Template:VR
From Datsun 1200 Club
The coolant/water temperature gauge incorporates a voltage regulator, which controls both fuel and water gauges.
  • If both the water and fuel gauges are off, suspect the regulator
  • If only one gauge is incorrect, suspect a bad connection, usually at the sender
See:  Fuel Gauge Wiring
See:  Temperature Gauge Wiring
Temperature Sender at cylinder head (on right side of head, at the very front):
8122.jpgAlbum 8122
Fuel Level Sender at fuel tank
24469.jpgAlbum 24469
Voltage Regulator is part of Temperature Gauge
19519.jpgAlbum 19519
Voltage Regulator Circuit in Cluster Gauge
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Template:VR"
This page has been accessed 1,031 times. This page was last modified 00:16, 8 August 2016. Content is available under Datsun 1200 Club.
