Jack
Revision as of 07:47, 29 December 2007; view current revision
Categories: Wheel And Tire | Daily Care
Datsun 1200s were equipped with an easy-to-use scissor-type jack. It shipped in the boot, as shown in the Owners' manual.
Also see: Changing tire
USA 1972 Owners manual (see page 27 for details):
There are four jack-up points at the floor panel
You can jack-up the 1200 at these points:
Using OEM jack (see Owners Manual above):
  • under rocker panel front
  • under rocker panel rear
Be sure to use a Nissan or Toyota jack with a "slot" to fit over the rocker panel seam.
Using other jacks:
  • Under lower A-arm (Transverse link), near tire
  • Middle of engine crossmember (lift entire front end)
  • center of Differential (lift entire rear of car)
  • Outboard ends of rear axle housing
CAUTION: Before sliding underneath the car, be sure to place jackstands under the suspension. In a pinch a tree stump or beefy timber can work. Make certain it is secure, and lower the weight of the car on the jackstands.
Standard Equipment
  • Scissor Jack
  • S-shaped Jack Handle
  • Wheel Wrench in black 'Nissan' bag
  • Tire retaining clamp
Jack Location
The Jack and its equipment is stored in the Trunk (Boot).
Coupe
Sedan
