Hitachi R145 was used in 4WD applications as the rear final drive. Many applications used a 4-bolt rear cradle which contained the entire suspension except for the struts.
Coupling Type - Hydraulic (alloy case) Coupling Type - Electric (alloy case)
Hydraulic clutch Coupling Type C24 Serena M12 Prairie Liberty K11 March P12 Primera VW11V Expert エキスパート U30 0108-
Electric Coupling Type T30 X-Trail Murano USA Z50 electric coupling
Sources
R145 was mostly used with 4-cylinder engines
B14 1995-1999 Sunny B15 1999–2004 Sunnyᵂ RB14 1995-2000 Rasheenᵂ B30 2005-2012 Lafestaᵂ C24 1999-2000 Serena JPN (IRS post-vanette) 2001-2012 Asia markets 2007-2023 China C25 2005-2010 Serenaᵂ C26 2011-2015 Serenaᵂ L34 2019-2024 Altimaᵂ USA J10 2006-2012 Nissan Qashqaiᵂ/Dualis J11 2017-2022 Rogue Sportᵂ J32 2008-2013 Teanaᵂ [Altima] K11 9911-0010 Micra/Marchᵂ CG10DE+CGA3DE M12 9811-0105 Prairie Libertyᵂ N14 1990-1995 Pulsar N15 1995-2000 Pulsar#N15 N30 1997-2001 Nissan R'nessaᵂ P12 2001-2008 Primeraᵂ S35 2010-2011 Rogueᵂ T30 2001-2007 X-Trailᵂ T32 2015-2020 Rogueᵂ JU30 2000-2003 Bassaraᵂ U30 1998-2003 Presageᵂ U31 2004-2009 Presageᵂ VW11 1999-2006 Expertᵂ エキスパート W11 1999-2005 Avenirᵂ Y11 2002-2005 Wingroadᵂ/AD Van VHNY11, VFY11 Y12 2005-2012 Wingroadᵂ/AD Van/NV150 Ad Z50 2002-2007 Muranoᵂ USA Z51 2009-2014 Muranoᵂ USA Z53 2015-2024 Muranoᵂ USA
Renault Kangooᵂ HY 2007-2017 Renault Samsung Koleos/QM5ᵂ
Gearset
2.466 3.357 3.692 ?
38100-10E60ᴳ GEAR SET-FINAL DRIVE 47/14=3.357 M12, N30, W11, U13 38100-CA000ᴳ GEAR SET-FINAL DRIVE 37/15=2.466 [split case] $617 USD T31 J11 U31 Z50 Z51 38100-CA00Eᴳ GEAR SET-FINAL DRIVE [split case] $1384 USD (2023) Z50 Z51 U31 J10 T31 Altima.2019-2024 Murano.2011-2024 Rogue.2010-2011,2015-2020 Rogue Sport.2017-2022 * superceeds 38100-CA000 38100-4N500ᴳ GEAR SET-FINAL DRIVE 37/15=2.466 [split case] C24,K11,M12,P12,T30,VW11,W11,JU30,U30.2002- Y11 38100-4N50Eᴳ GEAR SET-FINAL DRIVE 37/15=2.466 [split case] T31 2011-2016 Serena C26.MR20DD
38100-11E65ᴳ 48/13=3.692 [long pinion]
JU30 9911-0108 KA24DE+YD25DDT, B15, G10, U30.2000-2001 split case
R180 gearsets interchange with R145? 38100-03G10ᴳ GEAR SET-FINAL DRIVE 37/10=3.700 [R180 long pinion] B13, B14, N14, N15, RB14 Rasheen
LSD
Can R145 use the R180 LSD?
Coupling
The coupling takes the place of a center differential. These models have a totally different case, which is split on the axle centers.
Electric Coupling
The electric coupling is designed to work at any setting from non-powered to fully-powered, for various torque splits. The electric coupling, when not powered, allows the rear diff to free-wheel (putting the vehicle into FWD mode). When fully powered, the propeller shaft rotation connects to the diff as normal.
For this reason, operating as a RWD-only diff is complicated. You could use a relay and fully power it, but the failure mode would be to stop transmitting power.
Z50 USA Murano (CVT) T30 JDM X-Trail GT
Hydraulic Coupling
Appears to be a continuous (non-disconnectable) driver unit?
38760M assembly 38760KS assembly kit with bearings
38760-4N210ᴳ COUPLING ASSY-HYDRAULIC
* K11 March
38760-4N215ᴳ COUPLING ASSY-HYDRAULIC
* C24 Serena
* M12 Prairie Liberty
* P12.QR20DE.AT 0101-
* VW11V Expert エキスパート
38760-4N815ᴳ COUPLING KIT-HYDRAULIC
* KIT with 38760-4N215 and two bearings
* U30 0108-
* JDM.U30,C24,M12,JU30,P12,VW11,W11
Gasket
Nissan Gasket Silicone Liquid
Case
38310 CASE (CARRIER COMPL-GEAR) / DIFFERENTIAL HOUSING
COUPLED TYPES38310-8H500ᴳ [electric coupling] JDM T30 X-Trail 38310-CA000ᴳ [electric coupling] $1495 USD USA Murano.2003-2012.VQ35DE,QR25DE USA Rogue 2008-2015.QR25DE * Supersedes 38310-8H500 38310-4N500ᴳ [hydraulic coupling] C24 C25 M12 P12 U30 U31 JU30 W11 M12 VW11 J31 J32 B30 Y11 Y12
SHORT-NOSE 38311-20E00ᴳ * N30 R'nessa * JU30 9911-0108 KA24DE+YD25DDT 38310-4N500ᴳ * JU30.early
LONG-NOSE 38311-71Y00ᴳ/38311-71Y02ᴳ * B13, B15, M12, G10, N14, N15, RB14, W11
R180 38311-S6200ᴳ * USA.M11 non-LSD R200 38311-S7000ᴳ * USA.910+M10+M11.LSD+S130
Weight
Longnose R160 < 56 lbs Longnose R180 ~ 66 lbs Longnose R200 76 lbs Shortnose R200 72 lbs
Rear Suspension
431 REAR SUSPENSION STRUT TYPE B13,B15 drum brake N14,N15 DB *DISC OPTION SR20DE
N30 Short-nose JU30 9911-0108 Short-nose JU30 0108- Hydraulic Type U30 0108- R145A hydraulic type * Double A-arm suspension on cradle * transverse leaf * drum brake
P12, strut type, flat 4-bolt? * disc brake
