Measurements
Revision as of 17:54, 18 January 2025; view current revision
Category: Body
Body Dimensions
Compared to the Coupe, the sedan sits 5mm lower in front, 5mm higher in back. The sedans have "rake". The Coupe sits level.
  • Width, sedan: 1495 mm (also Van)
  • Width, Coupe: 1515 mm (also KPB110)
15005.jpgAlbum 15005
  • Length, sedan: 3830 mm
  • Length, coupe: 3835 mm
  • Length, coupe 1400GX: 3825 mm
  • Length, van: 3865 mm
    • Front Bumper to axle: 605 mm
    • Wheelbase: 2300 mm
    • Rear axle to rear body edge, sedan: 915 mm
    • Rear axle to rear body edge, coupe: 880 mm
    • Rear axle to rear body edge, van: 955 mm (edge of door hinge)
    • Rear bumper overhang, sedan: 10 mm
    • Rear bumper overhang, coupe: 40 mm
    • Rear bumper overhang, van: 5 mm
  • Ground clearance: 170.0 mm
  • Top of rear bumper, sedan: 580 mm from ground
  • Top of rear bumper, coupe: 575 mm from ground
15006.jpgAlbum 15006
  • Track width: 1240 mm front (tire tread centers)
  • Track width: 1245 mm rear (49.0 inches NOTE: Datsun 510 IRS is 50 inches)
  • Headlight Centers width: 1125 mm
  • Headlight Centers from ground, sedan: 660 mm (also van)
  • Headlight Centers from ground, coupe: 665 mm
  • Height, Sedan: 1390 mm
  • Height, Coupe: 1350 mm (same as KPB110)
  • Height, Van: 1405 mm
    • Tire radius: 276 mm
Ground clearance is measured from the bottom of the differential housing. So when you think about it, the tire size will make a difference...
  • Nominal Tire diameter: 21.7 inch (155SR-12, factory size)
Measurement sheets:
15007.jpgAlbum click to viewcoupe 15008.jpgAlbum click to view2-door 15009.jpgAlbum click to viewvan
^Diagrams: Sunny Salesman's Book, 1970
Crossmember
  • 60 crossmember bolts spacing
  • 656 " bolts width
  • 68, 8 " bolts from strut centerline
Leaf spring
  • 1117.5 front bolt to rear bolt
  • 125-54.2 vertical front bolt (below) to rear bolt (above)
  • 5.8
B310 Crossmember
  • 68.1 crossmember bolts spacing
  • 39.6, 43.2
  • 43.6, 40
  • 714, 722 " bolts width
  • 84.2, 16.1 " bolts from strut centerline
  • 850 axle centerline to shifter
  • 635 axle centerline to front crossmember bolt
Van Cargo Area
  • floor from ground: 565 mm
  • Length with rear seat folded up: 1485 mm
  • Hatch opening space: 815 mm high, 870 mm wide at top of door
  • nominial inside width: 1235 mm (5dr) or 1240 mm (3dr)
Comparison
Weight
See also: Weight
Lighter means faster accelerating with same engine
Comparison of 1200 to other 4-door sedans
B101550 pounds (703 kg)
B1101640 pounds (743 kg)
B2102000 pounds (overweight?)
B3102000 pounds (bigger than B210, yet just as light)
SPL3101995 pounds (905 kg)
Size
Also see Size
In millimeters:
sedanlengthwheelbasewidthtrackheightturningclearance
SPL310 roadster3953228014951213/119812754.9160
B10382022801445119113464.0160
B110383023001495124013904.1 m170 mm
B210408023401545127513604.7 m170
B31041902340158013301365turning165
S30/240Z coupe4136230516301347/13561283turning161
Weight Distribution
modelfront/rearHeight of Center of Gravity
B1054/46HCG
B10 DX55/45HCG
B2058/42HCG
B11054/46HCG
B12059/41HCG
B31053/47HCG
SPL31054/46460 mm
Comparison
1981 Civic: 61/39
1981 Corolla FWD: 60/40
B120 Front: 430kg
B120 Rear: 300kg
Body Alignment
22876.jpgAlbum 22876
Closeup detail- front suspension
4671.jpgAlbum click to view 4669.jpgAlbum click to view 4670.jpgAlbum click to view 22877.jpgAlbum click to view 7010.jpgAlbum click to view 7011.jpgAlbum click to view
Window Sticker
2682.jpgAlbum 2682
B10
Datsun 1000 Wagon
4-door Sedan
2-door Sedan
Ute/Truck
Export B20 1968 from Service Bulletin 88 page 5
length: 3815mm
 width: 1450mm
height: 1385mm
weight: 615kg
PB210
27396.jpgAlbum 27396
HB210
1976 North America specification
General Views
General Views Blueprints Diagrams
24943.jpgAlbum 24943
