Clutch Diagnoses
From Datsun 1200 Club
Categories: Clutch | Diagnoses and Corrections
Clutch problems do not necessarily mean you need a new clutch. Adjusting the clutch might resolve the problem. Or other more obscure issues might be the cause.
Noise when pedal pressed
Noise when pedal released
  • Worn Gearbox Bearing (Input Shaft Bearing)
Clutch Won't Release Fully
Difficult to shift gears due to failure to fully release
  • improper adjustment of linkage. Adjust the clutch to see if that fixes the issue.
  • incorrect length of Release Bearing sleeve fitted. If you just swapped gearboxes, this is a somewhat common issue
Grabby clutch
  • Drum shoe brakes too tight, or contaminated with oil or grease. Inspect Rear Brakes and (if so equipped) Brakes#Front Drum Brakes
  • Oil or grease on clutch face
  • Disc rivets loose
  • Poorly lubricated clutch disc splines
  • warped pressure plate
  • Misaligned clutch. Make sure there is no junk between gearbox
  • worn clutch cable (common with RHD clutches)
  • Worn lining. Replace disc
Clutch Slips
  • improper adjustment of linkage (no free play). Adjust the clutch to see if that fixes the issue.
  • worn disc
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Clutch_Diagnoses"
This page has been accessed 8,993 times. This page was last modified 07:37, 2 August 2019. Content is available under Datsun 1200 Club.
