Lowering B210
From Datsun 1200 Club
Categories: Datsun B210 | Lowering
See also: Lowering, which focuses on B110, but is mostly also applicable to B210.
The B110 strut tops are different from B210 tops. They 1200 tops have a lower profile and will lower a B210, just need to open up the center hole.
B110 vs B210 strut tops
10021.jpgAlbum 10021
Fitting 1200 tops into 120Y lowers the car 30mm
10022.jpgAlbum 10022 10019.jpgAlbum 10019
Using B110 strut tops in a 120Y lowers the front by 1 1/2". The PCD is different (slightly) so I knocked the studs out, elongated the holes with a die grinder, put the 120Y studs in. Gave them a zzzap to stop the moving during assembly. The hole the in the B210 strut tower needs to be opened up, I used a set of vice grips. Went a little at a time, about 4 times around.
POST 120Y lowering on the cheap
07/06/2013 update by L18_B110:
I just fitted a set of B110 strut tops to a B210 and found it slightly different to the above info.
PCD is identical - no mods required there. The B110 studs fit straight into the B210 holes. B110 studs are smaller diametre, M8 versus B210 studs M10 but that's no problem. I just used a washer under the nuts.
The centre hole in the B210 strut tower does need to be opened up from 80mm diametre to 94mm. I cut it carefully with an angle grinder with a 1mm cutting disc after marking around the opening. Photo shows the material removed.
This mod lowered my car approximately 30mm. The 1200 strut top mounts the shock top 5mm above the strut tower, and the 120Y mounts it 25mm below the strut tower.
Photo: opening up hole
25205.jpgAlbum 25205
CAUTION: doing the opposite -- fitting B210 strut tops to a 1200 -- raises the car about 30 mm
1204.jpgAlbum 1204
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Lowering_B210"
This page has been accessed 13,502 times. This page was last modified 18:48, 16 August 2018. Content is available under Datsun 1200 Club.
