Camshaft Timing
From Datsun 1200 Club
Category: Valvetrain
<-- back to Camshaft
Checking and adjusting the camshaft timing is an important part of a competition engine. You can also do the same for your street 1200 to ensure you are getting the expected performance.
Find TDC
  • degree wheel on crank pulley
  • One dial indicator on piston head
    • Through spark plug hole
    • or, directly if head is removed
3639.jpgAlbum 3639
NOTE: You can also use a piston stop to #find TDC
Advance crankshaft (turn clockwise) until lifter comes up 0.050":
  • Second dial indicator on pushrod, to measure cam lift
  • Timing wheel to have 360 degree measurement
Note the degree at which 0.050 lift occurs
Continue turning and note maximum lift. Compare to the camshaft specification sheet that comes with your camshaft. Or to the factory specifications below.
Check each lobe the same way to see if any lobes are worn.
Find TDC
  • Turn the crank pulley to line up the timing cover "0" with the crank pulley mark. This is TDC.
OR
  • Find true TDC using positive stopped piston
Use a 14mm piston stop $16 USD (or you can make one).
174_6103ddba1cda1.jpgPost 495656
  1. pull all plugs so you can easily turn engine by hand
  2. Put engine in approximate TDC, then rotate a bit further
  3. thread in the Stop to the #1 spark plug hole. Then turn the shaft in until it stops on the piston
  4. rotate back (by hand) a bit to be sure then engine stops (hits the Piston Stop)
  5. Mark the pulley
  6. rotate the opposite way (almost a full turn) until engine stops again
  7. Mark the pulley
Halfway between the two marks is TDC
Fine Adjustments
Advance or retard the camshaft using:
  • offset key for cam pulley
  • or, adjustable cam pulley
Modified timing cover to suit adjustable cam gear
{{Album|3640}
Retarding the cam moves the power band up in the RPM range
Advancing the cam lowers the power band in the RPM range.
Of course using the right camshaft is even better, but this technique can be used to see the effects:
  • fine tune the cam to the engine
  • fine tune the cam/engine to each particular track
  • cover up a mis-matched cam
Slotted cam pulley for adjustment
3639.jpgAlbum 3639
Measuring lift
9528.jpgAlbum 9528
Factory Specifications
See Camshaft Comparison for more details.
240/240 duration (A10 Datsun 1000)
248/248 duration (standard small bore A12/A13)
256/248 duration (standard large bore A14/A15)
256/256 duration (performance engines GX/A12T/EGI)
248/244 duration (1981-1982 USA)
248/248 as used by standard A12
23656.jpgAlbum 23656
248/248/14/54/12/56
Late-model
18422.jpgAlbum 18422
248/244/14/50/12/56
248/248/14/54/12/56
248/244/14/50/12/56
256/248/14/54/20/56
B310 Australia?
6195.jpgAlbum 6195
A14: 256/248
A12: 248/248
Aftermarket Specifications
210/199 Camtech "turbo" profile 600A68A-TURBO
246/239/14/52/4/55
921.jpgAlbum 921
228/228 Iskenderian D8-66
228/228/5/43/6/43
266/256/24/62/24/62
7518.jpgAlbum 7518
274/271 JTS 104CB
212/212/-2/35/-5/37
14441.jpgAlbum 14441
291/296 JTS 140-6
238/238/15/42/10/47
15607.jpgAlbum 15607
Smiths Regrinds (Mace Engineering)
0.050 specs not listed
7041.jpgAlbum 7041
Camtech Cams
618: 199/196 2000-6000 RPM
639: 210/210 2400-6400 RPM
621: 220/223 2600-6800 RPM
609: 231/235 3200-7200 RPM
608: 241/243 4000-7000 RPM
604: 250/253 4400-8200 RPM
23657.jpgAlbum 23657
JUN Camshafts
68, 72, 74, 76, 80, 82
23658.jpgAlbum 23658
74 Bprojects RACING CAMSHAFT 296-7.0
Usage: new-style A12
Duration: 74 (296)
Cam Lift: 7.0mm (0.276")
Cold Valve Clearance: 0.3mm (0.012")
Valve Timing Centerline: 103.5(Deg)
Wavy groove finish and Surface Coating
*TOMEI Ouality Control
Auckland Cams
23659.jpgAlbum 23659
grind #A057 Auckland Cams
Type: Fast Road
IN Advertised duration: 280 degrees
EX Advertised duration: 280 degrees
IN Duration at .050": 233 degrees
IN Cam lift:.284"
EX Cam lift .284"
Lobe separation: 108.5 degrees
This cam will have a lopey idle and is suitable for high performance street use and/or rally applications. Wide power band 2200-7000 rpm. Can be used with stock standard engine and will run well. For best results use with of 10.0 to 1 compression ratio, twin carbs and extractors.
Conversion
Japan to non-Japan duration
68 272
70
72 288
74 296
76 304
80 320
82 328
Valve Lift
Each manufacturer specifies this differently. The spec is valve lift (at the valve) but the cam lobe lift is amplified by the rocker arm ratio less valve lash:
Nissan: 1.44 ratio, cam lift not specified
JTS: 1.5 ratio, but they also specify cam lift
Camtech: cam lift only specified
Isky: ~1.48 ratio
For example:
Nissan cam lobe in.: 1.426" std (wear limit: 1.4055")
Nissan cam lobe in.: 1.187" base circle
Nissan cam lift: ~0.239"
Nissan Lash: ~0.013"
Nissan ratio: 1.44
Nissan valve lift: 0.331"
Valve Lash
Aftermarket camshaft grinders recommend from 0.010" to 0.024" depending on the profile (standard lash is 0.013" warm/0.014" cold).
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Camshaft_Timing"
This page has been accessed 24,685 times. This page was last modified 05:12, 11 November 2025. Content is available under Datsun 1200 Club.
