B110 was fitted with seat belts. Belts differ by country. Two-point or three-points belts were fitted.
Variations
Early USA models came with either 2-point (lap-belt only) or 3-point (lap + shoulder) belts. Both front and rear belts are standard equipment.
- All 1972 models use 3-point belts
- From 0172, retractor system was used front and rear
- Rear set had 2-point belts
- Rear Optional was 3-point belts (not available with retractor type)
- 86810: shoulder belt
- 86820: 2 point
- 86830: 3 point (set? Or RH?)
- 86880: 3 point LH
- 88820: rear
B110
Front
- 86820-H1001 BELT SET-safety (2 point) -0871, PB110
- 86820-H1001 BELT SET-safety (2 point) 0871-
- 86830-H4600 S/BELT F/SEAT 3 POINT TYPE (AUTO LOCK R 0172- USA $141.47
3 point retracting (with integrated shoulder belt)
- 86830-H1000 BELT SET-safety GX 1972, 1973, PB110 OPTION, PB110 GX
- 86830-H1001 BELT SET-safety GX 1972, 1973 $62.28
Shoulder belt
- 86810-H1000 BELT ASS'Y-shoulder, front seat (for 3 point) OPTION -0871
- 86810-H1001 BELT ASS'Y-shoulder, front seat (for 3 point) OPTION 0871-
Rear Seat Sedan, Van
- 88830-H1000 SET-SAFTY BELT REAR SEAT 3 POINT TYPE USA OPTION
- 88830-H1001 SET-SAFTY BELT REAR SEAT 3 POINT TYPE USA OPTION 0871- $71.11
- 88820-H1000 BELT SET-reat seat OPTION -0871
- 88820-H1001 BELT SET-reat seat OPTION 0871- JDM
- 88820-H4600 SET-SAFETY BELT REAR SEAT 2 POINT TYPE 0171- USA (retractor type) Sedan, Coupe NLA
- 88810-H1000 ASS'Y SHOULDER, safety belt OPTION USA
- 88810-H1001 ASS'Y SHOULDER, safety belt OPTION JDM, USA 7108-
Rear Seat Coupe
- 88820-H1800 BELT SET-reat seat OPTION [3 point], PB110 OPTION
- 88830-H1801 SET-SAFTY BELT REAR SEAT 3 POINT TYPE USA Coupe 0871-
- 88820-H1800 SET-SAFETY BELT REAR SEAT 2 POINT TYPE USA Coupe
- 88820-H1801 SET-SAFETY BELT REAR SEAT 2 POINT TYPE USA Coupe 0871-
- 88810-H1001 ASS'Y SHOULDER, safety belt OPTION JDM, USA 0871-
Seat Belt Warning System
USA models have a warning system. If the seat is occupied, the weight switch sounds a buzzer unless the belt is fastened. For details, see Seat Belt Warning System.
Swaps
The key to a great seat belt swap for B110 is finding a low profile rectractor that fits below the seat.
Late B210
1978 B210 dual-retractor design 3-point belt. It bolts to stock B110 bolt holes.
- Lower retractor blocks seat from fully moving back
- B210 Belt buckle is modern semi-rigid design that works stock B110 belts. But it is on the short side for B110.
620
1977 Datsun 620 pickup is a one-piece shoulder & seat belt, that bolts to stock B110 mount holes.
- Works like a modern belt, very nice
- Belt buckle is bit long. But works.
- Rectractor blocks seat from moving fully back. But has unique swing design so fits better than Late B210 belts.
1977 Datsun 620 Pickup belts (USA) in Datsun 1200
B210 belts bolt into B110. PB210 uses same belts.
Front
- 86820-H5000 2-point -7503
- 86830-H5000 3-point -7503 GX
- 86830-H7400 ELR 3-pt 7504- Sedan, Coupe 76- Van (Takata)
- 86830-N6610 NLR w/shoulder 7504- Van
- 86830-H7800 ELR 76- Van (Fuji)
Shoulder Belt
- 86810-H5000
Rear Sedan, Coupe
- 88820-H5000 -7503
- 88820-H7400 7504- (Takata)
- 88820-H6600 OPTION van
- 88820-H6601 OPTION van 0475- (Fuji)
- 88820-H6602 Van (Takata)
North America
Aside from fabric type and regional requirements, the basic difference is:
- 2-dr vs 4-dr
All are retractor type. All are 3-point, early uses separate shoulder belt, later uses integrated shoulder belt.
4-dr
- 86830-H6200 POLYESTER(NSK) -0274
- 86830-H6210 NYLON (TAKAT)(USA) 1073-0275
- 86830-H6205 NYLON (NSK) (USA) 0374-0275
- 86830-H6206 NYLON (NSK) (USA) 0375-
- 86830-H6211 NYLON (TAKAT)(USA) 0375-
- 86830-H6205 NYLON (NSK) (CAN) 0374-0775
- 86830-H6206 NYLON (NSK) (CAN) 0875-
- 86830-H6210 NYLON (TAKAT) (CAN) 1073-0775
- 86830-H6211 NYLON (TAKAT) (CAN) 0875-
2-dr California
- 86830-H6900 POLYESTER (NSK) -0274
- 86830-H6905 NYLON (NSK) (USA) 0374-0275
- 86830-H6906 NYLON (NSK) (USA) 0375-
- 86830-H7301 NYLON (NSK) (CAL) 0974-0275
- 86830-H7302 NYLON (NSK) (CAL) 0375-0775
- 86830-H6905 NYLON (NSK) (CAN) 0374-0775
- 86830-H6906 NYLON (NSK) (CAL,CAN) 0875-
- 86830-H6910 NYLON (TAKAT) (USA) 1073-0275
- 86830-H6911 NYLON (TAKAT) (USA) 0375-0776
- 86830-H7311 NYLON (TAKAT) (CAL) 0974-0275
- 86830-H7312 NYLON (TAKAT) (CAL) 0375-0775
- 86830-H6910 NYLON (TAKAT) (CAN) 1073-0775
- 86830-H6911 NYLON (TAKAT) (CAL,CAN) 0875-0776
- 86830-H6920 NYLON (TAKAT) 0876-
Rear
- 88820-H6200 SET-SAFETY BELT REAR SEAT (rectractor type, 2 point) USA -1177 $67.89
- 88820-H6205 SET-SAFETY BELT REAR SEAT (rectractor type, 2 point) USA 1277-
B120
BELT-SHOULDER, FRONT
- 86810-H7400 7510-7803 BLACK
- 86810-G1060 7804-8910 DARK BROWN
2 POINT
BELT SET-FRONT SEAT, 2 POINT
- 86820-H7401 7510-7803 BLACK
- 86820-G1260 7804-8910 DARK BROWN
3 POINT Non retracting
BELT SET-FRONT SEAT, 3 POINT (separate shoulder belt)
- 83830-H7401 7510-7803 BLACK
- 83830-G1061 7804-8109 DARK BROWN
- 83830-G1062 8110-8109
3 POINT Retracting
These retractors bolt to the B-pillar and should fit B110 sedan, coupe and van.
BELT SET-FRONT SEAT, 3 POINT (integrated shoulder belt)
- 83830-G1070 ELR DARK BROWN 7804-8109
- 83830-G1071 ELR 8110-8611
- 83830-G1900 ELR 8611-8910
- 83830-95W00 ELR 8910-
- 83830-95W03 ELR ????????????? 8910-
B310
B310 front seat belts have a retractor mechanism that fits inside the B-pillar. So they do not fit B110.
Rear
- 88820-H8500 Black $46.27
