Crankshaft Seal
Revision as of 07:35, 18 December 2009; view current revision
Category: Engine Mechanical
The Timing Cover seal is for the crankshaft pulley.
Front
RockAuto.com
  • BECK/ARNLEY Part # 0521989
  • SKF Part # 14720
  • TIMKEN Part # 223830
  • NATIONAL Part # 223830 {Oil Seal; Acrylates / Shaft Size=1.496" Housing Bore=2.165" Outer Diameter=2.176" Width=0.276"}
Repair Sleeve
Timing Cover Repair Sleeve fixes a worn crankshaft pully surface caused by a poorly lubricated seal.
  • before installation, be sure to put the slinger on correctly, and to grease the new seal.
  • SKF Part # 99147
  • NATIONAL Part # 99147 {Redi-Sleeve; 1.490" x 1.496" x .512"}
  • TIMKEN Part # KWK99147 Kwik-Sleeve
Rear
RockAuto.com
  • FEL-PRO Part # BS27493 {Rear Main Seal Set} OHV engine; Rear Main Seal Set; Rubber; One-piece
  • TIMKEN Part # 712006
  • NATIONAL Part # 712006 {Oil Seal; Silicone / Shaft Size=2.362" Housing Bore=3.228" Outer Diameter=3.236" Width=0.472"}
Repair Sleeve
  • TIMKEN Part # KWK99235 Kwik Sleeve, Optional Repair; Rear
  • NATIONAL Part # 99235 {Redi-Sleeve; 2.359" x 2.365" x .787"} Rear
