Fuel Sender
Revision as of 12:07, 31 July 2018; view current revision
Category: Fuel System
The fuel level 'sender' is the sensor in the tank. It does not incorporate a fuel line, although the coupe sensor has a fuel vent fitting. For the fuel outlet line, see Fuel tank.
To remove the sender, only a screwdriver and hammer is needed. Carefully drive the Lock Plate (retaining ring) anti-clockwise until loose.
26610.jpgAlbum 26610
All use same 2.5" O-ring and lock plate, including B10 and B120 through B310:
17342-18000 O-ring
17343-14800 Lock plate (also 17343-14801)
  • Coupe has a vent fitting on it (non-EVAPO
  • Coupe has no vent fitting (EVAPO models)
19019.jpgAlbum 19019
B110 Sedan USA & JDM
25060-H1000 GAUGE-FUEL TANK
25060-H1900 1070-
B110 Coupe USA & JDM
25060-H1800
B110 Van JDM
25060-H1400
B120 JDM
25060-G1000 7510-8111 GAUGE-fuel tank [bullet connector]
20560-G1010 8112- [multi-connector]
B210 Sedan USA & JDM
25060-H5000
B210 Coupe USA & JDM
25060-H5500
25060-H7210 0974-
B210 Van JDM
25060-H6600
B310 USA Sedan, Coupe, Wagon USA, early JDM
25060-H8500 GAUGE ASSY-FUEL TANK
Sedan
25060-H1900 GAUGE (sender)
174_5b349e8c2d883.jpgPost 488733
13983.jpgAlbum 13983 24471.jpgAlbum 24471 24470.jpgAlbum 24470
Truck
19044.jpgAlbum 19044 24466.jpgAlbum 24466 24469.jpgAlbum 24469 sender_a.jpg sender_b.jpg sender_c.jpg 174_5a35fe62c9cfb.jpgPost click for topic
120Y Coupe
24472.jpgAlbum 24472
B310 Van
There is a single Yellow wire on the sender. It goes forward to the dash Fuel Gauge. This wire is grounded through the sender resistance.
See main article: Fuel Gauge Wiring
Sender Specifications
As measured by club members, by moving the float up and down from stop to stop:
NOTE: This does not necessarily match "Full" and "Empty" marks of the fuel gauge, due to normal manufacturing tolerances. Typically a 1200 reads well 'E' before it runs out of fuel, this is normal.
Reference: Forum: Fuel sending unit specs
Fuel Gauge Specifications
From the 1973 Datsun 1200 Factory Service Manual
Ohms Mark
35   Half
Stock Fuel level gauge, ss measured by club members:
* Empty mark: 73-88 ohms input
* Full mark: 12 ohms
ang94541 uses an aftermarket Autometer 3515, which seems to match the Nissan sender. It is designed for the 1965-1985 Ford senders. Also used by Chrysler and VW beetle (73-10 ohm gauge).
* 3515 Empty mark: 73 ohms
* 3515 Full mark: 10 ohms
