<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference Carburetor
From June 1971 with Auto Choke
1 16010-H3901 ASSY-CARBURETOR (DCH306-1A) MANUAL 2 16010-H3900 1 16010-H3902 ASSY-CARBURETOR (DCH306-1B) MANUAL -672 2 16010-H3901 1 16010-H7000 ASSY-CARBURETOR (DCH306-4) MANUAL 0772- 0 16010-H3902 1 16010-H3920 ASSY-CARBURETOR (DCH306-3) AUTO 1 16010-H3921 ASSY-CARBURETOR (DCH306-3A) AUTO 2 16010-H3920 1 16010-H3922 ASSY-CARBURETOR (DCH306-3B) AUTO -672 2 16010-H3921 1 16010-H7100 ASSY-CARBURETOR (DCH306-5) AUTO 0772- 0 16010-H3900 1 16010-H3900 ASSY-CARBURETOR (DCH306-1) MANUAL 2 16011-H7011 ASSY-CHAMBER,CHOKE MANUAL 0772- 0 16011-H3910 2 16011-H3920 ASSY-CHAMBER,CHOKE AUTO -672 2 16011-H3910 ASSY-CHAMBER,CHOKE MANUAL -672 2 16011-H7111 ASSY-CHAMBER,CHOKE AUTO 0772- 0 16011-H3920 3 16182-H3920 POT-DASH AUTO 4 16302-H3910 LEVER-PUMP 5 16258-H3920 HOLDER-DASH POT AUTO 6 16143-H3910 ROD-PUMP 7 16262-H3910 DIAPHRAGM-SERVO 8 16118-H3910 ASSY-CHAMBER,THROTTLE 8 16118-H3911 ASSY-CHAMBER,THROTTLE -672 2 16118-H3910 8 16118-H7011 ASSY-CHAMBER,THROTTLE 0772- 0 16118-H3911 9 16145-91460 SPRING-IDLE ADJUST SCREW 10 16145-50000 SPRING-THROTTLE ADJUST SCREW 11 16129-25710 SCREW-THROTTLE ADJUST 11 16129-25715 SCREW-THROTTLE ADJUST -672 2 16129-25710 11 16114-H7010 SCREW-THROTTLE ADJUST 0772- 0 16129-25715 12 16144-M0110 SCREW-IDLE ADJUST -672 12 16144-H7010 SCREW-IDLE ADJUST 0772- 0 16144-M0110 13 16147-E6600 CAP-IDLE LIMITTEY 1070-0672 14 16082-H3910 PLATE-ADJUST -672 14 16082-H7010 PLATE-ADJUST 0772- 0 16082-H3910 15 16116-H3910 SLEEVE(B) 16 16128-H3910 LEVER-FIRST IDLE 17 16249-H3910 LEVER-OPENER 18 16389-H7010 COVER-THERMO 0772- 0 16389-H3910 18 16389-H3910 COVER-THERMO -672 19 16267-H3910 PIPE-VACUUM MANUAL 19 16267-H3920 PIPE-VACUUM AUTO 20 16161-H1911 HANGER-SPRING MANUAL -672 20 16161-H7010 HANGER-SPRING MANUAL 0772- 0 16161-H1911 21 16134-H1910 LEVER-THROTTLE MANUAL 21 16134-H3920 LEVER-THROTTLE AUTO 22 16116-H1910 SLEEVE(A) 23 16236-H1910 LEVER 24 16452-H1000 SPRING-PUMP LEVER 25 16453-H1000 WASHER 26 16025-H1000 TUBE-EMULSION(P) 27 16160-H1910 SPRING-THROTTLE RETURN 28 16171-25710 WEIGHT-INJECTOR -672 28 16171-H7010 WEIGHT-INJECTOR 0772- 0 16171-25710 29 16061-18010 FLOAT 30 16026-B0810 TUBE-EMULSION(S) 31 16151-H1000 PISTON-POWER 1070- 32 16148-H1000 SPRING-PISTON RETURN 33 16141-18010 ROD-CONNECTING 34 