Technical Bulletins
From Datsun 1200 Club
Category: General Information
Service changes were communicated with the issuing of a technical bulletin, so that dealer mechanics would know the latest procedures.
"Technical Bulletins for Datsun vehicles, 1978 Edition" (Service Technical Training Department, Nissan Motor Corporation in U.S.A.)
14122.jpgAlbum 14122
DATSUN TECHNICAL BULLETINS
January 1969 through December 1972
Technical Communications Dept. of Technical Engineering
Nissan Motor Company in U.S.A.
28207.pngAlbum 28207
Index
1200-applicable bulletins (including one that apply to "All Models")
TS71-20 1200 COUPE REAR FENDER DRAIN PLUG
TS71-28 CARTRIDGE OIL FILTER
TS71-31 COOLING FAN
TS71-33 CARBURETOR MODIFICATION
TS71-35 CARBURETOR CLEANING
TS71-40 REPLACEMENT PISTONS AND RINGS
TS71-44 CYLINDER HEAD TIGHTENING TORQUE
TS71-45 CYLINDER HEAD GASKET
TS71-48 TIMING CHAIN MODIFICATION
TS71-49 THROTTLE CABLE VIBRATION
TS71-59 GROUNDING, TAILLIGHT ASSEMBLY
TS72-05 INSTALLATION OF 1971 AIR CONDITION KIT IN 1972 VEHICLES
TS72-08 IDLE MIXTURE SCREW LIMITER CAP
TS72-18 ENGINE OIL LEVEL GAUAGE
TS72-24 TIMING MARKS, ALL MODELS
TS72-37 REMOVING POLYETHELENE COVERS
TS72-38 FRONT SEAT BELT ANCHORAGE
TS72-40 ABOLISHMENT OF TOUCH-UP PAINT
TS72-44 CYLINDER HEAD GASKET, 1972 MODEL
TS72-46 REMOVING AND INSTALLING CYLINDER HEAD BOLTS
TS72-48 STEERING WHEEL PULLER
TS72-51 VALVE CLEARANCE
TS72-58 [TANDEM] BRAKE MASTER CYLINDER
TS72-59 CHANGE IN TIMING INDICATOR AND PULLEY MARKS
TS72-62 ENGINE NUMBERS
TS72-65 INERTIA WEIGHT LABEL
TS72-71 CYLINDER HEAD MODIFICATIONS
TS72-70 GAS-FILLED SHOCK ABSORBERS
TS72-77 CYLINDER HEAD MODIFICATIONS
TS72-82 LUBRICANT SPECIFICATIONS
TS72-85 CAMSHAFT PLUGS
TS72-87 PRE-DELIVERY VEHICLE ALTERATION PROHIBITION
TS72-89 VALVE AND GUIDE REPLACEMENT
TS72-89B CYLINDER HEAD OIL GALLERY PLUGS
TS72-91 USE OF KEENSERTS
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Technical_Bulletins"
This page has been accessed 1,013 times. This page was last modified 00:01, 25 February 2023. Content is available under Datsun 1200 Club.
