Rear Door Part Numbers
From Datsun 1200 Club
Categories: Body | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Door
Door Hinge
Door Glass
Weatherstripping
Sedan
REAR DOOR (4 DOOR SEDAN)
1 82102-H1000 ASS'Y-PANEL, rear door (R.H.) STD
  82102-H1100 ASS'Y-PANEL, rear door (R.H.) DX,GL,GX
  82103-H1000 ASS'Y-PANEL, rear door (L.H.) STD
  82103-H1100 ASS'Y-PANEL, rear door (L.H.) DX,GL,GX
2   82210-H1001 ASS'Y-SASH, rear door (R.H.)
    82211-H1001 ASS'Y-SASH, rear door (L.H.)
3 82220-H1000 ASS'Y-SASH, partition, rear door (R.H.)
  82221-H1000 ASS'Y-SASH, partition, rear door (L.H.)
4 82336-H1000   RUBBER-glass run "D" (2)
  82336-H1001   RUBBER-glass run "D" (from '70-Oct.) (2) > 82336-H1000
5    08320-40612 SCREW-fixing partition to sash (2)
   fixing partition to inner parcel
6    08915-53610 WASHER-plain (2)
7    08915-13610 WASHER-lock (2)
8    08410-61012 SCREW (2)
9 82254-H1000 GLASS-rear door corner (R.H.) STD
  82254-H1100 GLASS-rear door corner (R.H.) DX,GL,GX
  82255-H1000 GLASS-rear door corner (L.H.) STD
  82255-H1100 GLASS-rear door corner (L.H.) DX,GL,GX
10 82242-H1000 WEATHERSTRIP-partition rear door (2)
REAR DOOR HINGE (4 DOOR SEDAN)
11 82400-H1001 HINGE ASS'Y-rear door, upper (R.H.)
   82401-H1001 HINGE ASS'Y-rear door, upper (L.H.)
12 82402-H1000 HINGE ASS'Y-rear door, lower (2)
   H0400-73002 BUSHING-door hinge (8)
fixing hinge
   13 01221-00031 BOLT-with plain & lock washer (fixing hinge to pillar) (12)
   14 08120-82062 BOLT-with lock washer (fixing hinge to door) (10)
or, fixing hinge
   13 77720-89913 BOLT-special (fixing pillar) (12)
      77740-89912 WASHER-plain special (fixing pillar) (12)
   14 08120-82062 BOLT-with lock washer (fixing door) (10)
or, fixing hinge
   13,14 011-21000 BOLT-with plain & lock washer (22)
REAR DOOR FITTING (4 DOOR SEDAN)
15 82830-H1000 WEATHERSTRIP ASS'Y-rear door (R.H.)
   82831-H1000 WEATHERSTRIP ASS'Y-rear door (L.H.)
16 ※左右Setで左?性?り。
   82820-H1000 MOULDING ASS'Y-rear door outside (R.H.) <※> 82820-H3100
   82820-H3100 MOULDING ASS'Y-rear door outside (R.H.) (from '72-4)
   82821-H1000 MOULDING ASS'Y-rear door outside (L.H.) <※> 82821-H3100
   82821-H3100 MOULDING ASS'Y-rear door outside (L.H.) (from '72-4)
17 80825-H1000 CLIP-moulding, door outside (8)
18 82836-H1000 WEATHERSTRIP-rear door inside (R.H.)
   82837-H1000 WEATHERSTRIP-rear door inside (L.H.)
19 80860-H1000 STOPPER ASS'Y-door glass (2)
20 08310-61214   SCREW
21 86865-21010 RUBBER-bumper, rear door (2)
22 82804-H1000 SCREEN-seal (2)
23 80840-21001 COVER-drain hole (4)
24 96502-H1001 ASH TRAY ASS'Y (1) STD (2) DX,GL,GX
25 08520-51212   SCREW (1) STD (2) DX,GL,GX
REAR DOOR TRIMMING (4 DOOR SEDAN)
26 82900-H1000 FINISHER ASS'Y-rear door (R.H.) STD
   82900-H3100 FINISHER ASS'Y-rear door (R.H.) STD 1972
   82901-H3100 FINISHER ASS'Y-rear door (L.H.) STD
   82901-H3100 FINISHER ASS'Y-rear door (L.H.) STD 1972
27 82900-H1100 FINISHER ASS'Y-rear door (R.H.) (Black) DX,GL,GX
   82900-H3200 FINISHER ASS'Y-rear door (R.H.) (Black) DX,GL,GX 1972
   82900-H1101 FINISHER ASS'Y-rear door (R.H.) (Yellow) DX
   82900-H3201 FINISHER ASS'Y-rear door (R.H.) (Yellow) DX 1972
   82901-H1100 FINISHER ASS'Y-rear door (L.H.) (Black) DX,GL,GX
   82901-H3200 FINISHER ASS'Y-rear door (L.H.) (Black) DX,GL,GX 1972
   82901-H1101 FINISHER ASS'Y-rear door (L.H.) (Yellow) DX
   82901-H3201 FINISHER ASS'Y-rear door (L.H.) (Yellow) DX 1972
28 80919-89900 CLIP-door finisher (12)
29 80929-32200 CAP-door finisher (12)
30 80960-H1000 HANDLE-pull (M5) (2) STD < 80960-H1001
   80960-H1001 HANDLE-pull (M6) (2) STD
   fixing pull handle
   31 08310-52042 SCREW (M5) (4)
      08310-62042 SCREW (M6) (4)
   32 08915-43542 WASHER-plain (M5) (4)
      08915-43642 WASHER-plain (M6) (4)
33 80940-H1100 ARM REST COMP (2) DX,GL,GX
   fixing arm rest
   34 08410-62012 SCREW (4)
   35 08915-13610 WASHER-lock (4)
Van
REAR DOOR (VAN)
 1 82102-H1400 ASS'Y-PANEL, rear door (R.H.)
 2 82210-H1401   ASS'Y-SASH, rear door (R.H.)
   82211-H1401   ASS'Y-SASH, rear door (L.H.)
 3 82220-H1400 ASS'Y-SASH, partition, rear door (R.H.)
   82221-H1400 ASS'Y-SASH, partition, rear door (L.H.)
 4 82336-H1400 RUBBER-glass run "D" (2)
 fixing partition to inner panel
 9 82254-H1400 GLASS-rear door corner (R.H.) VS,VP
   82254-H1500 GLASS-rear door corner (R.H.) V-DX
   82255-H1400 GLASS-rear door corner (L.H.) VS,VP
   82255-H1500 GLASS-rear door corner (L.H.) V-DX
10 82242-H1400 WEATHERSTRIP-partition rear door 2 V-Dx.
REAR DOOR HINGE (4 DOOR VAN)
same as 4-door sedan above
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Rear_Door_Part_Numbers"
This page has been accessed 5,241 times. This page was last modified 05:47, 2 August 2017. Content is available under Datsun 1200 Club.
