ARP bolt kits are popular for the A-series engine.
Rod Bolts
ARP Rod Bolts: See Rod Studs
Cylinder Head Studs
ARP cylinder head studs & nuts replace the stock Head Bolts and are tightened to 60 ft. lbs.
* 202-4202 (early A12) * 202-4203 (A14)
NOTE: 1974-up A12 and A14 use the same center (long) head bolt. So:
- use #202-4202ᴳ (A12) for early engines A10 and pre-1974 A12
 - use #202-4203ᴳ (A14) for all late engines, including late A12, A12A, A13, A14, A15
* ARP Web Site for early A12
ARP 202-4203 for late A12/A14/A15 has one long stud
Main Bearing Caps
ARP 202-5401a main bolt kit Kameari Engine Works 202-5401A
Compare to Nissan Bolts * 12293-18001 BOLT FIXING BEARING CAP (10) SEE Engine_block#Main_Bearing_Caps * A10/A12/A14/A15 * L20/L24/L28 * L16/L18/L20B * Z24E/Z24S/Z24I engines * KA24E * E15/E16
