Datsun 1200s had optional AM and AM/FM radios. Original Equipment Manufacturers (OEMs) included Clarion, Hitachi, and Ferris.
Factory Options
- Monoraul AM, single speaker
- Mono AM/FM, with single speaker
- Stereo AM/FM, with dual speakers
Stock AM Radio, Ferris - Datsun (Australia)
Stock AM Radio, Hitachi - Datsun (USA, 1972)
Stock AM Radio, Philips - Datsun (Australia)
Stock AM/FM Radio, Clarion (JDM, 1972)
Clarion RN 1006M
Speakers
If your 1200 came with a factory radio, the factory speaker and grille mounted on the kick panel under the dash. The stereo option came with two of these, one for each side.
You can fit high-quality speakers in the original location:
When the speakers are real big
Operation
USA 1972 Owners manual (see page 20 for details): ![]() ![]()
Radio Instruction Card
Here's a radio instruction card, for the Hitach AM radio:
Radio Delete Plate
Perhaps most 1200s came without a radio. Here's the plate:
Alternate Mounting Locations
In center Console
Aftermarket Stereos
Most modern stereos are DIN-mounted, requiring you to use an alternate mounting location, or cut the metal dash to fit it. A few companies still offer a two-shaft CD-receiver in a modern design.
amplifiers, equalizers, CD players, etc
Nissan Accessory Kits
- 99993-00132 Hitachi AM/FM Radio model A-1681
- 99993-00119 Hitachi AM/FM Radio model A-1581
B110
- 27900-H1110 KIT-RADIO WITH ANTENNA (HITACHI) OP
- 27900-H1105 KIT-RADIO WITH ANTENNA (CLARION) OP
- replaces 27363-18200
- 27900-H1102 KIT-RADIO WITH ANTENNA (CLARION) OP
- 27962-H1110 ASSY-ANTENNA OP
- 27962-H1100 ASSY-ANTENNA OP
- 27984-H5001 CONDENSER-TYPE B OP
- replaces 27984-89900
- 68470-H1100 MASK-RADIO DATSUN MARK
- 27978-H1000 PLUG-RUBBER
- 27979-H1000 PLUG-RUBBER
- 27910-H7225 KIT-RADIO AM (CLARION) OP 0875- 27910-H6225
- 27910-H6226 KIT-RADIO AM FM MONO. (CLARION) OP 0774-0775
- 27910-H7226 KIT-RADIO AM FM MONO. (CLARION) OP 0875- 27910-H6226
- 27910-H6228 KIT-RADIO AM FM MULTI. (CLARION) OP 0774-0775
- 27910-H7227 KIT-RADIO AM FM MULTI. (CLARION) OP 0875- 27910-H6228
- 27910-H6225 KIT-RADIO MW (CLARION) OP -
- 27910-H6100 SET RADIO RECEIVER MW (CLARION) OP -
- 27910-H6205 SET RADIO RECEIVER AM FM MONO (CLARIO OP 0774-
- 27910-H6210 SET RADIO RECEIVER AM FM MULTI (CLARI OP 0774-
- 27924-H6100 ESCUTCHEON-RADIO OP -
- 27923-H5025 SET-KNOB WITH WASHER & NUT OP 0774-
- 27923-H5025 SET-KNOB WITH WASHER & NUT AM FM MULTI OP 0774-
- X3803-43700 KNOB-INNER MW (CLARION) OP -
- X3803-43800 KNOB-OUTER MW (CLARION) OP -
- 27962-H6100 ASSY-ANTENNA (CLARION) OP -176
- 27962-H6101 ASSY-ANTENNA (CLARION) OP 0276- 27962-H6100
- 27962-H6110 ASSY-ANTENNA (HITACHI) OP -
- 27962-H6111 ASSY-ANTENNA (HITACHI) OP 0476- 27962-H6110
- 27984-H5000 CONDENCER TYPE B OP -
- 27984-H5001 CONDENCER TYPE B OP - 27984-H5000
- 27933-H5010 ASSY-SPEAKER MW (HITACHI) OP -
- 27933-H5001 ASSY-SPEAKER AM FM MULTI. (CLARION) OP 0774-0775
- 27933-H5001 ASSY-SPEAKER AM FM MULTI. (CLARION) OP 0875-
- 29440-H5001 ASSY-SPEAKER AM FM MULTI. (CLARION) RE OP 0875-
- 27933-H5001 ASSY-SPEAKER MW (CLARION) OP -
- 68470-H5000 MASK-RADIO -
- 27978-H1000 PLUG-RUBBER -
- 27979-H1000 PLUG-RUBBER -
- 27979-H5000 COVER-ANTENNA OP. -
- 68480-H6200 ASSY-INDICATOR LAMP,SEAT BELT CAN -
- 68480-H7302 ASSY-INDICATOR LAMP,BELT CATALYST & F CAL 0875- 68480-H7301
- 68480-H7301 ASSY-INDICATOR LAMP,BELT CATALYST & F CAL 0974-0775 68480-H6200
- 68480-H7302 ASSY-IND LAMP,SEAT BELT, CATALYST & F FED(GFU) 1276-