16305-19915 SHAFT-PUMP LEVER 35 16307-04000 COVER-PUMP 36 16272-36710 PLUG-DRAIN (2) 37 16066-18010 SHAFT-FLOAT 38 16101-H1000 VALVE-NEEDLE 39 16098-25710 FILTER 40 16029-18010 WASHER 41 16065-H1010 SCREW 42 16033-L0101 JET-MAIN #97 -672 42 16033-H7010 JET-MAIN #95 0772- 0 16033-L0101 43 16043-25715 JET-MAIN #140 44 16055-14811 JET-SLOW #43 45 16054-B0810 JET-SLOW #50 46 16050-18010 BLEED-SLOW AIR #80 (2) 47 16204-08000 BLEED-SLOW AIR #100 48 16051-H3910 BLEED-SLOW AIR #215 49 16059-H3910 VALVE-POWER #50 -671 49 16059-H3911 VALVE-POWER #45 0771-0672 2 16059-H3910 49 16059-14810 VALVE-POWER #60 0772- 2 16059-H3911 50 16196-H7010 ASSY-CUT,FUEL 0772-1072 50 16196-H7011 VALVE-ANTI DIESELING SOLENOID 1172- 0 16196-H7010 51 16455-H1000 KIT-GASKET -672 51 16455-H6200 KIT-GASKET 2 16455-H1001 51 16455-H6200 KIT-GASKET 2 16455-H1000 51 16455-H1001 KIT-GASKET 0772- 2 16455-H1000 52 16475-H3910 KIT-SCREW & WASHER(B) -1072 52 16475-H7010 KIT-SCREW & WASHER (B) 1172- 0 16475-H3910 53 16465-H3910 KIT-SCREW & WASHER(A) 54 16009-H1910 KIT-REPAIR A, CARBURETOR -672 54 16009-H7000 KIT-REPAIR A,CARBURETOR 0772- 2 16009-H1910 54 16009-H6200 KIT-REPAIR A CARBURETOR 2 16009-H7000 55 16009-H7010 KIT-REPAIR B,CARBURETOR 0772- 2 16009-H3910 55 16009-H3910 KIT-REPAIR B, CARBURETOR -672
1 16010-H3901 ASSY-CARBURETOR (DCH306-1A) MANUAL 2 16010-H3900 1 16010-H3902 ASSY-CARBURETOR (DCH306-1B) MANUAL -672 2 16010-H3901 1 16010-H7000 ASSY-CARBURETOR (DCH306-4) MANUAL 0772- 0 16010-H3902 1 16010-H3920 ASSY-CARBURETOR (DCH306-3) AUTO 1 16010-H3921 ASSY-CARBURETOR (DCH306-3A) AUTO 2 16010-H3920 1 16010-H3922 ASSY-CARBURETOR (DCH306-3B) AUTO -672 2 16010-H3921 1 16010-H7100 ASSY-CARBURETOR (DCH306-5) AUTO 0772- 0 16010-H3900 1 16010-H3900 ASSY-CARBURETOR (DCH306-1) MANUAL 2 16011-H7011 ASSY-CHAMBER,CHOKE MANUAL 0772- 0 16011-H3910 2 16011-H3920 ASSY-CHAMBER,CHOKE AUTO -672 2 16011-H3910 ASSY-CHAMBER,CHOKE MANUAL -672 2 16011-H7111 ASSY-CHAMBER,CHOKE AUTO 0772- 0 16011-H3920 3 16182-H3920 POT-DASH AUTO 4 16302-H3910 LEVER-PUMP 5 16258-H3920 HOLDER-DASH POT AUTO 6 16143-H3910 ROD-PUMP 7 16262-H3910 DIAPHRAGM-SERVO 8 16118-H3910 ASSY-CHAMBER,THROTTLE 8 16118-H3911 ASSY-CHAMBER,THROTTLE -672 2 16118-H3910 8 16118-H7011 ASSY-CHAMBER,THROTTLE 0772- 0 16118-H3911 9 16145-91460 SPRING-IDLE ADJUST SCREW 10 16145-50000 SPRING-THROTTLE ADJUST SCREW 11 