D4N
From Datsun 1200 Club
Categories: Engine Electrical System | Ignition Modifications
Hitachi distributor for 8-plug distributors (CA-series and Z-series). It has a one-piece type internal module (ignitor + pickup in one). The module looks similar to the D4R distributor but D4R has only two terminals.
Vacuum Advance module looks similar but the screw is 90-degrees to D4R and D4K advance modules.
* 8-plug caps
* 90-degree advance mounting
* 3-wire hookup
* 720 with Z20, Z22, Z24 (not Z24I)
* M10 (CA20E) -0986
* S110 with Z22E, Z20E.CAL [FED is 4-plug, uses matchbox]
* S12 with CA20E -0186 (newer has no advance module)
* T11 with CA20S, CA20E.(EXC MITSUBISHI)
STATOR
22163-W0560 Z20,Z22,Z24
* USA
** 720 Pickup Z20, Z22, and Z24 engines
** M10 with CA20E
** S110 with Z20E, Z22E
** S12 with CA20E
** T11 with CA20E, CA20S
TIU
TRANSISTOR IGNITION UNIT [ignitor & pickup unit]
5-terminal (EBDTI, Coil-, Battery, Retard Input, Tachometer, Coil+)
22020-61W00/22020-61W02/22020-61W03
* 720.Z20
* General Motors 88921571
* Wells JA141
4-terminal (EBCI, Coil+, Coil-, Battery)
22020-D0200
* S110.Z22E
* 720.Z24
* Wells JA124
22020-V5400/22020-V5401
* 720.Z24
* Wells JA124
3-terminal (EBI, Coil+, Coil-, Battery)
22020-W0560/22020-W0561
* 720.Z22, M10.CA20E.MT, S12.CA20E, T11.CA20E.MT
* S110.Z20E 0179-0681
* Wells JA113
22020-W0560
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=D4N"
This page has been accessed 8,853 times. This page was last modified 03:27, 24 September 2017. Content is available under Datsun 1200 Club.
