Hall-effect distributor conversion
From Datsun 1200 Club
Categories: Engine Electrical System | Ignition Modifications
Convert your newer Hitachi D4A Distributor (A14/A15/A12) to Hall-effect using VW distributor. Only need to drill one little hole. Hall Effect is a magnetic sensor with built-in amplifier in the sensor, to create a standard voltage signal before it is sent to an ignition controller. The dizzy is locked, no mechanical advance or nothing -- the controller does that, so this is good for a custom turbo spark curve.
This can be used with an ECU or with a programmable ignition controller like MSD 6AL-2. A points distributor can also trigger ECU or controller, but the Hall Effect works reliably at RPMs in excess of 8000 RPM and need no periodic adjustment.
Finished product
10579.jpgAlbum 10579 10580.jpgAlbum 10580 10620.jpgAlbum 10620
Main Forum discussions:
* Hallified A14\A15 Dizzy
* crank angle sensor
Parts Needed
Parts Needed
* Hitachi D4A Distributor 1973-up large cap type
VW/Audi electronic ignition Hall-effect type distributor
* wire shield
* Disrupter ring (trigger ring)
* Hall Effect sensor plate
* rotor shaft
10604.jpgAlbum 10604 10605.jpgAlbum 10605 10606.jpgAlbum 10606
Source
1980-1983 Volkswagen/Audi electronic ignition distributor (hall effect type) for 4-cylinder engine.
Rockauto $122
South Africa
* Golf Mk1 1.8 and others
USA 4-cyl 1.5, 1.6, 1.7
* 1980-1983 Audi 4000 MFI
* 1980-1983 VW Dasher, Jetta, Rabbit, Scirrocco, Quantum
Steps
Remove the Hitachi contact plate
10607.jpgAlbum 10607
Modify the Golf rotor shaft by cutting a flat on one side so the Hitachi rotor will slip on. Use file and hacksaw.
Remove the Hitachi rotor shaft & install Golf rotor shaft
10608.jpgAlbum 10608 10609.jpgAlbum 10609
The Golf's upper shaft has 2 pins underneath, where the springs get hooked up, make them fit in between the weights, and when your tighten it from the top, just add a little washer, the make sure the shaft gets tightened, so it's locked with the bottom shaft.
Install the locked contact point plate (this disables vacuum advance)
10610.jpgAlbum 10610
Install the Golf sensor plate (drill one hole)
10611.jpgAlbum 10611 10612.jpgAlbum 10612 10613.jpgAlbum 10613
Fit Golf wire shield in place
10614.jpgAlbum 10614
Install circlip
10615.jpgAlbum 10615
Put Disrupter ring in place, key and top circlip
10616.jpgAlbum 10616 10617.jpgAlbum 10617 10618.jpgAlbum 10618 10619.jpgAlbum 10619
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Hall-effect_distributor_conversion"
This page has been accessed 10,430 times. This page was last modified 08:37, 14 January 2017. Content is available under Datsun 1200 Club.
