Valvetrain Part Numbers
From Datsun 1200 Club
Categories: Engine Mechanical | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
Camshaft
Valves
Rocker Shaft
Timing Chain
Push Rods
 1 13001-H7000 ASSY-CAMSHAFT A12 0772- 0 13001-H2300
 1 13001-H1000 CAMSHAFT A12
 2 11023-78200 PLUG-TAPER A12
 3 13032-18000 DOWEL-CAMSHAFT GEAR A12
 4 13010-18001 PLATE-CAMSHAFT A12
   08110-6161A BOLT-FIXING CAMSHAFT PLATE (2) A12 01111-00022
 5 01111-00022 BOLT-FIXING CAMSHAFT PLATE (2) A12
   08915-1361A WASHER-LOCK FIXING CAMSHAFT PLATE (2) A12 08915-13610
 6 08915-13610 WASHER-LOCK FIXING CAMSHAFT PLATE (2) A12
   13024-H8500 SPROCKET-CAMSHAFT A12 13024-18001
 7 13024-18001 SPROCKET-CAMSHAFT A12
 8 13082-18000 BOLT-CAMSHAFT SPROCKET A12
 9 13030-18000 WASHER-CAMSHAFT A12
   08915-2401A WASHER-LOCK A12 08915-14010
10 08915-14010 WASHER-LOCK A12
11 13028-18001 CHAIN-CAMSHAFT A12
12 13070-18001 ASSY-TENSIONER CHAIN A12
13 08120-63510 BOLT-FIXING CHAIN TENSIONER (2) A12
14 08915-13610 WASHER-LOCK FIXING CHAIN TENSIONER (2) A12
15 13201-H1000 VALVE-INTAKE (4) A12
16 13202-H1000 VALVE-EXHAUST (4) A12
17 13203-H1000 SPRING-VALVE OUTER (8) A12
18 13205-18000 SEAT-VALVE SPRING (8) A12
19 13209-H2302 RETAINER-VALVE SPRING (8) A12 0772- 0 13209-H2301
19 13209-18000 RETAINER-VALVE SPRING (8) A12
19 13209-H2300 RETAINER-VALVE SPRING (8) A12 2 13209-18000
19 13209-H2301 RETAINER-VALVE SPRING (8) A12 0670-0672 2 13209-H2300
20 13210-73400 COLLET-VALVE 1 (16) A12
20 13210-H1000 COLLET-VALVE 1 (16) A12 0272- 0
20 13210-U0100 COLLET-VALVE 1 (16) A12 1072- 2 13210-H1000
21 13207-18000 SEAL-OIL VALVE (INTAKE ONLY) (8) A12 -672
21 13207-H2301 SEAL-LIP VALVE OIL (INTAKE ONLY,KEEPER) (4) OP A12 2 13207-H2300
21 13207-H2310 SEAL-LIP,VALVE,OIL (INTAKE ONLY,NOK) (4) OP A12
22 13219-H1000 SHROUD-VALVE INNER (8) A12 0772- 2 13207-18000
22 13219-H1000 SHROUD-VALVE INNER,FOR TROPICAL REG (8) OP A12
23 13252-18000 ASSY-SHAFT & VALVE ROCKER A12
24 13254-58000 PLUG-EXPANSHION ROCKER SHAFT (2) A12
25 13256-18000 SPRING-INSIDE ROCKER SHAFT (4) A12
26 13222-18001 BRACKET-ROCKER SHAFT (5) A12
27 13224-18000 BOLT-ROCKER SHAFT (5) A12
28 08915-43810 WASHER-PLAIN (5) A12
29 13257-18003 ROCKER-VALVE NO.1 (4) A12 13257-18001
29 13257-18001 ROCKER-VALVE NO.1 (4) A12
30 13258-18003 ROCKER-VALVE NO.2 (4) A12 13258-18001
30 13258-18001 ROCKER-VALVE NO.2 (4) A12
31 13234-18000 SCREW-ADJUSTING ROCKER VALVE (8) A12
32 13288-18001 NUT-ADJUSTING ROCKER VALVE (8) A12
33 13231-H1000 LIFTER-VALVE (8) A12
33 13231-H1001 LIFTER-VALVE (8) A12 13231-H1000
34 13238-H1001 ROD-PUSH (8) A12 1070- 2 13238-H1000
34 13238-H1000 ROD-PUSH (8) A12
1973 LB110 USA Parts Catalog
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Valvetrain_Part_Numbers"
This page has been accessed 5,850 times. This page was last modified 05:40, 4 September 2017. Content is available under Datsun 1200 Club.
