Manifold
Revision as of 00:51, 2 November 2019; view current revision
Category: Engine Mechanical
Also See
Port Sizes
Intake Manifold
Exhaust Manifold
Aftermarket manifold for SUs, Webers, etc.
EFI Manifold
Turbo exhaust manifolds
Headers/Extractors
Flanges
http://www.kemotorsport.com Datsun A-series Flanges round/oval $65set posted
CAD files
NOTE: The ports in the CAD files are extra large
NOTE2: There are RH and LH versions of the flanges
18181_572789971c0a6.jpgPost 477629 174_5dbcb25753f4b.jpgPost 492986
Dimensionalized Prints
NOTE: The port sizes are extra large in these prints.
Dimensionalized prints of the port and bolt-hole locations can be found POST here
18181_572789a94049c.jpgPost 477629
18181_5727a314cd555.jpgPost 478554 18181_5727a327e7f62.jpgPost 478554
Left/Right Differences
18181_572789bc5c5f4.jpgPost 478551
the intake bolt spacing is opposite between 1-2 and 3-4
The_Engine_Room
18181_572789900b7f0.jpgPost 478551 18181_572789971c0a6.jpgPost 478551 18181_572789a94049c.jpgPost 478551 18181_572789c6e3837.jpgPost 478551 18181_572789d028be7.jpgPost 478551 18181_572789dfa0839.jpgPost 478551 18181_572789e6a1f6e.jpgPost 478551
Studs
MANIFOLD
08911-10810 NUT CYLINDER HEAD TO MANIFOLD  [M8] (9)
08915-13810 WASHER-LOCK [M8] (9)
New-style (all A14/A15 and A12.7908-) take 2 additional
  • Note: the bottom row of nuts is normally not visible
  • Old-style Manifold 5 bolts across the top
  • new-style Manifold 7 bolts across the top
9764_4a2e45a04b14c.jpgUpload click to view
Stud Length
* 28 mm
1 45mm (EGI manifold)
2 40mm (EGI manifold)
STUDS
08213-82810 STUD-MANIFOLD M8 x 28 (9)
B120 7808- (new style)
  08223-82810 M8 x 28 top(first, middle, last) bottom(first, last) (5)
  08223-83510 M8 x 35 top(second)
  08223-83210 M8 x 32 top(third, fifth) (2)
    08223-82810 M8 x 28 8910-
  08223-84010 M8 x 40 top(sixth)
    08223-83510 M8 x 35 8910-
  08223-82810 M8 x 28 bottom(middle two) (2)
    14065-W1300 8910-
NOTE: non-1200 manifolds take differing numbers and lengths of studs
