DX) 1270- 17 80900-H1900 ASSY-FINISH FRONT DOOR RH SEDAN 2 DOOR 18 80901-H7002 ASSY-FINISH FRONT DOOR LH (BLACK,LG-13 SEDAN 2 DOOR 0173- 18 80901-H1301 ASSY-FINISH,FRONT DOOR LH (YELLOW) SEDAN 2 DOOR (DX) 1270- 18 80901-H1900 ASSY-FINISH FRONT DOOR LH SEDAN 2 DOOR 18 80901-H7000 ASSY-FINISH FRONT DOOR LH (BLUE,LB-211 SEDAN 2 DOOR 0772- 18 80901-H7001 ASSY-FINISH FRONT DOOR LH (BEIGE,LH-20 SEDAN 2 DOOR 0772- 19 80919-89900 CLIP-DOOR FINISH (6) SEDAN 2 DOOR 20 80929-32200 CAP-DOOR FINISH CLIP (6) SEDAN 2 DOOR 21 80940-H1100 COMP-ARM REST BLACK #766 (2) SEDAN 2 DOOR (DX) 21 80940-K1002 COMP-ARM REST BLACK #766 (2) SEDAN 2 DOOR (DX) 22 08410-62012 SCREW-MACHINE M6 (4) SEDAN 2 DOOR (DX) 23 08915-13610 WASHER-PLAIN M6 (4) SEDAN 2 DOOR (DX) 24 80517-H1000 SHELD-INSIDE HANDLE (2) SEDAN 2 DOOR 1170-
Coupe
1 80830-H1202 ASSY-WEATHERSTRIP,FRONT DOOR,R.H COUPE 2 80830-H1800 1 80830-H1800 ASSY-WEATHERSTRIP FRONT DOOR RH COUPE 2 80831-H1800 ASSY-WEATHERSTRIP FRONT DOOR LH COUPE 2 80831-H1202 ASSY-WEATHERSTRIP,FRONT DOOR,L.H COUPE 2 80831-H1800 3 80834-H1000 SPACER-WEATHERSTRIP FRONT DOOR RH COUPE 4 80835-H1000 SPACER-WEATHERSTRIP FRONT DOOR LH COUPE 5 80820-H1200 ASSY-MOULDING FRONT DOOR OUTER RH COUPE 5 80820-H3600 ASSY-MOULDING FRONT DOOR OUTER RH COUPE 2 80820-H1200 6 80821-H1200 ASSY-MOULDING FRONT DOOR OUTER LH COUPE 6 80821-H3600 ASSY-MOULDING FRONT DOOR OUTER LH COUPE 2 80821-H1200 7 80825-H1000 CLIP-MOULDING DOOR OUTER (8) COUPE 8 80836-H1200 WEATHERSTRIP-FRONT DOOR INSIDE (2) COUPE 9 80860-H1000 ASSY-STOPPER DOOR GLASS (2) COUPE 10 08310-61214 SCREW-MACHINE WITH SPRING WASHER M6 (2) COUPE 11 80832-H1000 RUBBER-BUMPER FRONT DOOR (2) COUPE 12 80804-H1200 SCREEN-SEAL FRONT DOOR INSIDE (2) COUPE 13 80840-21001 COVER-DRAIN HOLE (2) COUPE 14 80886-H1200 RUBBER-DOOR COVER RH COUPE 15 80887-H1200 RUBBER-DOOR COVER LH COUPE 16 80212-H1800 ASSY-DOOR SASH LOWER RH COUPE 17 80213-H1800 ASSY-DOOR SASH LOWER LH COUPE 18 08410-61012 SCREW-MACHINE TO BODY IN SIDE FIX (4) COUPE 19 08915-13610 WASHER-SPRING LOCK TO BODY IN SIDE FIX (4) COUPE 20 80900-H1801 ASSY-FINISH,FRONT DOOR,R.H (YELLOW) OP.COUPE 20 80900-H1800 ASSY-FINISH FRONT DOOR RH BLACK #1742 COUPE 20 80900-H7101 ASSY-FINISH,FRONT DOOR,RH (BEIGE,LH-20 COUPE 0772- 20 80900-H7102 ASSY-FINISH,FRONT DOOR,RH (BLACK,LG-13 COUPE 0173- 20 80900-H7100 ASSY-FINISH FRONT DOOR RH (BLUE) COUPE 0772- 21 80901-H1800 ASSY-FINISH FRONT DOOR LH BLACK #1742 COUPE 21 80901-H7100 ASSY-FINISH FRONT DOOR LH (BLUE) COUPE 0772- 21 80901-H1801 ASSY-FINISH,FRONT DOOR,L.H (YELLOW) OP.COUPE 21 80901-H7101 ASSY-FINISH FRONT DOOR,LH (BEIGE,LH-20 COUPE 0772- 21 80901-H7102 ASSY-FINISH FRONT DOOR,LH (BLACK,LG-13 COUPE 0173- 22 80919-89900 CLIP-DOOR FINISH (8) COUPE 23 80929-32200 CAP-DOOR FINISH CLIP (8) COUPE 24 80940-H1100 COMP-ARM REST BLACK #766 (2) COUPE 25 08410-62012 SCREW-MACHINE M6 (4) COUPE 26 08915-13610 WASHER-PLAIN M6 (4) COUPE 27 80517-H1000 SHIELD-INSIDE HANDLE (2) COUPE 1170-
