Head Part Numbers
From Datsun 1200 Club
Categories: Engine Mechanical | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Cylinder Heads
Rocker Cover
Thermostat
1 11041-H3900 ASSY-HEAD,CYLINDER A12 0671-1272 22 11041-H1001
1 11041-H3901 ASSY-HEAD CYLINDER A12 0173-0273 32 11041-H3900
1 11041-H3902 ASSY-HEAD CYLINDER A12 0373- 2 11041-H3901
 11041-H3903 ASSY-HEAD CYLINDER A12 0373- 2 11041-H3902
1 11041-H1001 ASSY-HEAD CYLINDER A12 -571 1
2 13212-H0110 GUIDE-VALVE INTAKE (4) A12
2 13212-H0111 GUIDE-VALVE INTAKE (4) A12 2 13212-H0110
3 13213-H0110 GUIDE-VALVE EXHAUST (4) A12
3 13213-H0111 GUIDE-VALVE EXHAUST (4) A12 2 13213-H0110
4 11098-18011 INSERT-VALVE SEAT INTAKE (4) A12
4 11098-18012 11098-H101211098-18011
  11098-H1012 INSERT-VALVE SEAT INTAKE (4) A12
5 11099-18010 INSERT-VALVE SEAT EXHAUST (4) A12
5 11099-H1010 INSERT-VALVE SEAT,EXHAUST (4) A12 -273 32 11099-18010
  11099-M0111 INSERT-VALVE SEAT,EXHAUST (4) A12
6 00933-20650 PLUG-TAPER (2) A12
6 01647-00011 PLUG-TAPER (2) A12 2 00933-20650
 00933-1401A PLUG-WELCH A12 00933-14000
7 00933-14000 PLUG-WELCH A12
 14065-B8600 STUD-MANIFOLD M8 (4) A12 08213-82510
8 08213-82510 STUD-MANIFOLD M8 (4) A12
9 08213-82810 STUD-MANIFOLD M8 (5) A12
10 11051-73403 PLUG-BLIND CYLINDER HEAD (4) A12
11 13214-73400 RING-SNAP VALVE GUIDE (8) A12
12 00931-30610 PLUG-HEATER OUTLET HOLE A12
13 11044-18004 GASKET-CYLINDER HEAD A12
13 11044-H1000 GASKET-CYLINDER HEAD A12 2 11044-18004
13 11044-H3900 GASKET-CYLINDER HEAD A12 0671- 0 11044-H1000
13 11044-H3925 KIT-GASKET,CYLINDER HEAD A12 0672- 2 11044-H3900
14 11045-H1000 RING-OIL,OIL GALLERY A12 0672-
15 11056-H1000 BOLT-FIXING CYLINDER HEAD (9) A12 1272- 2 11056-18001
15 11056-18001 BOLT-FIXING CYLINDER HEAD (9) A12
16 11057-18000 BOLT-FIXING CYLINDER HEAD A12
16 11057-H1000 BOLT-FIXING CYLINDER HEAD A12 1272- 2 11057-18000
17 11058-18000 WASHER-LOCK FIXING CYLINDER HEAD 1 (10) A12
17 11058-H1000 WASHER-LOCK FIXING CYLINDER HEAD 1 (10) A12 0172- 2 11058-18000
18 10005-H1000 SLINGER-ENGINE FRONT A12
19 13264-H1000 ASSY-COVER VALVE ROCKER A12
19 13264-H7000 ASSY-COVER,VALVE ROCKER A12 0772- 0 13264-H1000
20 08915-13610 WASHER-LOCK FIXING ROCKER COVER (6) A12
 08360-61612 SCREW-MACHINE FIXING ROCKER COVER (6) A12 08310-61612
21 08310-61612 SCREW-MACHINE FIXING ROCKER COVER (6) A12
 15255-B3430 CAP-OIL FILLER A12 15255-15953
22 15255-15953 CAP-OIL FILLER A12
23 15270-B3400 PACKING-OIL FILLER CAP A12 2 15270-11200
23 15270-11200 PACKING-OIL FILLER CAP A12
24 13270-18001 PACKING-ROCKER COVER A12
25 21200-A3001 ASSY-THERMOSTAT 82C A12 EXHAUST & EVAPO
25 21200-A3005 ASSY-THERMOSTAT 88C FOR WINTER OP A12
25 21200-78502 ASSY-THERMOSTAT 76.5C FOR TROPICAL USE OP A12
25 21200-78500 ASSY-THERMOSTAT 82C A12 CRANK
26 11060-G0300 OUTLET-WATER A12 AUTOMATIC
26 11060-G0300 OUTLET-WATER A12 MANUAL -273 3
26 11060-H7000 OUTLET-WATER A12 MANUAL 0373- 0 11060-G0300
 11062-58000 WASHER-JOINT WATER OUTLET [gasket] A12 11062-18000
27 11062-18000 WASHER-JOINT WATER OUTLET [gasket] A12
28 31139-49006 BOLT-HEX M8 (2) A12
 08915-1381A WASHER-SPRING (2) A12 08915-13810
29 08915-13810 WASHER-SPRING (2) A12
30 22120-U2001 ASSY-SWITCH WATER TEMP A12 MANUAL 0373-
31 24200-H7000 CLIP-SWITCH HARNESS A12 MANUAL 0373-
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Head_Part_Numbers"
This page has been accessed 696 times. This page was last modified 01:21, 3 October 2012. Content is available under Datsun 1200 Club.