16129-25710 SCREW-THROTTLE ADJUST 11 16129-25715 SCREW-THROTTLE ADJUST -672 2 16129-25710 11 16114-H7010 SCREW-THROTTLE ADJUST 0772- 0 16129-25715 12 16144-M0110 SCREW-IDLE ADJUST -672 12 16144-H7010 SCREW-IDLE ADJUST 0772- 0 16144-M0110 13 16147-E6600 CAP-IDLE LIMITTEY 1070-0672 14 16082-H3910 PLATE-ADJUST -672 14 16082-H7010 PLATE-ADJUST 0772- 0 16082-H3910 15 16116-H3910 SLEEVE(B) 16 16128-H3910 LEVER-FIRST IDLE 17 16249-H3910 LEVER-OPENER 18 16389-H7010 COVER-THERMO 0772- 0 16389-H3910 18 16389-H3910 COVER-THERMO -672 19 16267-H3910 PIPE-VACUUM MANUAL 19 16267-H3920 PIPE-VACUUM AUTO 20 16161-H1911 HANGER-SPRING MANUAL -672 20 16161-H7010 HANGER-SPRING MANUAL 0772- 0 16161-H1911 21 16134-H1910 LEVER-THROTTLE MANUAL 21 16134-H3920 LEVER-THROTTLE AUTO 22 16116-H1910 SLEEVE(A) 23 16236-H1910 LEVER 24 16452-H1000 SPRING-PUMP LEVER 25 16453-H1000 WASHER 26 16025-H1000 TUBE-EMULSION(P) 27 16160-H1910 SPRING-THROTTLE RETURN 28 16171-25710 WEIGHT-INJECTOR -672 28 16171-H7010 WEIGHT-INJECTOR 0772- 0 16171-25710 29 16061-18010 FLOAT 30 16026-B0810 TUBE-EMULSION(S) 32 16148-H1000 SPRING-PISTON RETURN 33 16141-18010 ROD-CONNECTING 34 16305-19915 SHAFT-PUMP LEVER 35 16307-04000 COVER-PUMP 36 16272-36710 PLUG-DRAIN (2) 37 16066-18010 SHAFT-FLOAT 38 16101-H1000 VALVE-NEEDLE 39 16098-25710 FILTER 40 16029-18010 WASHER 41 16065-H1010 SCREW 42 16033-L0101 JET-MAIN #97 -672 42 16033-H7010 JET-MAIN #95 0772- 0 16033-L0101 43 16043-25715 JET-MAIN #140 44 16055-14811 JET-SLOW #43 45 16054-B0810 JET-SLOW #50 46 16050-18010 BLEED-SLOW AIR #80 (2) 47 16204-08000 BLEED-SLOW AIR #100 48 16051-H3910 BLEED-SLOW AIR #215 49 16059-H3910 VALVE-POWER #50 -671 49 16059-H3911 VALVE-POWER #45 0771-0672 2 16059-H3910 49 16059-14810 VALVE-POWER #60 0772- 2 16059-H3911 50 16196-H7010 ASSY-CUT,FUEL 0772-1072 50 16196-H7011 VALVE-ANTI DIESELING SOLENOID 1172- 0 16196-H7010 51 16455-H1000 KIT-GASKET -672 51 16455-H6200 KIT-GASKET 2 16455-H1001 51 16455-H6200 KIT-GASKET 2 16455-H1000 51 16455-H1001 KIT-GASKET 0772- 2 16455-H1000 52 16475-H3910 KIT-SCREW & WASHER(B) -1072 52 16475-H7010 KIT-SCREW & WASHER (B) 1172- 0 16475-H3910 53 16465-H3910 KIT-SCREW & WASHER(A) 54 16009-H1910 KIT-REPAIR A, CARBURETOR -672 54 16009-H7000 KIT-REPAIR A,CARBURETOR 0772- 2 16009-H1910 54 16009-H6200 KIT-REPAIR A CARBURETOR 2 16009-H7000
1973 LB110 USA Parts Catalog
