Alternator Part Numbers
From Datsun 1200 Club
Categories: Charging System | Catalog
<-- back to Part Numbers Index
Also see: Main articles for usage, photos, cross-reference
Alternator
Voltage Regulator
B110
VOLTAGE REGULATOR
17 23500-29901 REGULATOR-voltage (日立) TL1Z-37
   23500-29902 REGULATOR-voltage (日立) TL1Z-57 <> 23500-29901
   23500-29911 REGULATOR-voltage (三菱, RQB-2B)
18 08513-61212 SCREW fixing regulator (2)
19 08916-13610 WASHER-lock fixing regulator (2)
Sunny Truck
REGULATOR-VOLTAGE 23500
23500-29912 7510-8503 ミツビシ
23500-29913 8503-8910 ミツビシ
25A ALTERNATOR & REGULATOR
1 23100-U0100 ASSY-ALT.12V-35A (HITACHI LT135-13)(DE A12 2 23100-A5501
1 23100-A5501 ASSY-ALTERNATOR(HITACHI)
2 23108-A5501 ASSY-ROTOR
3 23120-14801 BEARING-BALL A12
4 23102-A5501 ASSY-STATOR
5 23127-H0300 ASSY-COVER,REAR
5 23127-61700 ASSY-COVER,REAR A12 2 23127-H0300
5 23127-61701 ASSY-COVER REAR A12 2 23127-61700
6 23236-H0300 COVER-DIODE
6 23236-H0301 COVER-DIODE A12 0872- 2 23236-H0300
7 23230-H0300 ASSY-DIODE
8 23133-H0300 ASSY-HOLDER,BRUSH
8 23133-H0301 ASSY-HOLDER,BRUSH 23133-H0300
9 23135-H0300 ASSY-BRUSH,F
10 23135-H0301 ASSY-BRUSH,E
11 23156-H0300 ASSY-TERMINAL BOLT
12 23118-H0300 ASSY-COVER,FRONT
13 23122-21000 PACKING
14 23121-21000 RETAINER-PACKING
15 23120-14800 BEARING-BALL
16 23123-21005 RETAINER-BEARING
17 23164-H0100 BOLT-SETTING
18 23131-H0300 BOLT-THROUGH,L=85 2
19 23131-H0301 BOLT-THROUGH,L=95
20 23150-21001 ASSY-PULLEY
20 23150-21002 ASSY-PULLEY A12 2 23150-21001
21 23153-H0100 ASSY-NUT
22 23200-E3400 SCREW-SET
23 23500-N3300 REGULATOR-VOLTAGE (HITACHI TLI A12 1072- 2 23500-29902
23 23500-29906 REGULATOR-VOLTAGE (HITACHI TLI A12 1072- 23500-N3300, 23500-29911
23 23500-29902 REGULATOR-VOLTAGE (HITACHI TLI -972 22 23500-29901
23 23500-29901 REGULATOR-VOLTAGE (HITACHI TL1
23 23500-29911 REGULATOR-VOLTAGE (MITSUBISHI
24 08513-61212 SCREW-TAPPING 2
25 08916-13610 WASHER-LOCK (INTERNAL TOOTH) 2
25C ALTERNATOR(HITACHI)
1 23100-U0100 ASSY-ALTERNATOR 12V-35A (LT135-13) A12
2 23108-U0100 ASSY-ROTOR A12
4 23102-U0101 ASSY-STATOR A12 2 23102-U0100
4 23102-U0100 ASSY-STATOR A12
5 23127-U0100 ASSY-COVER,REAR A12
5 23127-U0101 ASSY-COVER,REAR A12 2 23127-U0100
6 23133-U0100 ASSY-HOLDER,BRUSH A12
6 23133-U0101 ASSY-BRUSH A12 0 23133-U0100
7 23135-H0300 ASSY-BRUSH(F) A12
8 23135-H0301 ASSY-BRUSH(E) A12
9 23193-P0100 TERMINAL-N A12
10 23236-U0100 COVER-BRUSH A12
11 23230-U0100 DIODE A12
12 23236-H0300 COVER-DIODE A12
12 23236-H0301 COVER-DIODE A12 0872- 2 23236-H0300
13 23156-H0300 ASSY-BOLT,TERMINAL A12
14 23247-H0300 SLEEVE A12
15 23118-H0300 ASSY-COVER,FRONT A12
16 23120-14800 BEARING-BALL A12
17 23121-21000 RETAINER-PACKING A12
18 23122-21000 PACKING A12
19 23131-H0300 BOLT-THROUGH 2 A12
20 23131-H0301 BOLT-THROUGH A12
21 23164-H0100 BOLT-SETTING A12
22 23150-21002 ASSY-PULLEY A12
23 23153-H0100 ASSY-NUT,PULLEY A12
24 23200-E3400 SET-SCREW A12
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Alternator_Part_Numbers"
This page has been accessed 7,280 times. This page was last modified 04:34, 4 September 2017. Content is available under Datsun 1200 Club.
