Suzuki G Engine Swap
From Datsun 1200 Club
Categories: Engine Modifications | Engine Swaps
Suzuki G-series B (16-valve) engine is a lightweight, high-output, twin-cam four cylinder. For example, the G13B from GTI Swift is lighter than A15, but 109 HP compare to 80HP for an A15.
The beauty of this engine is the power, torque and weight capability. 125HP with carb and exhaust changes.
  • 10kg lighter than A10
  • 20kg lighter than A15 when all considered
GB13 in Datsun 1000
22493.jpgAlbum 22493
See wikipedia:Suzuki G engine
G13B
G13BA SOHC
G13BB (MPFI)
G16B
G13B in Datsun 1200
14126.jpgAlbum 14126
Sources
G16B
* 1990–2005 Suzuki Escudo TA01R/W-2.3.4.5
* 1992–1997 Suzuki Esteem
* 1995–2002 Suzuki Cultus Crescent
* Geo Tracker
* Suzuki Sidekick
* 1995-1997 Suzuki X-90
* Suzuki Swift
* 1994 Suzuki Vitara 16V
Ignition
Distributor: because it is on the back of the head, some mod will be needed.
20769.jpgAlbum 20769 19722.jpgAlbum 19722
Suzi-tech at Thornliegh made the dizzy and it cost a fortune. If I was to do it again I would just cut the fire wall. I think you can use a Mazda cap which gives you more room.
Turbo
20774.jpgAlbum 20774 20775.jpgAlbum 20775 20768.jpgAlbum 20768 20770.jpgAlbum 20770 20771.jpgAlbum 20771 20772.jpgAlbum 20772 20776.jpgAlbum 20776 21192.jpgAlbum 21192 21193.jpgAlbum 21193 21194.jpgAlbum 21194 20683.jpgAlbum 20683
Cooling
18857.jpgAlbum 18857 18858.jpgAlbum 18858
Transmission
Gearbox: use Suzuki Sierra or Samurai gearbox or Geo Tracker
24370.jpgAlbum 24370
The box will fit easily in a 1200 tunnel if it is the 4x2 version.
24371.jpgAlbum 24371 24372.jpgAlbum 24372
In Datsun 1000
18511.jpgAlbum 18511 18827.jpgAlbum 18827 18826.jpgAlbum 18826
Shifter
Gearlever moved forward on Suzuki gearbox
This is the lever moved forward with flat alloy cover plate then use a Sierra or other shifter housing
24373.jpgAlbum 24373
Gav
GB13 in Datsun 1000. See Build Project discussion: G13B into my KB10
19373.jpgAlbum 19373 20616.jpgAlbum 20616 20770.jpgAlbum 20770 20776.jpgAlbum 20776 21192.jpgAlbum 21192 21194.jpgAlbum 21194 22494.jpgAlbum 22494 18512.jpgAlbum 18512 18513.jpgAlbum 18513 18514.jpgAlbum 18514
Lightened flywheel
19725.jpgAlbum 19725
935.JPGAlbum click to view 936.JPGAlbum click to view 937.JPGAlbum click to view 18317.jpgAlbum click to view 18318.jpgAlbum click to view 18319.jpgAlbum click to view 18320.jpgAlbum click to view 18825.jpgAlbum click to view 18828.jpgAlbum click to view 18860.jpgAlbum click to view 18861.jpgAlbum click to view 18862.jpgAlbum click to view 18863.jpgAlbum click to view 19372.jpgAlbum click to view
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Suzuki_G_Engine_Swap"
This page has been accessed 76,823 times. This page was last modified 00:47, 21 April 2018. Content is available under Datsun 1200 Club.
