Kick Panel
Revision as of 13:30, 20 May 2021; view current revision
Categories: Fibreglass | Interior
The Dash Side Trimming covers the side of the foot well, just forward of the front doors. These are popularly called "Kick Panels". The factory right and left speakers are mounted on the kick panel.
13444.jpgAlbum 13444
  • The panels have a cut-out area for the (optional) speaker, which can easily be broken out and discarded in order to fit the speaker.
  • There is also a kidney-shaped/triangular plug in each panel, which gives access to the lower Door Hinge bolts. The plug differs RH to LH.
  • panels and plugs came in Black (early 1200), Brown (1978-1988) and Gray (1989-up)
287.jpgAlbum 287 3745.jpgAlbum 3745 10150.jpgAlbum 10150 10808.jpgAlbum 10808
Flare
For the Japan market, the Emergency Signal flare was mounted to the kick panel:
20573.jpgAlbum 20573 24033.jpgAlbum 24033
ハイフレヤ High Flare
174_57e1bdfbc21f1.jpgPost 481371
Nissan 26890-89900 Red Fuse
Effective date 1981 January
End date 1982 February 5
25617.jpgAlbum 25617
Holder
26885-89900 HOLDER-lamp -7301
26895-89900 HOLDER-EMERGENCY SIGNAL 7302- [26885N]
ハツエントウ Warning Flare
Custom
Carbon Fibre kick panels have been made.
13222.jpgAlbum 13222
Kick panels with designed speaker enclosure:
7310.jpgAlbum 7310
Covering with fabric:
23388.jpgAlbum 23388
Dash Part Numbers
NOTE: the kick panel is called 'Dash Trim' later 'Dash Side Finisher'
  • 66900-H1001 TRIM-DASH SIDE RH
  • 66900-H1101 TRIM-DASH SIDE RH -7803 Black
  • 66901-H1601 TRIM-DASH SIDE LH -7803 Black
  • 66901-H1901 TRIM-DASH SIDE LH
  • 66901-G1060 FINISHER-DASH SIDE, RH 7804-8910 BROWN
  • 66901-95W00 FINISHER-DASH SIDE, RH 8910- GRAY
  • 66900-G1060 FINISHER-DASH SIDE, LH 7804-8910 BROWN
    23389.jpgAlbum click to view
  • 66900-95W00 FINISHER-DASH SIDE, LH 8910- GRAY
    • 08540-41012 SCREW-TAPPING (4)
    • 08915-43420 WASHER-PLAIN (4)
  • 08410-61212 SCREW-MACHINE
  • 08410-61220 SCREW-MACHINE
  • 36528-22500 WASHER-PLAIN
  • 66904-H1001 PLUG-DASH SIDE RH -7803 [black]
  • 66905-H1001 PLUG-DASH SIDE LH -7803 [black]
  • 64891-W5000 PLUG 7804- D=30
  • 66919-H1001 CLIP-trimming -7804 (6) BLACK
  • 66919-G1060 CLIP-trimming 7804-8910 (6) BROWN
  • 66919-95W00 CLIP-trimming 8910- (6) GRAY
23356.jpgAlbum 23356
サイド トリム
