For the 70s
From Datsun 1200 Club
Category: Documentation
<-- back to USA brochures
Title: DATSUN 1200 2-door Sedan [Blue 2-door Sedan]
1971 2door B110R
Format:single sheet Size:unknown Publication Number:SLE 2310-011012
5264.jpg#folded 29081.jpg#A 29082.jpg#B
A12 Engine:
rugged technological masterpiece
Folded
Lower quarter of Side B folder over onto Side A
It's the all new
Big Little car for 70's
5264.jpgAlbum 5264
Side A
Dash, interior, flow-through ventilation
29081.jpgAlbum 29081
The most exciting 1200 cc sedan in the Western Hemisphere!
Sporty in appearance! Sporty in performance! Unexpected comforts and luxury features throughout this economical motoring wonder! Easy to drive and a cinch to park, DATSUN's all new 2-door sedan is unbelievably roomy, even in the back!
Outmaneuver the clumsy over-sized monsters with DATSUN'S superior power/weight ratio (under 23.0 lbs. per HP). Outspeed conventional "economy" cars at over 90 mph! Top performance and top features!
Here are desirables that most makers charge you extra for-Disc brakes! Short-throw 4-on-the-floor! Sun visors, Bumper guard! Safety tubeless white sidewall tires! Double horn! Steering lock! Mirrors inside and outside! And flow-through ventilation!
Of course there are specially tested safety facilities like collapsible steering, tandem master cylinder, seat belts, windshield washer and 2-speed wipers. Notice you get a lot that's above and beyond ordinary safety standards. Extras are standard on this fabulous all-new sedan!
Closeup
29083.jpgAlbum 29083
Side B
Mechanism
29082.jpgAlbum 29082
World-Famous Nissan Engine!
Here's the tested powerhouse that gets you over 90 mph easily! Four efficient cylinders generate 69 energetic horses most economically. Big car 5-bearing crankshaft for smooth, powerful operation. Designed to run superbly at high speeds and reliably at low speeds, this rugged technological masterpiece offers 71.5 cu. in. displacement.
Special Suspensions!
The suspensions were carefully designed to perfectly match the superior handling characteristics of this new car. As a result, the rear suspensions, for example, were specifically planned to balance the fully independent suspensions up front. A semi-floating axle has been integrated with newly developed semielliptic leaf springs in the rear. Proven strut-type suspensions up front assure optimum road holding and stability.
Safe, Sports Car Steering
The most sensitive steering mechanism is recirculating ball — something which most cars don't have, but which DATSUN gets! So you get greater car control than ever before! The amazingly short turning circle (under 27 ft) not only assures exceptional maneuverability, it also makes parking so easy. You can slip into spaces other compacts have to pass by. Naturally, the steering column is fully collapsible for safety.
Exclusive NUBCI
Nissan's Unitary Body Construction (NUBC) features an expensive welding process that permanently joins chassis and frame as one solid unit. Extra rigid for safety. Extra quiet because there are no bolts to rattle. Extra low maintenance because there are fewer parts to work loose and cause trouble.
Disc Brakes!
Of course disc brakes are best! They're the only kind that assure non-fade stopping even at high speeds. But just check how many compacts offer this professional feature as standard equipment!
DATSUN
NISSAN MOTOR CO. LTD.
Copyright 1971 by Nissan Motor Company, Limited. All rights reserved. Printed in Japan.
Publication No. SLE 2310-011012
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=For_the_70s"
This page has been accessed 1,113 times. This page was last modified 17:45, 1 April 2025. Content is available under Datsun 1200 Club.
