Air conditioning
Revision as of 09:24, 4 November 2008; view current revision
Datsun 1200, unlike the Datsun 1000, was designed with airconditioning in mind. However, it was still a dealer-installed add-on option.
  • Pump
  • Condensor (cooling radiator)
  • Double crankshaft pulley. (The extra pulley runs the compressor)
  • Under-dash vents
  • Hoses
  • Wiring
Since B110 A/C is fairly rare, you can source most of the parts from a B210 or B310. Only the interior vent setup is needed for a B110. They are fairly common on late model B122 Sunny Trucks.
Optional Fan
Nissan option flex-fan
Dealer item
From USA catalog:
  • 21060-H1001 FAN-COOLING A12 (standard B110 fan)
  • 21060-A4605, 21060-N0100 FAN-COOLING D=330 FOR TROPICAL USA (330 mm diameter)
B122 Sunny Truck Kit
You need all these parts:
  • Ass'y indoor unit (air volume switch, evaporator, integrated blower fan)
  • air conditioner compressor
  • compressor bracket
  • crank pulley (belt cooler)
  • two capacitor (before radiator, radiator horizontal)
  • capacitor for electric fans
  • high-pressure pipe
  • low-pressure hose
  • Receiver tank
  • relay harnesses
2185.jpg 2187.jpg 2199.jpg 2209.jpg 2210.jpg 2341.jpg 2495.jpg 3053.jpg 3811.jpg 4163.jpg 4164.jpg 4305.jpg 5060.jpg 5063.jpg 7635.jpg 7777.jpg 9377.jpg 9378.jpg 11444.jpg 11711.jpg 12038.jpg 13934.jpg 14556.jpg 14557.jpg
