Camshaft Comparison
Revision as of 23:12, 22 August 2009; view current revision
Category: Camshaft
There are basically four factory camshaft grinds:
  • small bore grind
  • large bore grind
  • performance grind, used in GX, Twin-carb, and EFI engines
  • emission grind, used in 1981-1982 USA engines
However, these can be fitted to any engine. The emission grind cam was used in A12A, A14 and A15 engine -- all with same cam part number.
Duration
"Advertised Duration" means you should only compare these numbers with grinds from the same manufacturer. Other vendors may measure it differently.
1974-up
  • 13001-H9800 CAMSHAFT [Typical use: 1981-1982 USA]
    244/248 duration
    • USA B310 A14,A15 B310 0880-
    • USA B310 A12A 0880- B310
  • 13001-H5700 CAMSHAFT [Typical use: Performance engine]
    248/256 duration .331 lift
    • JPN B210 A12T, A14T
    • JPN B310 A14E, A15E
  • 13001-H5000 CAMSHAFT [Typical use: A12S]
    248/248 duration
    • JPN B120 A12S
    • JPN B210 A12S
    • JPN B310 A12S, A13S
    • USA B310 A12A 0879-0780
    • CAN B310 A12A
  • 13001-H6200 ASSY-CAMSHAFT [Typical use: A14/A15]
    248/256 duration
    • JPN B210 A14S
    • USA B210 A13, A14
    • USA B210 F10 A14
    • USA B310 A14,A15 -0780
    • JPN B310 A14S, A15S
ADVERTISED DURATION
248/248 duration (standard small bore)
  • 13001-H5000
248/256 duration (standard large bore)
  • 13001-H6200
256/256 duration (performance engines)
  • 13001-H5700 .331 lift
244/248 duration (Late USA emission)
  • 13001-H9800
1967-1973
  • 13001-H7000 ASSY-CAMSHAFT USA B110 A12 0772- 0 13001-H2300
  • 13001-H2300 CAMSHAFT B110 JPN A12 GX
  • 13001-H1000 CAMSHAFT B110 USA JPN A12
  • 13001-18001 CAMSHAFT B10 JPN A10 0470- replaces 13001-18000 & 13001-H0100
  • 13001-18000 CAMSHAFT JPN B10 A10
  • 13001-H0100 CAMSHAFT JPN B10 A10
ADVERTISED DURATION
248/248 duration
  • 13001-H1000 A12
256/256 duration .331 lift
  • 13001-H2300 A12 GX
Chart
Part Number@Ex. DurIn. DurIn. OpenIn. CloseEx. CloseEx. OpenLift (in)Reference
13001-18000 ?
13001-H1000?248248145412560.335Camshaft photo
13001-H2300?256256205618580.353A12GX Engine
13001-H5000?24824814541256 photo
13001-H5700?256248145420560.331here
13001-H6200?256248145420560.324photo
13001-H9800?24824414501256 1981 Engine
99996-H1031?300     0.487Nismo
99996-H1032?310     0.487Nismo
13001-H57100.10280 386235650.37topic
13001-H57110.10      0.37Nismo
?0.10320     0.413Nismo
?0.10328     0.413Nismo