- 68480-H7200 ASSY-INDICATOR LAMP,SEAT FED 0974-0776 68480-H6200
- 68480-H6200 ASSY-INDICATOR LAMP,SEAT BELT -874
- 68480-H6200 ASSY-INDICATOR LAMP,SEAT FED 0876- 68480-H7200
- F8480-H6200 ASSY-SOCKET WITH HARNESS FORINDICATOR LA -874
- 26261-89900 BULB-INDICATOR LAMP -
- 26261-89900 BULB-INDICATOR LAMP FED 0974-
- 26261-89900 BULB-INDICATOR LAMP CAL 0974-
- 27989-H5000 ASSY-BONDING WIRE OP -
- 24875-H7201 DETECTOR-DRIVE COUNTER FED 0974-
B310
- B7910-H9111 RADIO KIT-AM/FM MONO (HITACHI) OP
- B7910-H9101 RADIO KIT-AM/FM MONO (CLARION) OP
- B7910-H9161 RADIO KIT-AM/FM MPX (CLARION) OP
- B7910-H8501 RADIO KIT-AM(CLARION) OP
- 27901-W5800 RADIO UNIT-AM OP
- 27907-W5800 RADIO UNIT-AM/FM MONO OP
- 27911-W5800 RADIO UNIT-AM/FM MPX OP
- 27933-89925 KNOB SET-RADIO,OUTER/INNER OP
- 27933-89901 KNOB-RADIO,OUTER OP
- 27934-89901 KNOB-RADIO,INNER OP
- 08915-44010 WASHER-PLAIN OP
- 27939-89900 NUT OP
- 27927-H8500 BRACKET-RADIO RH OP
- 27928-H8500 BRACKET-RADIO LH OP
- 08310-50812 SCREW(FOR UNIT) OP
- 08540-51242 SCREW(FOR INST) OP
- 24210-89962 CLIP OP
- 24210-89932 CLIP OP
- 99604-H1400 CLIP OP
- 27984-K0100 CONDENSER(FOR IGN COIL) OP
- 01461-00061 SCREW-TAPPING(M6) OP
- 27984-M0900 CONDENSER(FOR REGULATOR) OP
- 08510-61612 SCREW-TAPPING(M6) OP
- 27987-W5000 WIRE-BONDING(ENGINE DASH) OP
- 27960-H9100 ANTENNA SET (CLARION) OP
- 27960-H9110 ANTENNA SET (HITACHI) OP
- B7945-H8510 SPEAKER KIT-AM/FM MONO (HITACHI) OP
- B7945-H9301 SPEAKER KIT-AM/FM MPX (CLARION) OP WAGON
- B7945-H9161 SPEAKER KIT-AM/FM MPX OP SEDAN
- B7945-H8500 SPEAKER KIT-AM/FM MONO (CLARION) OP
- B7945-H8500 SPEAKER KIT-AM (CLARION) OP
- B7945-H9101 SPEAKER KIT-AM/FM MPX (CLARION) OP COUPE
- B9315-H9200 CASSETTE DECK KIT OP
- 24325-H8663 HARNESS-ADOPTER OP
- 29337-U7800 CABLE-ADOPTER EARTH OP
- 08540-51212 SCREW OP
- 96926-H8903 MASK-CONSOLE(FOR STEREO) (BLUE) OP
- 96926-H8901 MASK-CONSOLE(FOR STEREO) (BLACK) OP
- 96926-H8902 MASK-CONSOLE(FOR STEREO) (BROWN) OP
F10
- B7920-M5906 KIT-RADIO(AM/FM) (CL COUPE,OP 0278- Y B7920-M5905
- B7920-M5910 KIT-RADIO(AM/FM) (HI COUPE,OP -
- B7920-M4900 KIT-RADIO(AM) (CLARI OP -
- B7920-M5905 KIT-RADIO(AM/FM) (CL COUPE,OP -178 8
- 27911-M5905 TUNER (AM/FM) (CLARI COUPE,OP -178 8
- 27914-M5906 TUNER (AM/FM) (CLARI COUPE,OP 0278- Y 27914-M5905
- 27914-M5910 TUNER (AM/FM) (HITAC COUPE,OP -
- 27914-M4900 TUNER (AM) (CLARION) OP(SEDAN WAGON) -
- 27935-M3825 SET-KNOB WITH WASHER OP - Y 27935-M0225
- 27935-M5925 SET-KNOB WITH WASHER COUPE,OP -
- 27935-M3825 SET-KNOB WITH WASHER COUPE,OP - Y 27935-M3825
- 27935-M0225 SET-KNOB WITH WASHER OP -
- 27935-M0227 PLATE-ESCUTCHEON (FO OP -
- 27935-M5927 PLATE-ESCUTCHEON (FO COUPE,OP -
- 08313-51698 SCREW-PAN HEAD WITH COUPE,OP -
- 27933-H5001 SPEAKER COUPE,OP -
- 08510-41297 SCREW-PAN HEAD TAPPI COUPE,OP -
- 27984-M3060 SUPPRESSOR-NOISE,FOR COUPE,OP -
- 27984-M3061 SUPPRESSOR-NOISE,FOR COUPE,OP - Y 27984-M3060
- 27984-M0900 SUPPRESSOR-NOISE,C F COUPE,OP -
- 27982-M0200 TERMINAL-EARTH COUPE,OP -
- 27964-M3000 ANTENNA-PILLAR COUPE,OP -476 6
- 27964-M3001 ANTENNA-PILLAR COUPE,OP 0576- Y 27964-M3000
- 08510-51612 SCREW COUPE,OP -
- 08530-51690 SCREW COUPE,OP -
510
- 27900-21610 KIT RADIO OP. CANADA
- 27900-26110 RADIO KIT OP. USA -0768
- 27900-A0810 RADIO KIT OP. 0868-0669 supercedes 27900-26110
- 27910-A4625 RADIO KIT OP 0769- supercedes 27900-A0800
- 27910-A4626 RADIO KIT OP. 0769-0172 supercedes 27900-A0810
- 27900-N0225 RADIO KIT OP 0272- supercedes 27910-A4626
