Brake Wiring
From Datsun 1200 Club
Category: Wiring
Dash Brake lamp lights up if there is a problem or if the parking brake is on.
Brake Stop Lights
See: brake stop lamp wiring
Hand Brake Switch
Lamp switch for Hand Brake pull-handle was fitted to USA 1200s, Japan Sunny Truck staring 7510, and is fitted to newer Australia utes.
25759.jpgAlbum 25759
The switch turns on the warning lamp
Switch
17020.jpgAlbum 17020
UTE: switch wire goes up back wall
26409.jpgAlbum 26409
Brake Fluid Level Warning
Starting around 1976, Brake Master Cylinder caps were fitted with floats and electrical switches to warn of low brake fluid level.
26477.jpgAlbum 26477
Pressure Loss Switch
A brake check switch is used on North American 1200s to signal if there is a problem with the brake pressure.
See Main Article: Warning_Light_Switch#Wiring
Schematic
The BRAKE dash lamp is always connect to 12V when IGN switch is on. It only lights up when a switch grounds the bulb. A switch is fitted to the hand brake lever. When you pull the lever, it grounds the circuit.
  • G: Green wire from IGN fuse to dash cluster lamps
  • B: Black wire to main body earth bolt in engine compartment
  • Y/G: Yellow wire w/Green stripe, from switch to bulb, grounds the bulb
21612.jpgAlbum 21612
(Most 1200s don't have the Check/Service Warning Light Switch)
21611.jpgAlbum 21611
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Brake_Wiring"
This page has been accessed 15,289 times. This page was last modified 05:54, 4 December 2021. Content is available under Datsun 1200 Club.
