Chassis Lube
From Datsun 1200 Club
Categories: Front Axle And Front Suspension | Propeller Shaft And Differential Carrier
Chassis Lube or "Grease job" should be done every 12 months.
  1. Driveshaft (tailshaft) - both u-joints
    • Most driveshafts have sealed joints. Some are replaceable, can be removed and repacked.
    • Some have non-replaceable joints.
  2. Steering Linkage
    • 4 side rod ends
    • both ends of Cross Rod
  3. Ball Joints, one each side at front wheels
19475.jpgAlbum 19475
Unfortunately many after market cheap aftermarket manufactured joints are non-greasable types.
And many just have a plug - no grease-gun nipple. However, you can simply remove the plug and put a nipple on it, and then can grease it.
Zerk-type grease fittings, deluxe (with covers)
grease fitting, grease nipple, Zerk fitting, Alemite fitting
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Chassis_Lube"
This page has been accessed 8,848 times. This page was last modified 10:02, 30 July 2016. Content is available under Datsun 1200 Club.
