Water Pump Part Numbers
From Datsun 1200 Club
Categories: Cooling System | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
Water Pump
Fan
Truck
WATER PUMP & FAN
1 21010-18027 PUMP ASS'Y-water, with gasket
  21010-H1025 PUMP ASS'Y-water, with gasket > 21010-18027
  21010-H5025 PUMP ASS'Y-water, with gasket (7211-8109) <*> 21010-H1025
  * 08110-85010 (2 pcs),08213-84810 (3 pcs) とセットはにて新->旧に互瑍性おります。
  21010-H7225 7804-8109 OP.COOLER <0,0> 21010-H7227
  21010-H7227 8110-     OP.COOLER
  21010-M6626 8110-     <0,2> 21010-H5025
2 21014-18000 GASKET-water pump cover to body side
  21014-H1000 GASKET-WATER PUMP 7510-
fixing water pump (from '72-11)
 3 08911-10810 NUT 3
   08911-1082A NUT 7510-
 4 08110-84810 BOLT 2
   08110-45010 BOLT 2 > 08110-84810
   08120-83062 BOLT 7510-
 5 08915-13810 WASHER-lock 5
   09340-0010P WASHER-LOCK 8110-
6 21051-18000 PULLEY-fan and water pump -8910
  21051-H7200 OP.COOLER 7804-
  21051-H8500 9810-
7 11720N
  11720-18002 BELT-fan
  11720-77701 BELT-FAN & ALTERNATOR 7510-8503 L=980 <2,0> 11720-77702
  11720-77702 8504- L=990
  11720-H7200 OP.COOLER 7804-8109 L=970 Band <2,2> 11720-H7201
  11720-H7201 OP.COOLER 8110- L=990 Band
  11720-H7210 OP.COOLER 8504- L=975 Samsung
8 21060-H1001 BLADE-fan
  21060-H1001 7510-
  21060-N0110 FAN-COOLING OP.COOLER 7804-8109 <0,0> 21060-G1210
  21060-G1210 FAN-COOLING OP.COOLER 8110-
fixing fan blade to water pump
 9 08120-62010 BOLT 4
 10 21069-21000 WASHER-lock 2
21064-G1660 SPACER-FAN OP.COOLER 7804-7907 <0,0> 21064-G1615
21064-G1615 SPACER-FAN OP.COOLER 7908-
1974 B120 Parts Catalog C-288
1997 B120 Parts Catalog C-415
1 21010-18003 ASSY-PUMP WATER
1 21010-18026 ASSY-PUMP WATER WITH GASKET <> 21010-18003
1 21010-18027 ASSY-PUMP WATER WITH GASKET 0870-0871 <> 21010-18026
1 21010-H1025 ASSY-PUMP WATER WITH GASKET 0971-1072 <> 21010-18027
1 21010-H5025 ASSY-PUMP WATER WITH GASKET 1172- <> 21010-H1025
1 BA010-M6626 ASSY-PUMP WATER WITH GASKET 1172- <> 21010-H5025
2 21022-18003 VANE-WATER PUMP
3 21026-73000 ASSY-SEAL WATER PUMP
4 21027-73000 ASSY-SEAT
5 21035-13202 BEARING-WATER PUMP
6 21054-18000 HUB-WATER PUMP
7 21014-18000 GASKET-WATER PUMP COVER
8 08911-10810 NUT-HEX M8 FIXING WATER PUMP (3)
9 08110-84810 BOLT-HEX M8 FIXING WATER PUMP (2)
9 08110-85010 BOLT-HEX M8 FIXING WATER PUMP (2) 1172- <> 08110-84810
10 08915-13810 WASHER-LOCK FIXING WATER PUMP (5)
11 21051-18000 PULLEY-FAN & WATER PUMP
12 21060-H1001 FAN-COOLING
12 21060-A4605 FAN-COOLING D=330 FOR TROPICAL USA OP CRANK
12 21060-N0100 FAN-COOLING,FOR TROPICAL USE OP <> 21060-A4605
13 08120-62010 BOLT-HEX FIXING FAN (4)
14 21069-21000 WASHER-COCK FIXING FAN (2)
15 11720-18002 BELT-FAN L=838 A12
   11720-G0300 BELT-FAN L=838 <> 11720-18002
1973 LB110 USA Parts Catalog, page 20-1
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Water_Pump_Part_Numbers"
This page has been accessed 8,722 times. This page was last modified 05:05, 26 September 2018. Content is available under Datsun 1200 Club.
