Template:Test
Revision as of 08:26, 13 July 2018; view current revision
>= 480
>= 800
>= 1280
small screen
Images
Padding
Album-
9.jpgAlbum 99.jpgAlbum 99.jpgAlbum 9
mix
space character between
11.jpgAlbum 11 11.jpgAlbum 11
no space character (right, left padding)
11.jpgAlbum 1111.jpgAlbum 11
default line spacing
11.jpgAlbum 11
11.jpgAlbum 11
default top,bottom padding
11.jpgAlbum 1111.jpgAlbum 1111.jpgAlbum 11
0 top,bottom padding (class=test_pad_zero)
11.jpgAlbum click to view11.jpgAlbum click to view11.jpgAlbum click to view11.jpgAlbum click to view11.jpgAlbum click to view11.jpgAlbum click to view11.jpgAlbum click to view11.jpgAlbum click to view11.jpgAlbum click to view11.jpgAlbum 11
Album
Album Width
(Album 12.jpg is 330 x 225)
Album|12 (default, up to 400px wide, image is 330px wide)
12.jpgAlbum 12
Album|12|width=400, still shows correct 330px wide
12.jpgAlbum 12
Album|12|jpg|400, shown at 400px which makes the photo stretched, use only if you want to force a size
12.jpgAlbum 12
Arbitrary Width
forced widths, will stretch if needed (if width= is used, invalid widths will be ignored)
13.jpgAlbum 13 330x226
Album|13|jpg|400 192 120
13.jpgAlbum 13 13.jpgAlbum 13 13.jpgAlbum 13
Album|13|jpg|width=400 256 192 120
13.jpgAlbum 13 13.jpgAlbum 13 13.jpgAlbum 13 13.jpgAlbum 13
Album Width by name
Album|8580 (750 x 462)
8580.jpgAlbum 8580
Album|8580|width=XL, LG, MED, SM, TH, THUMB
8580.jpgAlbum 8580 8580.jpgAlbum 8580 8580.jpgAlbum 8580 8580.jpgAlbum 8580 8580.jpgAlbum 8580 8580.jpgAlbum 8580
Album|8580|width=MAX
8580.jpgAlbum 8580
Album Width by number
widths available: 100,THUMB(140),TH(160),SM(256),MED(400),LG(560),XL(640),MAX. blank for no-resize (imagepx class). INDEX for inheritance
Album|8580 (750 x 462) [default Album class "imagepx" (400px wide)]
8580.jpgAlbum 8580
Album|8580|width=400 256 160 140 100
Mixed Widths
mixing Class width with arbitrary width
Class width wins:
{{Album|8580|jpg|SM|width=MED}} {{Album|8580|jpg|MED|width=SM}}
placement of width irrelevant
{{Album|width=TH|8580|jpg|SM}} {{Album|8580|jpg|SM|width=TH}}
Order in CSS
/* GLOBAL WIKI styles */
  img { max-width:400px;
/* IMG general classes */
  .imageSMpx img { max-width: 256px; }
Album Width INDEX
AlbumSize
AlbumSize
No Click
PhotoTh!
Photo!
AlbumPhoto PhotoAlbum ThumbPhoto
4356.jpgAlbum click to view 4585.jpgAlbum click to view
th_4356.jpgAlbum click to view
Photo Photo! Photo-
PhotoH
PhotoPost
DSCF2788.jpgPost click for topic
PhotoTh PhotoTh! PhotoThH
PhotoTranslate
PhotoUrl (NO wrappers)
H
Height stretches to uniform height
ImgHeight 105
th_280zxt.jpg th_62143goldto.jpg 12.jpgAlbum click to view
PhotoH 166 default
ThumbH default
10.jpgAlbum click to view 101.jpgAlbum click to view 102.jpgAlbum click to view 103.jpgAlbum click to view 6499.jpgAlbum click to view 26470.jpgAlbum click to view
UploadH 200
10308_4cff4389d072d.jpgUpload click to view 14784_4d2f0d4640e8d.jpgUpload click to view
UploadH 352 (limited to 400px wide)
Pending
S13 Japan Silvia 8805-9310
[250 mm] 40206-35F01 SR20DE.2WS+CA18DE+CA18DET 8805-9310 <> 40206-35F02  [280 mm] 40206-55F01
2WS.KS+4WS 9308- <> 40206-55F03,40206-7J101,40206-73L01,40206-73L02
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaap
inlo
imageMEDpx class
helo
QUOTE
should be two paragraphs
blockquote (narrow)
Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam Laoreet dolore magna aliquam erat volutpat. Ut wisi enim ad minim veniam, quis nostrud exerci tation ullamcorper suscipit lobortis
Quote with BRs added
blockquote (class="fancy")
blockquote (class="wide")
8580.jpgAlbum 8580
QUOTE IMG
Did you know?
The Coupe came out two years after the sedan started selling
Datsun 1000 Coupe article
TOC
original TOC with 400px applied
styled TOC (UL margin affects)
current TOC
LIST
LIST IMG
All right edges should line up
8580.jpgAlbum 8580
  1. ol
    8580.jpgAlbum 8580
    ol dd
    8580.jpgAlbum 8580
Une
image100px
a
photo with link to article
image400px
Gearbox (Template:Album400R)19983.jpg
Gearbox (Template:Album)
19983.jpgAlbum 19983
dos
Old Tech Section Graphic Old Tech Section Graphic 19982.jpgAlbum click to view 1.jpgAlbum click to view 19980.jpgAlbum click to view 19982.jpgAlbum click to view 1.jpgAlbum click to view 19980.jpgAlbum click to view 19982.jpgAlbum click to view 1.jpgAlbum click to view 19980.jpgAlbum click to view
hello world
Album
Album
tres
19983.jpg 19984.jpg 8580.jpgAlbum 8580
next line
Force
Template:Album
12.jpgAlbum 12 14.jpgAlbum 14 13.jpgAlbum 13 15.jpgAlbum 15
op
Quin
12.jpgAlbum 12
next line
1
1
1
1
1 next line
1
1
1
float right is after this line
last line
Seis
Column
GMREADME.TXT Copyright (c) 1998-2000 Microsoft Corporation. All Rights Reserved.
The GM.DLS file contains the Roland SoundCanvas Sound Set which is protected under the following copyright: Roland GS Sound Set/Microsoft (P) 1996 Roland Corporation U.S. The Roland SoundCanvas Sound Set is licensed under Microsoft's End User License Agreement for use with Microsoft operating system products only. All other uses require a separate written license from Roland.
